Question / Help Problem with repeated audio
Well folks, I have the following problem I will give all the details how it is configured my audio here at OBS, he keeps repeating the audio, and the only solution I found was to disable the sound, which is on the main window of OBS, but the problem now I can not send the sound of the game because if I enable it starts with the audio problem repeated.
log file after a long test:
13:41:06: device: Microsoft LifeCam HD-5000,
13:41:06: device id \\?\usb#vid_045e&pid_076d&mi_00#6&168eb145&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
13:41:06: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-666666
13:41:06: use buffering: false - 0, fourCC: 'YUY2'
13:41:06: audio device: Microfone (4- Sennheiser 3D G4ME1),
13:41:06: audio device id (null),
13:41:06: audio time offset 0,
13:41:06:
13:41:06: device audio info - bits per sample: 16, channels: 2, samples per sec: 44100, block size: 4
13:41:06: Using directshow input
13:41:06: PERFORMANCE WARNING: Scene change took 584 ms, maybe some sources should be global sources?
below has some pictures the first is how it's picking up audio without repeating all the time, then it's like he is repeating, and the third as ta set up the webcam.
