23:11:53: Open Broadcaster Software v0.613b - 32bit (´・ω・`)
23:11:53: -------------------------------
23:11:53: CPU Name: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
23:11:53: CPU Speed: 2394MHz
23:11:53: Physical Memory: 4095MB Total, 2860MB Free
23:11:53: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
23:11:53: monitor 1: pos={0, 0}, size={1920, 1080}
23:11:53: Windows Version: 6.2 Build 9200
23:11:53: Aero is Enabled
23:11:53: OBS Modules:
23:11:53: Base Address Module
23:11:53: 00920000 OBS.exe
23:11:53: 572A0000 OBSApi.dll
23:11:53: 57B20000 DShowPlugin.dll
23:11:53: 57B00000 GraphicsCapture.dll
23:11:53: 57AE0000 NoiseGate.dll
23:11:53: 57AC0000 PSVPlugin.dll
23:11:53: ------------------------------------------
23:11:53: Adapter 1
23:11:53: Video Adapter: Intel(R) HD Graphics 4600
23:11:53: Video Adapter Dedicated Video Memory: 0
23:11:53: Video Adapter Shared System Memory: 1879048192
23:11:53: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
23:11:53: Adapter 2
23:11:53: Video Adapter: NVIDIA GeForce GT 755M
23:11:53: Video Adapter Dedicated Video Memory: 2085482496
23:11:53: Video Adapter Shared System Memory: 2147610624
23:11:53: =====Stream Start: 2014-03-12, 23:11:53===============================================
23:11:53: Multithreaded optimizations: On
23:11:53: Base resolution: 1920x1080
23:11:53: Output resolution: 1920x1080
23:11:53: Loading up D3D10 on Intel(R) HD Graphics 4600 (Adapter 1)...
23:11:53: Audio Format: 48000 Hz
23:11:53: Audio Channels: 2 Ch
23:11:53: Playback device Default
23:11:53: Using desktop audio input: Speakers (2- Gioteck EX-05 Headset)
23:11:53: Audio Encoding: AAC
23:11:53: bitrate: 128
23:11:53: Using graphics capture
23:11:54: Scene buffering time set to 400
23:11:54: ------------------------------------------
23:11:54: Video Encoding: x264
23:11:54: fps: 60
23:11:54: width: 1920, height: 1080
23:11:54: preset: veryfast
23:11:54: profile: main
23:11:54: keyint: 120
23:11:54: CBR: yes
23:11:54: CFR: yes
23:11:54: max bitrate: 2500
23:11:54: buffer size: 2300
23:12:00: SharedTexCapture hooked
