Bug Report Problems capturing GoldSource Engine?
Caribou007
The GoldSource Engine is used in games like Counter-Strike 1.6, Half-Life 1, Day Of Defeat and Team Fortress Classic.
I don't see Direct3D Rendering as an option, only Software and OpenGL. OBS captures a black screen using Game Capture and Window Capture (Compatibility Mode on or off), and Monitor Capture results in a very poor framerate on my computer. My computer isn't very powerful, but it still seems like something is wrong.
dodgepong
Administrator
Community Helper
Direct3D is no longer an option with GoldSrc games as of an engine update in February. You can use OpenGL just fine instead, and Game Capture should work with that. I was able to capture CS 1.6 perfectly well in OpenGL mode.
Caribou007
Thanks for the reply. I just tried again, and now it works. It's odd. Before I posted here, I googled to try to find a solution, and found a topic where the exact same thing happened to someone else. It wouldn't work, then they tried again a few days later, and somehow, then it worked.
