TheXploder
After commiting to many tests since seeing problems with my Blue Yeti and livestreaming through OBS, I think I have narrowed down what the problem is but still have no idea what to do. Could be wrong but heck, that is why I am posting here for help.
So here is the problem: I have been having constant problems with using my Blue Yeti when livestreaming through OBS. The issue is that after roughly 15 minutes of streaming, the microphone starts cutting out and then cuts out in its entirety. Sometimes the audio comes back, other times it does not. When it doesn't I can only get it working again by unplugging and plugging in the USB again, but it happens yet again after another 15-30 minutes.
I managed to discover that the cable, driver and microphone are all fine, the problem seems to be OBS. I will attach here my logs from my last test recording where the problem still happened again. Hopefully someone out there can help me out with this or at least point me in the right direction. As stated above, this problem is not caused by the USB, Microphone or Drivers.
