Question / Help Problem with stream fps
UnluckyBabua
Hi all,
I have some problem with my streaming, I tried to stream fortnite but my stream wasn't smooth at all.. I had a lot of fps drop and stuttering..
My pc:
Ryzen R7 1700
16gb ram 3000mhz g skill ripjaws v
gtx 1060 6gb gainward
My obs settings:
output res: 1280x720 (I tried with 3 different res)
downscale filter: lanczos
fps: 60
format: nv122
Bitrate 4000 CBR
I also tried to check the task manager during my streaming and cpu was at 50%~, ram same and the gpu was around 98%
My last log: https://gist.github.com/7a898f987323dc1daa1654ee57e6fbbd
sorry for my englando D:
I also tried to stream in 720p (look at my actual resolution, it's 1280x720)
From what I saw in the log I saw that your output was on 1080p though? So I don't know if its a wrong log, or I am perhaps just blind as a bat.
Perhaps turning settings down in the game? Try changing the resolution in game, see if that works? Or maybe something to do with Vsync? Are you on 60hz or 144hz?
EDIT: I see what happened, the first time it was 1080, then you changed it. I reacted to this quite tired so didn't see that, sorry.
