Question / Help Problems with Audio echo
zarex
I'm having a problem with audio when streaming
every time i turn on my Logitech c920 webcam in OBS I get an echo from my voice only, I'm using an Astro A40 headset with the mixamp for a headset. I turned the mic pickup to 0 and muted it for the C920 and also disabled it in my recording so that the only mic that should be active is my astro's.
I also made sure that the mic settings in OBS are set to my Astro headset and not the c920 as well as the logitech settings switched to astro mic.
dodgepong
Administrator
Community Helper
Have you checked the audio settings of the webcam source? Sometimes webcams automatically add their audio to the video capture, and you have to disable it.
