I am FL Studio 21 user and recently I strarted recording my projects with OBS. Since I have an external audio card (Focusrite Scarlett 8i6), I use a plugin called Voxengo Recorder that sends audio to a free driver so I can record without using ASIO.
Everything worked just fine even on default settings, quality of video was great, there were no lags until I needed to record just a bass part, when I opened the recorded video there were obvious pops and clicks in the higher frequencies. I experimented with formats and found out that mkv/AMD HW H.265/FFmpeg FLAC formats are working just fine for me, accept... the video quality is just awful now. Also when I switch to AMD HW H.264 my gpu loads at 100% and skipped frames due to encoding lag is like 60%, on H.265 it is 0%. Files, recorded with other audio/video encoding formats either not opening at all, or have no sound.
Would be grateful if you suggest any solutions.
Thanks in advance!
Thanks in advance!
