Question / Help Problems with the installation of OBS
galaxymax
Hello guys!
I have a problem with the installation of OBS. He tells me that there are no vc2017redist_x64 and vc2017redist_x86 files on my computer. Well, I install them, restart the computer and the installation stops telling me that I have to install the two components above.
Can you help me?
Thank you
Try to download .zip version of the OBS Studio - unpack it to any folder and run ("bin\64bit\obs64.exe"). If it fails to run - it may show to you what file is really missing from your system.
