Question / Help Problem withe OBS (Open Broadcaster Software) FPS setting
kademin
i just partition my hd and installed windows 7 64 it, for main purpose to stream from it. (fresh install. list of all software that's been installed 1.all windows updates, 2.chrome, 3.directx 9, 4.easeus partition master 9.2.2, 5.KMPlayer, 6.revo uninstaller, 7.OBS. that's it nothing els ). so i started obs changed settings to
Encoding:
Quality Balance – 9/10
Max Bitrate (kb/s) – 3000 (i have Comcast 10 up 50 down. lol more like 6 down 38 up according to http://testmy.net/)
Audio Encoding: default
Broadcast Settings: default
Video:
Base Resolution - 1037 x 788 (i need this to be in this rang +, - 10 Pix)
Resolution Downscale - 1037 x 788
FPS – 30 FPS
Audio: default
Advanced: default (except these ↓ )
Use Multithreaded Optimizations - High
x264 cpu Preset - veryfast
OK when i Adding a Screen Region i use this ↓ but my position and size is different
my is
Position 0, 0,
size 1037, 788,
so now that we now how i have it set up. lets look in to the problem. every time i try to cast my idle FPS is 20-25 (no mater on what x264 cpu Preset i use or how high i set FPS)
and when play a video or play BOI my FPS drops to 7-10
i have
CPU X6800 @2.93 OR overclocked to 3.5
RAM 4 GB
NVIDIA 8600GT (latest Drivers )
OS 64-bit
if i did't know any better i would say that my system is to week but like i sad this is a second partition on this HD. my firs one has same copy of windows but with bunch of other !@#$%^& installed and OBS on this one works just fine 30+ fps on Fast : x264 cpu Preset setting. Why it's being stupid on this one is beyond me.
i also trade reinstalling OBS, use test build, and deleting Config Folder (so it resets completely ) no luck.
Krazy
Town drunk
Re: Problem withe OBS (Open Broadcaster Software) FPS settin
Disable Aero if you absolutely must use Monitor Capture on windows 7. Make sure "Disable Aero at startup" is checked in settings>video
But really, avoid Monitor Capture at all costs on Windows 7.
R1CH
Forum Admin
Developer
That looks like a very old version of OBS, you should also update.
kademin
no this is the newest version the screen shot is no of my system and like i sad i'v used test build. Both of OSs have there performance setting set to Performance so all Aero nonsense is disabled by default .i also tried using aVHscrCap as alternative to build in one and it did not helped one bit.
also it stays the same even if you tell it to capture the hole window. and Thank you fore fast replays
kademin
21:29:25: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
21:29:25: -------------------------------
21:29:25: CPU Name: Intel(R) Core(TM)2 CPU X6800 @ 2.93GHz
21:29:25: CPU Speed: 3300MHz
21:29:25: Physical Memory: 4094MB Total, 2425MB Free
21:29:25: stepping id: 6, model 15, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 2, total cores 2
21:29:25: monitor 1: pos={0, 0}, size={1280, 1024}
21:29:25: monitor 2: pos={1280, 0}, size={1280, 1024}
21:29:25: Windows Version: 6.1 Build 7601 S
21:29:25: Aero is Disabled
21:29:25: OBS Modules:
21:29:25: Base Address Module
21:29:25: 01330000 OBS.exe
21:29:25: 73430000 OBSApi.dll
21:29:25: 73C70000 DShowPlugin.dll
21:29:25: 73CB0000 GraphicsCapture.dll
21:29:25: 738F0000 NoiseGate.dll
21:29:25: 73920000 PSVPlugin.dll
21:29:25: ------------------------------------------
21:29:25: Adapter 1
21:29:25: Video Adapter: NVIDIA GeForce 8600 GT
21:29:25: Video Adapter Dedicated Video Memory: 519634944
21:29:25: Video Adapter Shared System Memory: 1878257664
21:29:25: =====Stream Start: 2013-07-22, 21:29:25===============================================
21:29:25: Multithreaded optimizations: On
21:29:25: Base resolution: 1037x778
21:29:25: Output resolution: 1036x778
21:29:25: Loading up D3D10...
21:29:25: Playback device Default
21:29:25: Using desktop audio input: Digital Audio (S/PDIF) (High Definition Audio Device)
21:29:25: Using auxilary audio input: Digital Audio (S/PDIF) (High Definition Audio Device)
21:29:25: Audio Encoding: AAC
21:29:25: bitrate: 128
21:29:25: Using Monitor Capture
21:29:25: Video Encoding: x264
21:29:25: fps: 30
21:29:25: width: 1036, height: 778
21:29:25: preset: veryfast
21:29:25: CBR: yes
21:29:25: CFR: no
21:29:25: max bitrate: 3000
21:29:37: Total frames rendered: 219, number of frames that lagged: 210 (95.89%) (it's okay for some frames to lag)
21:29:38: =====Stream End: 2013-07-22, 21:29:38=================================================
21:29:49: =====Stream Start: 2013-07-22, 21:29:49===============================================
21:29:49: Multithreaded optimizations: On
21:29:49: Base resolution: 1037x778
21:29:49: Output resolution: 1036x778
21:29:49: ------------------------------------------
21:29:49: Loading up D3D10...
21:29:49: Playback device Default
21:29:49: Using desktop audio input: Digital Audio (S/PDIF) (High Definition Audio Device)
21:29:49: Using auxilary audio input: Digital Audio (S/PDIF) (High Definition Audio Device)
21:29:49: Audio Encoding: AAC
21:29:49: bitrate: 128
21:29:49: Using Monitor Capture
21:29:49: Video Encoding: x264
21:29:49: fps: 30
21:29:49: width: 1036, height: 778
21:29:49: preset: veryfast
21:29:49: CBR: yes
21:29:49: CFR: no
21:29:49: max bitrate: 3000
21:29:51: Total frames rendered: 33, number of frames that lagged: 20 (60.61%) (it's okay for some frames to lag)
21:29:51: =====Stream End: 2013-07-22, 21:29:51=================================================
21:31:34:
21:31:34: Profiler results:
21:31:34:
21:31:34: ==============================================================
21:31:34: frame - [100%] [avg time: 54.819 ms (cpu time: avg 14.052 ms, total 3541.22 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.00912%]
21:31:34: | frame preprocessing and rendering - [26.5%] [avg time: 14.531 ms (cpu time: avg 6.438 ms, total 1622.41 ms)] [avg calls per frame: 1] [children: 24.7%] [unaccounted: 1.8%]
21:31:34: | | scene->Preprocess - [24.7%] [avg time: 13.544 ms (cpu time: avg 5.571 ms, total 1404.01 ms)] [avg calls per frame: 1]
21:31:34: | video encoding and uploading - [73.5%] [avg time: 40.283 ms (cpu time: avg 7.614 ms, total 1918.81 ms)] [avg calls per frame: 1] [children: 73.4%] [unaccounted: 0.131%]
21:31:34: | | flush - [0.655%] [avg time: 0.359 ms (cpu time: avg 0.247 ms, total 62.4 ms)] [avg calls per frame: 1]
21:31:34: | | CopyResource - [68.4%] [avg time: 37.474 ms (cpu time: avg 5.385 ms, total 1357.21 ms)] [avg calls per frame: 0]
21:31:34: | | conversion to 4:2:0 - [0.104%] [avg time: 0.057 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:31:34: | | call to encoder - [4.23%] [avg time: 2.319 ms (cpu time: avg 1.98 ms, total 499.202 ms)] [avg calls per frame: 0]
21:31:34: | | sending stuff out - [0.00365%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
21:31:34: | Convert444Threads - [96.3%] [avg time: 52.791 ms (cpu time: avg 1.3 ms, total 327.601 ms)] [avg calls per frame: 0]
21:31:34:
FerretBomb
Really, the Monitor Capture is likely *the* cause. It's the worst of all the capture methods, and should not be used if at all possible, because it delivers HORRIBLE performance and can even lag your game.
Delete it and switch to Game Capture, or Window Capture with aero ON if at all possible (not just 'capture whole window', DELETE the Monitor Capture and add a Window Capture instead). Otherwise, may just have to deal with the poor framerate.
kademin
god damn it iv tried all that all ready. and thank you for tying. im going to install ffdshow and customize the hall out of it like i did on the other partition. i'm not shore if this should effected in any way? if some one can confer it, I dont feel like wasting to much time on this. it a lot of work now that i think about it.
i just remembered that i probably have an older version of OBS on the working partition. i'm going to try to get the same version and let you know if this works
Krazy
Town drunk
Your GPU is a gigantic bottleneck here, and pretty much nothing you do is going to be able to get around that.
kademin
no but its working fine on the other partition. this is why in tying so hard , it doesn't make any sense. and i can't cast from the other one because it has antivirus and other heavy cpu programs.
