Bug Report Problem with Paragon and OBS Studio
Vole
I will upload a video later which makes this issue more clear and shows the problem with OBS Studio.
Basically if I launch Paragon and use Game Capture Mode in the OBS Screen I can see the game's loading screen. It also seems to work fine as long as I am in the menu.
But once I start looking for players and a match OBS will only display the "looking for players search bar" and once all players have been found OBS will display the "ready-up bar". This image will freeze in OBS and even when I am in the draft mode or in the game/match afterwards, OBS won't display it.
Do you guys have any solution for this? I imagine the old OBS is working with Paragon, since I know some streamers which do use some kind of OBS with Paragon. But I cannot get Paragon and OBS Studio to work together.
Sure I can use window capture or screen capture. But I would really love to use game capture mode and it should be working somehow.
Kind regards
Vole
PS: Running Windows 10. nVidia GTX 960.
xDevlinx21
I get the same issue. I mean I use Monitor Capture but honestly that's my least favorite and last resort to capture something. I always prefer Window Capture whenever possible but with Paragon sadly that's not the case. I hope this can get fixed soon.
EDIT: Running Windows 10 Pro and a GTX 970.
Must2Dont
Window capture is not an option, because when you Alt+Tab - windows program bar (that one with start button) pops on top of Paragon window and spoils broadcast =(
Vole
hey guys. i switched over to xsplit recently since i can only get the stream to work with that one. sad they didnt fix it yet on obs studio.
