I used to work with 2 USB webcams simultaneously (1xLogitech C922 Pro (primary cam) and 1x Logitech QuickCam Pro 5000 as secondary cam) on my old Mint 19.3 Mate platform with OBS 27.2.4 and I never had any problem with it. On my Mint 20.3 (Cinnamon) I managed to establish the same arrangement with OBS 28.0.1 but sadly after a removal of the QuickCam Pro 5000 (needed somewhere else) and a reboot of the PC the webcams in the scenes where either gone or swapped.
Without the secondary QuickCam Pro 5000 I found this device mapping under /dev/v4l/by-id :
usb-046d_C922_Pro_Stream_Webcam_5CB212DF-video-index0 (mapped to video 0)
usb-046d_C922_Pro_Stream_Webcam_5CB212DF-video-index1 (mapped to video 1)
After I plugged in the QuickCam Pro 5000 and rebooted the PC I got his:
usb-046d_08ce_3C9C41A2-video-index0 (mapped to video0)
usb-046d_08ce_3C9C41A2-video-index1 (is mapped to video1)
usb-046d_C922_Pro_Stream_Webcam_5CB212DF-video-index0 (mapped to video2)
usb-046d_C922_Pro_Stream_Webcam_5CB212DF-video-index1 (is mapped to video3)
That means that the video0/1 – mapping of my primary webcam C922 was shifted to video2/3.
Then I checked the terminal output of OBS and found, that OBS seems to select the webcam by using the video-(n) device.
Does this explain my problem?
Questions:
1. Is OBS ignoring the hardware behind the video-(n) device?
2. If yes, can this be changed (of course only if this makes sense)?
I was assuming since OBS 28 that the hardware behind a video(n) device must be known to OBS in order to support special settings/features of a certain camera type. It seems that this is not the case.
Is there an easy way to set a primary webcam as "default webcam" (video0) in Mint 20.3? Are there other solutions? Is this possibly a bug in OBS?
Best regards
Crapman
Questions:
Best regards
Crapman
