19:00:12: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
19:00:12: -------------------------------
19:00:12: CPU Name: AMD Phenom(tm) II X4 955 Processor
19:00:12: CPU Speed: 3214MHz
19:00:12: Physical Memory: 4095MB Total, 4095MB Free
19:00:12: stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
19:00:12: monitor 1: pos={0, 0}, size={1680, 1050}
19:00:12: Windows Version: 6.1 Build 7601 S
19:00:12: Aero is Enabled
19:00:12: OBS Modules:
19:00:12: Base Address Module
19:00:12: 00260000 OBS.exe
19:00:12: 6A870000 OBSApi.dll
19:00:12: 71B40000 DShowPlugin.dll
19:00:12: 71800000 GraphicsCapture.dll
19:00:12: 717E0000 NoiseGate.dll
19:00:12: ------------------------------------------
19:00:12: Adapter 1
19:00:12: Video Adapter: NVIDIA GeForce GTX 560 Ti
19:00:12: Video Adapter Dedicated Video Memory: 1025966080
19:00:12: Video Adapter Shared System Memory: 3221106688
19:00:12: =====Stream Start: 2013-05-17, 19:00:12===============================================
19:00:12: Multithreaded optimizations: On
19:00:12: Base resolution: 1680x1050
19:00:12: Output resolution: 1680x1050
19:00:12: Loading up D3D10...
19:00:12: Playback device {0.0.0.00000000}.{e9af3379-dc46-4e71-9c82-17529566f8d1}
19:00:12: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
19:00:12: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
19:00:12: Audio Encoding: AAC
19:00:12: bitrate: 128
19:00:12: Using graphics capture
19:00:12: Video Encoding: x264
19:00:12: fps: 40
19:00:12: width: 1680, height: 1050
19:00:12: preset: veryfast
19:00:12: CBR: yes
19:00:12: CFR: no
19:00:12: max bitrate: 3200
19:00:18: Total frames rendered: 211, number of frames that lagged: 1 (0.47%) (it's okay for some frames to lag)
19:00:18: =====Stream End: 2013-05-17, 19:00:18=================================================
19:00:22: =====Stream Start: 2013-05-17, 19:00:22===============================================
19:00:22: Multithreaded optimizations: On
19:00:22: Base resolution: 1680x1050
19:00:22: Output resolution: 1680x1050
19:00:22: ------------------------------------------
19:00:22: Loading up D3D10...
19:00:22: Playback device {0.0.0.00000000}.{e9af3379-dc46-4e71-9c82-17529566f8d1}
19:00:22: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
19:00:22: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
19:00:22: Audio Encoding: AAC
19:00:22: bitrate: 128
19:00:22: Using graphics capture
19:00:22: Video Encoding: x264
19:00:22: fps: 40
19:00:22: width: 1680, height: 1050
19:00:22: preset: veryfast
19:00:22: CBR: yes
19:00:22: CFR: no
19:00:22: max bitrate: 3200
19:00:22: using memory capture
19:00:34: Total frames rendered: 439, number of frames that lagged: 66 (15.03%) (it's okay for some frames to lag)
19:00:34: =====Stream End: 2013-05-17, 19:00:34=================================================
23:00:05: =====Stream Start: 2013-05-17, 23:00:05===============================================
23:00:05: Multithreaded optimizations: On
23:00:05: Base resolution: 1680x1050
23:00:05: Output resolution: 1680x1050
23:00:05: ------------------------------------------
23:00:05: Loading up D3D10...
23:00:05: Playback device {0.0.0.00000000}.{e9af3379-dc46-4e71-9c82-17529566f8d1}
23:00:05: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
23:00:05: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
23:00:05: Audio Encoding: AAC
23:00:05: bitrate: 128
23:00:05: Using graphics capture
23:00:05: Video Encoding: x264
23:00:05: fps: 30
23:00:05: width: 1680, height: 1050
23:00:05: preset: veryfast
23:00:05: CBR: yes
23:00:05: CFR: no
23:00:05: max bitrate: 3200
23:00:06: Total frames rendered: 34, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
23:00:07: =====Stream End: 2013-05-17, 23:00:07=================================================
23:54:10: =====Stream Start: 2013-05-17, 23:54:10===============================================
23:54:10: Multithreaded optimizations: On
23:54:10: Base resolution: 1680x1050
23:54:10: Output resolution: 1680x1050
23:54:10: ------------------------------------------
23:54:10: Loading up D3D10...
23:54:10: Playback device {0.0.0.00000000}.{e9af3379-dc46-4e71-9c82-17529566f8d1}
23:54:10: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
23:54:10: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
23:54:10: Audio Encoding: AAC
23:54:10: bitrate: 128
23:54:10: Using graphics capture
23:54:10: Video Encoding: x264
23:54:10: fps: 30
23:54:10: width: 1680, height: 1050
23:54:10: preset: veryfast
23:54:10: CBR: yes
23:54:10: CFR: no
23:54:10: max bitrate: 3200
23:54:10: using memory capture
23:54:12: Total frames rendered: 60, number of frames that lagged: 1 (1.67%) (it's okay for some frames to lag)
23:54:12: =====Stream End: 2013-05-17, 23:54:12=================================================
23:54:13: =====Stream Start: 2013-05-17, 23:54:13===============================================
23:54:13: Multithreaded optimizations: On
23:54:13: Base resolution: 1680x1050
23:54:13: Output resolution: 1680x1050
23:54:13: ------------------------------------------
23:54:13: Loading up D3D10...
23:54:13: Playback device {0.0.0.00000000}.{e9af3379-dc46-4e71-9c82-17529566f8d1}
23:54:13: Using desktop audio input: Lautsprecher (VIA High Definition Audio)
23:54:13: Using auxilary audio input: Mikrofon (VIA High Definition Audio)
23:54:13: Audio Encoding: AAC
23:54:13: bitrate: 128
23:54:13: Using graphics capture
23:54:13: Video Encoding: x264
23:54:13: fps: 30
23:54:13: width: 1680, height: 1050
23:54:13: preset: veryfast
23:54:13: CBR: yes
23:54:13: CFR: no
23:54:13: max bitrate: 3200
23:54:13: using memory capture
23:54:14: Using RTMP service: Twitch / Justin.tv
23:54:14: Server selection: rtmp://live-fra.justin.tv/app
23:54:16: SO_SNDBUF was at 8192
23:54:16: SO_SNDBUF is now 65536
23:54:39: Total frames rendered: 609, number of frames that lagged: 61 (10.02%) (it's okay for some frames to lag)
23:54:39: RTMPPublisher::SocketLoop: Aborting due to bStopping
23:54:39: Number of times waited to send: 2, Waited for a total of 8194 bytes
23:54:39: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:54:39: =====Stream End: 2013-05-17, 23:54:39=================================================
23:54:41:
23:54:41: Profiler results:
23:54:41:
23:54:41: ==============================================================
23:54:41: frame - [100%] [avg time: 16.422 ms] [avg calls per frame: 1] [children: 75.3%] [unaccounted: 24.7%]
23:54:41: | scene->Preprocess - [0.0244%] [avg time: 0.004 ms] [avg calls per frame: 1]
23:54:41: | video encoding and uploading - [75.2%] [avg time: 12.356 ms] [avg calls per frame: 1] [children: 74.5%] [unaccounted: 0.755%]
23:54:41: | | CopyResource - [1.11%] [avg time: 0.183 ms] [avg calls per frame: 0]
23:54:41: | | conversion to 4:2:0 - [1.63%] [avg time: 0.268 ms] [avg calls per frame: 0]
23:54:41: | | call to encoder - [71.5%] [avg time: 11.737 ms] [avg calls per frame: 0]
23:54:41: | | sending stuff out - [0.268%] [avg time: 0.044 ms] [avg calls per frame: 0]
23:54:41:
