Question / Help Problem with sound during livestream
Aurenqt
Hi guys, it's since a while that i'm streaming, and recently i've decided to use Skype too during it. But here comes the problem..Somehow there is a noize during my whole stream; and for my low experience with OBS i've no idea of how remove that background noize.
For be more detailed, here there is my last livestream with that noize:
http://www.twitch.tv/aurenqt/b/468524163
Hoping to find a solution of this, thanks in advice :)
Best Regards
Lain
Forum Admin
Lain
Forum Moderator
Developer
It's from the mic - do you have your mic plugged into the back of your computer or something? It sounds like general interference (though quite bad admittedly)
Aurenqt
Actually i've my headset plugged to the back with my computer, with an USB cable that connect mic/head together in the same UBS slot
Lain
Forum Admin
Lain
Forum Moderator
Developer
Hm, USB devices shouldn't usually do this, sounds like a motherboard quirk. Have you tried swapping it to a different port, or doing it with the other devices? That can sometimes help. (also if possible update your motherboard drivers, that can also somewhat rarely help out)
