Simon Theodor Singer
Hi all,
let me explain my setup and what I want to do:
PC 1 / Win10 (IP: 192.168.1.114):
I thought, couldn't be so hard ... but:
I want any PC with VLC in my network (PC2 - PC n) to be able to watch the live stream from OBS.
I would prefer the solution without the rtmp server, which is PC1 (OBS) <-> PC2 (VLC player)
But could anyone enlighten me, what are the advantages and the disadvantages of:
BTW:
Windows firewall are OFF on both PCs.
I did not find posts or something on Google, that would help me for my specific setup,
maybe because I have a different understanding of how things (should) work,
or just because I am using the wrong terms.
Would appreciate, if somebody could point me into the right direction.
Thanks.
Regards,
OBS installed, with many sources, works like a charm =)
PC 2 / Win10 (IP: 192.168.1.113): VLC Installed, but can not view stream from OBS, because I don't know the URL, Protocol and port.
What I want is to make PCs in my network able to view the "live/mixed output, result" of OBS.I thought, couldn't be so hard ... but:
- What I understood is, that I need an rtpM server, so that I can view OBS stream with VLC player from that rtMp server which is "filled" from OBS.
- But I also read the article, the title was analogously " ... OBS Stream from one to another pc ..." where you can record and then watch with VLC
I followed this tutorial, but VLC player seemed to play, but the screeen was black.
- Viewing stream with VLC player from rtmp Server PC1 (OSB) -> PC ? (RTMP SRV) <- PC2 (VLC player)
- Viewing with Vlc, by not starting stream in OBS, but starting recording.
BTW:
Thanks.
Regards,
