Wolfbane
Im having problems with my sound atm.
When I stream, the mic works, but the sound from winamp is not played to the veiwers.
I only have one soundcard, and I do not use the motherboard soundcard.
I only have one outgoing from my computer to my reciver, from that reciver I plugin my headphone in the reciver.
So Im 100% sure the music is playing, since I hear it myself and see the equalziers graphs moving.
I use Winamp to play music, but I tested differnt programs, so same was when I tested VLC. I hear music but the veiwers dont.
Then I went to you-tube to try if that worked, and yes, the audio from you-tube goes to the viewers. So more and less it seems to be some kind of wrong settings. And Im not refering to setting wrong on OBS, more a setting wrong in windows. (Windows 7)
I did install "Hexchat" and in the last installing thing it askes if I want to install plugins, and one of them was some audi plugin, I think it was after this that the problem occured. But I do not know for sure.
Is there anyone who are good at these things, I really appreciate the help.
