I've used OBS for almost half a year of my streaming "career" but now suddenly I'm having troubles using the program to stream.
I can start my stream, but the bit rate drops and fluctuates between green and red, causing it to drop frames.
I've tried everything to resolve it, changing Ingest Server, Lowering Bitrate, tried streaming to Hitbox using OBS, and the samething happens so the problem is not twitch, also tried streaming using XSplit and had no problem, constant bitrate.
I will leave here a log of a stream i did for 2h, despite having lag problems.
http://pastebin.com/Nkdsfiut
