Hello I have a problem in my OBS, he does not go out of 0 kbps in transmission on twitch.tv, however when I go to the Youtube livestream works normally. I would like a solution Please. (sorry English of errors, I am using Google Translator)
http://www.imgur.com/jiHay6n (Screen with Problem)
Edit @@@
my last Log
Edit @@@
my last Log
12:30:41: Open Broadcaster Software v0.571b - 32bit (´・ω・`)
12:30:41: -------------------------------
12:30:41: CPU Name: Intel(R) Core(TM) i5-2310 CPU @ 2.90GHz
12:30:41: CPU Speed: 2987MHz
12:30:41: Physical Memory: 4095MB Total, 4095MB Free
12:30:41: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
12:30:41: monitor 1: pos={0, 0}, size={1920, 1080}
12:30:41: Windows Version: 6.1 Build 7601 S
12:30:41: Aero is Disabled
12:30:41: OBS Modules:
12:30:41: Base Address Module
12:30:41: 009B0000 OBS.exe
12:30:41: 6C140000 OBSApi.dll
12:30:41: 743B0000 DShowPlugin.dll
12:30:41: 720B0000 GraphicsCapture.dll
12:30:41: 733F0000 NoiseGate.dll
12:30:41: 72090000 PSVPlugin.dll
12:30:41: ------------------------------------------
12:30:41: Adapter 1
12:30:41: Video Adapter: AMD Radeon HD 7800 Series
12:30:41: Video Adapter Dedicated Video Memory: 2128814080
12:30:41: Video Adapter Shared System Memory: 2166087680
12:30:41: =====Stream Start: 2013-09-30, 12:30:41===============================================
12:30:41: Multithreaded optimizations: On
12:30:41: Base resolution: 1920x1080
12:30:41: Output resolution: 640x360
12:30:41: Loading up D3D10 on AMD Radeon HD 7800 Series...
12:30:41: Audio Format: 48000hz
12:30:41: Playback device {0.0.0.00000000}.{29409af7-f163-4e27-bfbd-ad02edd2d07c}
12:30:41: Using desktop audio input: Alto-falantes (Turtle Beach COD EFF Headset)
12:30:41: Using auxilary audio input: Microfone (Turtle Beach COD EFF Headset)
12:30:41: Audio Encoding: AAC
12:30:41: bitrate: 128
12:30:41: Using Monitor Capture
12:30:41: Video Encoding: x264
12:30:41: fps: 30
12:30:41: width: 640, height: 360
12:30:41: preset: veryfast
12:30:41: profile: high
12:30:41: keyint: 60
12:30:41: CBR: yes
12:30:41: CFR: no
12:30:41: max bitrate: 1200
12:30:41: buffer size: 1200
12:30:41: MMDeviceAudioSource: Frequency for device 'Alto-falantes (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:30:41: MMDeviceAudioSource: Frequency for device 'Microfone (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:30:43: Using RTMP service: Twitch / Justin.tv
12:30:43: Server selection: rtmp://live.justin.tv/app
12:30:43: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
12:30:44: Completed handshake with rtmp://live.justin.tv/app in 640 ms.
12:30:46: SO_SNDBUF was at 8192
12:30:46: SO_SNDBUF is now 65536
12:30:51: RTMPPublisher::SendLoop: Stalled for 4175 ms to write 169306 bytes (buffer: 0 / 169984), unstable connection?
12:31:01: RTMPPublisher::SendLoop: Stalled for 8805 ms to write 168181 bytes (buffer: 0 / 169984), unstable connection?
12:31:01: Total frames encoded: 592, total frames duplicated: 29 (4.90%)
12:31:01: Total frames rendered: 596, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:31:07: RTMPPublisher::SendLoop: Stalled for 6232 ms to write 169388 bytes (buffer: 0 / 169984), unstable connection?
12:31:14: RTMPPublisher::SendLoop: Stalled for 6379 ms to write 169806 bytes (buffer: 0 / 169984), unstable connection?
12:31:21: RTMPPublisher::SendLoop: Stalled for 7546 ms to write 91505 bytes (buffer: 0 / 169984), unstable connection?
12:31:21: RTMPPublisher::SocketLoop: Graceful loop exit
12:31:37: Average send payload: 101392 bytes, average send interval: 3416 ms
12:31:37: Number of times waited to send: 7, Waited for a total of 26445 bytes
12:31:37: Number of b-frames dropped: 146 (33%), Number of p-frames dropped: 149 (34%), Total 295 (67%)
12:31:37: Number of bytes sent: 1013924
12:31:37:
12:31:37: Profiler time results:
12:31:37:
12:31:37: ==============================================================
12:31:37: video thread frame - [100%] [avg time: 7.544 ms] [children: 76.9%] [unaccounted: 23.1%]
12:31:37: | scene->Preprocess - [76.9%] [avg time: 5.803 ms]
12:31:37: GPU download and conversion - [100%] [avg time: 0.2 ms] [children: 85.5%] [unaccounted: 14.5%]
12:31:37: | flush - [77%] [avg time: 0.154 ms]
12:31:37: | CopyResource - [6.5%] [avg time: 0.013 ms]
12:31:37: | conversion to 4:2:0 - [2%] [avg time: 0.004 ms]
12:31:37: Convert444Threads - [100%] [avg time: 0.155 ms] [children: 96.1%] [unaccounted: 3.87%]
12:31:37: | Convert444toNV12 - [96.1%] [avg time: 0.149 ms]
12:31:37: encoder thread frame - [100%] [avg time: 0.475 ms]
12:31:37:
12:31:37:
12:31:37: Profiler CPU results:
12:31:37:
12:31:37: video thread frame - [cpu time: avg 5.156 ms, total 3073.22 ms] [avg calls per frame: 1]
12:31:37: | scene->Preprocess - [cpu time: avg 4.24 ms, total 2527.22 ms] [avg calls per frame: 1]
12:31:37: GPU download and conversion - [cpu time: avg 0.026 ms, total 15.6 ms] [avg calls per frame: 1]
12:31:37: | flush - [cpu time: avg 0.026 ms, total 15.6 ms] [avg calls per frame: 1]
12:31:37: | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:31:37: | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:31:37: Convert444Threads - [cpu time: avg 0.12 ms, total 140.4 ms] [avg calls per frame: 2]
12:31:37: | Convert444toNV12 - [cpu time: avg 0.12 ms, total 140.4 ms] [avg calls per frame: 2]
12:31:37: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:31:37:
12:31:37: =====Stream End: 2013-09-30, 12:31:37=================================================
12:35:46: =====Stream Start: 2013-09-30, 12:35:46===============================================
12:35:46: Multithreaded optimizations: On
12:35:46: Base resolution: 1920x1080
12:35:46: Output resolution: 640x360
12:35:46: ------------------------------------------
12:35:46: Loading up D3D10 on AMD Radeon HD 7800 Series...
12:35:46: Audio Format: 48000hz
12:35:46: Playback device {0.0.0.00000000}.{29409af7-f163-4e27-bfbd-ad02edd2d07c}
12:35:46: Using desktop audio input: Alto-falantes (Turtle Beach COD EFF Headset)
12:35:46: Using auxilary audio input: Microfone (Turtle Beach COD EFF Headset)
12:35:46: Audio Encoding: AAC
12:35:46: bitrate: 128
12:35:47: Using Monitor Capture
12:35:47: ------------------------------------------
12:35:47: Video Encoding: x264
12:35:47: fps: 30
12:35:47: width: 640, height: 360
12:35:47: preset: veryfast
12:35:47: profile: high
12:35:47: keyint: 60
12:35:47: CBR: yes
12:35:47: CFR: no
12:35:47: max bitrate: 1200
12:35:47: buffer size: 1200
12:35:47: MMDeviceAudioSource: Frequency for device 'Alto-falantes (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:35:47: MMDeviceAudioSource: Frequency for device 'Microfone (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:35:48: Using RTMP service: Twitch / Justin.tv
12:35:48: Server selection: rtmp://live.justin.tv/app
12:35:48: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
12:35:49: Completed handshake with rtmp://live.justin.tv/app in 579 ms.
12:35:51: SO_SNDBUF was at 8192
12:35:51: SO_SNDBUF is now 65536
12:35:58: RTMPPublisher::SendLoop: Stalled for 5472 ms to write 167688 bytes (buffer: 0 / 169984), unstable connection?
12:36:00: RTMPPublisher::SendLoop: Stalled for 2245 ms to write 168630 bytes (buffer: 0 / 169984), unstable connection?
12:36:08: RTMPPublisher::SendLoop: Stalled for 7770 ms to write 167158 bytes (buffer: 0 / 169984), unstable connection?
12:36:15: RTMPPublisher::SendLoop: Stalled for 7494 ms to write 166097 bytes (buffer: 0 / 169984), unstable connection?
12:36:24: RTMPPublisher::SendLoop: Stalled for 8309 ms to write 167366 bytes (buffer: 0 / 169984), unstable connection?
12:36:29: Total frames encoded: 1264, total frames duplicated: 61 (4.83%)
12:36:29: Total frames rendered: 1269, number of late frames: 1 (0.08%) (it's okay for some frames to be late)
12:36:30: RTMPPublisher::SendLoop: Stalled for 5925 ms to write 168253 bytes (buffer: 0 / 169984), unstable connection?
12:36:38: RTMPPublisher::SendLoop: Stalled for 7986 ms to write 166061 bytes (buffer: 0 / 169984), unstable connection?
12:36:42: RTMPPublisher::SendLoop: Stalled for 4663 ms to write 167363 bytes (buffer: 0 / 169984), unstable connection?
12:36:49: RTMPPublisher::SendLoop: Stalled for 6355 ms to write 169564 bytes (buffer: 0 / 169984), unstable connection?
12:36:54: RTMPPublisher::SendLoop: Stalled for 5214 ms to write 168918 bytes (buffer: 0 / 169984), unstable connection?
12:37:02: RTMPPublisher::SendLoop: Stalled for 7881 ms to write 166726 bytes (buffer: 0 / 169984), unstable connection?
12:37:08: RTMPPublisher::SendLoop: Stalled for 6177 ms to write 168303 bytes (buffer: 0 / 169984), unstable connection?
12:37:16: RTMPPublisher::SendLoop: Stalled for 8426 ms to write 169308 bytes (buffer: 0 / 169984), unstable connection?
12:37:23: RTMPPublisher::SendLoop: Stalled for 6282 ms to write 164655 bytes (buffer: 0 / 169984), unstable connection?
12:37:23: RTMPPublisher::SocketLoop: Graceful loop exit
12:37:36: Average send payload: 122532 bytes, average send interval: 4514 ms
12:37:36: Number of times waited to send: 15, Waited for a total of 61496 bytes
12:37:36: Number of b-frames dropped: 403 (36%), Number of p-frames dropped: 440 (40%), Total 843 (76%)
12:37:36: Number of bytes sent: 2450643
12:37:37:
12:37:37: Profiler time results:
12:37:37:
12:37:37: ==============================================================
12:37:37: video thread frame - [100%] [avg time: 6.436 ms] [children: 75.8%] [unaccounted: 24.2%]
12:37:37: | scene->Preprocess - [75.8%] [avg time: 4.879 ms]
12:37:37: GPU download and conversion - [100%] [avg time: 0.182 ms] [children: 89%] [unaccounted: 11%]
12:37:37: | flush - [78%] [avg time: 0.142 ms]
12:37:37: | CopyResource - [6.59%] [avg time: 0.012 ms]
12:37:37: | conversion to 4:2:0 - [4.4%] [avg time: 0.008 ms]
12:37:37: Convert444Threads - [100%] [avg time: 0.152 ms] [children: 96.1%] [unaccounted: 3.95%]
12:37:37: | Convert444toNV12 - [96.1%] [avg time: 0.146 ms]
12:37:37: encoder thread frame - [100%] [avg time: 0.441 ms]
12:37:37:
12:37:37:
12:37:37: Profiler CPU results:
12:37:37:
12:37:37: video thread frame - [cpu time: avg 4.757 ms, total 6037.24 ms] [avg calls per frame: 1]
12:37:37: | scene->Preprocess - [cpu time: avg 3.896 ms, total 4945.23 ms] [avg calls per frame: 1]
12:37:37: GPU download and conversion - [cpu time: avg 0.098 ms, total 124.8 ms] [avg calls per frame: 1]
12:37:37: | flush - [cpu time: avg 0.061 ms, total 78 ms] [avg calls per frame: 1]
12:37:37: | CopyResource - [cpu time: avg 0.024 ms, total 31.2 ms] [avg calls per frame: 1]
12:37:37: | conversion to 4:2:0 - [cpu time: avg 0.012 ms, total 15.6 ms] [avg calls per frame: 1]
12:37:37: Convert444Threads - [cpu time: avg 0.093 ms, total 234 ms] [avg calls per frame: 2]
12:37:37: | Convert444toNV12 - [cpu time: avg 0.087 ms, total 218.4 ms] [avg calls per frame: 2]
12:37:37: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:37:37:
12:37:37: =====Stream End: 2013-09-30, 12:37:37=================================================
12:38:45: =====Stream Start: 2013-09-30, 12:38:45===============================================
12:38:45: Multithreaded optimizations: On
12:38:45: Base resolution: 1920x1080
12:38:45: Output resolution: 640x360
12:38:45: ------------------------------------------
12:38:45: Loading up D3D10 on AMD Radeon HD 7800 Series...
12:38:45: Audio Format: 48000hz
12:38:45: Playback device {0.0.0.00000000}.{29409af7-f163-4e27-bfbd-ad02edd2d07c}
12:38:45: Using desktop audio input: Alto-falantes (Turtle Beach COD EFF Headset)
12:38:45: Using auxilary audio input: Microfone (Turtle Beach COD EFF Headset)
12:38:45: Audio Encoding: AAC
12:38:45: bitrate: 128
12:38:45: Using Monitor Capture
12:38:45: Video Encoding: x264
12:38:45: fps: 30
12:38:45: width: 640, height: 360
12:38:45: preset: veryfast
12:38:45: profile: high
12:38:45: keyint: 60
12:38:45: CBR: yes
12:38:45: CFR: no
12:38:45: max bitrate: 1200
12:38:45: buffer size: 1200
12:38:45: MMDeviceAudioSource: Frequency for device 'Alto-falantes (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:38:45: MMDeviceAudioSource: Frequency for device 'Microfone (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:38:47: Using RTMP service: Twitch / Justin.tv
12:38:47: Server selection: rtmp://live.justin.tv/app
12:38:47: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
12:38:48: Completed handshake with rtmp://live.justin.tv/app in 1593 ms.
12:38:52: SO_SNDBUF was at 8192
12:38:52: SO_SNDBUF is now 65536
12:38:58: RTMPPublisher::SendLoop: Stalled for 4742 ms to write 169443 bytes (buffer: 0 / 169984), unstable connection?
12:39:07: RTMPPublisher::SendLoop: Stalled for 8495 ms to write 166332 bytes (buffer: 0 / 169984), unstable connection?
12:39:14: Total frames encoded: 851, total frames duplicated: 42 (4.94%)
12:39:14: Total frames rendered: 857, number of late frames: 1 (0.12%) (it's okay for some frames to be late)
12:39:14: RTMPPublisher::SendLoop: Stalled for 6746 ms to write 169547 bytes (buffer: 0 / 169984), unstable connection?
12:39:22: RTMPPublisher::SendLoop: Stalled for 7701 ms to write 168787 bytes (buffer: 0 / 169984), unstable connection?
12:39:28: RTMPPublisher::SendLoop: Stalled for 5793 ms to write 169601 bytes (buffer: 0 / 169984), unstable connection?
12:39:35: RTMPPublisher::SendLoop: Stalled for 7348 ms to write 167721 bytes (buffer: 0 / 169984), unstable connection?
12:39:41: RTMPPublisher::SendLoop: Stalled for 5543 ms to write 166589 bytes (buffer: 0 / 169984), unstable connection?
12:39:47: RTMPPublisher::SendLoop: Stalled for 6276 ms to write 169930 bytes (buffer: 0 / 169984), unstable connection?
12:39:54: RTMPPublisher::SendLoop: Stalled for 7045 ms to write 169205 bytes (buffer: 0 / 169984), unstable connection?
12:40:03: RTMPPublisher::SendLoop: Stalled for 9311 ms to write 169302 bytes (buffer: 0 / 169984), unstable connection?
12:40:12: RTMPPublisher::SendLoop: Stalled for 8421 ms to write 25062 bytes (buffer: 0 / 169984), unstable connection?
12:40:12: RTMPPublisher::SocketLoop: Graceful loop exit
12:40:22: Average send payload: 77861 bytes, average send interval: 3142 ms
12:40:22: Number of times waited to send: 13, Waited for a total of 44470 bytes
12:40:22: Number of b-frames dropped: 164 (26%), Number of p-frames dropped: 175 (27%), Total 339 (53%)
12:40:22: Number of bytes sent: 1946538
12:40:22:
12:40:22: Profiler time results:
12:40:22:
12:40:22: ==============================================================
12:40:22: video thread frame - [100%] [avg time: 8.689 ms] [children: 82.8%] [unaccounted: 17.2%]
12:40:22: | scene->Preprocess - [82.8%] [avg time: 7.193 ms]
12:40:22: GPU download and conversion - [100%] [avg time: 0.171 ms] [children: 73.7%] [unaccounted: 26.3%]
12:40:22: | flush - [60.8%] [avg time: 0.104 ms]
12:40:22: | CopyResource - [6.43%] [avg time: 0.011 ms]
12:40:22: | conversion to 4:2:0 - [6.43%] [avg time: 0.011 ms]
12:40:22: Convert444Threads - [100%] [avg time: 0.143 ms] [children: 96.5%] [unaccounted: 3.5%]
12:40:22: | Convert444toNV12 - [96.5%] [avg time: 0.138 ms]
12:40:22: encoder thread frame - [100%] [avg time: 0.411 ms]
12:40:22:
12:40:22:
12:40:22: Profiler CPU results:
12:40:22:
12:40:22: video thread frame - [cpu time: avg 4.277 ms, total 3666.02 ms] [avg calls per frame: 1]
12:40:22: | scene->Preprocess - [cpu time: avg 3.567 ms, total 3057.62 ms] [avg calls per frame: 1]
12:40:22: GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:40:22: | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:40:22: | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:40:22: | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:40:22: Convert444Threads - [cpu time: avg 0.083 ms, total 140.4 ms] [avg calls per frame: 2]
12:40:22: | Convert444toNV12 - [cpu time: avg 0.083 ms, total 140.4 ms] [avg calls per frame: 2]
12:40:22: encoder thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:40:22:
12:40:22: =====Stream End: 2013-09-30, 12:40:22=================================================
12:41:04: Settings::Video: Disabling Aero
12:41:11: =====Stream Start: 2013-09-30, 12:41:11===============================================
12:41:11: Multithreaded optimizations: On
12:41:11: Base resolution: 1920x1080
12:41:11: Output resolution: 1920x1080
12:41:11: ------------------------------------------
12:41:11: Loading up D3D10 on AMD Radeon HD 7800 Series...
12:41:11: Audio Format: 48000hz
12:41:11: Playback device {0.0.0.00000000}.{29409af7-f163-4e27-bfbd-ad02edd2d07c}
12:41:11: Using desktop audio input: Alto-falantes (Turtle Beach COD EFF Headset)
12:41:11: Using auxilary audio input: Microfone (Turtle Beach COD EFF Headset)
12:41:11: Audio Encoding: AAC
12:41:11: bitrate: 128
12:41:11: Using Monitor Capture
12:41:11: Video Encoding: x264
12:41:11: fps: 30
12:41:11: width: 1920, height: 1080
12:41:11: preset: veryfast
12:41:11: profile: high
12:41:11: keyint: 60
12:41:11: CBR: yes
12:41:11: CFR: no
12:41:11: max bitrate: 1200
12:41:11: buffer size: 1200
12:41:11: MMDeviceAudioSource: Frequency for device 'Alto-falantes (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:41:11: MMDeviceAudioSource: Frequency for device 'Microfone (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:41:13: Using RTMP service: Twitch / Justin.tv
12:41:13: Server selection: rtmp://live.justin.tv/app
12:41:13: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
12:41:16: Completed handshake with rtmp://live.justin.tv/app in 3534 ms.
12:41:19: SO_SNDBUF was at 8192
12:41:19: SO_SNDBUF is now 65536
12:41:23: RTMPPublisher::SendLoop: Stalled for 3087 ms to write 169555 bytes (buffer: 0 / 169984), unstable connection?
12:41:31: RTMPPublisher::SendLoop: Stalled for 6904 ms to write 168987 bytes (buffer: 0 / 169984), unstable connection?
12:41:38: Total frames encoded: 802, total frames duplicated: 34 (4.24%)
12:41:38: Total frames rendered: 806, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
12:41:40: RTMPPublisher::SendLoop: Stalled for 8593 ms to write 166436 bytes (buffer: 0 / 169984), unstable connection?
12:41:49: RTMPPublisher::SendLoop: Stalled for 9696 ms to write 169930 bytes (buffer: 0 / 169984), unstable connection?
12:41:57: RTMPPublisher::SendLoop: Stalled for 7582 ms to write 166617 bytes (buffer: 0 / 169984), unstable connection?
12:42:05: RTMPPublisher::SendLoop: Stalled for 7804 ms to write 167902 bytes (buffer: 0 / 169984), unstable connection?
12:42:14: RTMPPublisher::SendLoop: Stalled for 9212 ms to write 169417 bytes (buffer: 0 / 169984), unstable connection?
12:42:22: RTMPPublisher::SendLoop: Stalled for 7491 ms to write 168217 bytes (buffer: 0 / 169984), unstable connection?
12:42:29: ~RTMPPublisher: Network appears stalled with 166225 / 169984 buffered, dropping connection!
12:42:29: RTMPPublisher::SocketLoop: Graceful loop exit
12:42:29: Average send payload: 145831 bytes, average send interval: 5566 ms
12:42:29: Number of times waited to send: 12, Waited for a total of 42359 bytes
12:42:29: Number of b-frames dropped: 111 (20%), Number of p-frames dropped: 115 (21%), Total 226 (41%)
12:42:29: Number of bytes sent: 1604144
12:42:29:
12:42:29: Profiler time results:
12:42:29:
12:42:29: ==============================================================
12:42:29: video thread frame - [100%] [avg time: 5.424 ms] [children: 78.6%] [unaccounted: 21.4%]
12:42:29: | scene->Preprocess - [78.6%] [avg time: 4.265 ms]
12:42:29: GPU download and conversion - [100%] [avg time: 0.168 ms] [children: 79.8%] [unaccounted: 20.2%]
12:42:29: | flush - [64.9%] [avg time: 0.109 ms]
12:42:29: | CopyResource - [5.36%] [avg time: 0.009 ms]
12:42:29: | conversion to 4:2:0 - [9.52%] [avg time: 0.016 ms]
12:42:29: Convert444Threads - [100%] [avg time: 1.05 ms] [children: 99.1%] [unaccounted: 0.857%]
12:42:29: | Convert444toNV12 - [99.1%] [avg time: 1.041 ms]
12:42:29: encoder thread frame - [100%] [avg time: 1.8 ms]
12:42:29:
12:42:29:
12:42:29: Profiler CPU results:
12:42:29:
12:42:29: video thread frame - [cpu time: avg 3.541 ms, total 2854.82 ms] [avg calls per frame: 1]
12:42:29: | scene->Preprocess - [cpu time: avg 3.038 ms, total 2449.22 ms] [avg calls per frame: 1]
12:42:29: GPU download and conversion - [cpu time: avg 0.038 ms, total 31.2 ms] [avg calls per frame: 1]
12:42:29: | flush - [cpu time: avg 0.019 ms, total 15.6 ms] [avg calls per frame: 1]
12:42:29: | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:42:29: | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
12:42:29: Convert444Threads - [cpu time: avg 1.005 ms, total 1591.21 ms] [avg calls per frame: 2]
12:42:29: | Convert444toNV12 - [cpu time: avg 1.005 ms, total 1591.21 ms] [avg calls per frame: 2]
12:42:29: encoder thread frame - [cpu time: avg 1.086 ms, total 858.005 ms] [avg calls per frame: 1]
12:42:29:
12:42:29: =====Stream End: 2013-09-30, 12:42:29=================================================
12:44:03: =====Stream Start: 2013-09-30, 12:44:03===============================================
12:44:03: Multithreaded optimizations: On
12:44:03: Base resolution: 1920x1080
12:44:03: Output resolution: 1920x1080
12:44:03: ------------------------------------------
12:44:03: Loading up D3D10 on AMD Radeon HD 7800 Series...
12:44:03: Audio Format: 48000hz
12:44:03: Playback device {0.0.0.00000000}.{29409af7-f163-4e27-bfbd-ad02edd2d07c}
12:44:03: Using desktop audio input: Alto-falantes (Turtle Beach COD EFF Headset)
12:44:03: Using auxilary audio input: Microfone (Turtle Beach COD EFF Headset)
12:44:03: Audio Encoding: AAC
12:44:03: bitrate: 128
12:44:04: Using Monitor Capture
12:44:04: ------------------------------------------
12:44:04: Video Encoding: x264
12:44:04: fps: 30
12:44:04: width: 1920, height: 1080
12:44:04: preset: veryfast
12:44:04: profile: high
12:44:04: keyint: 60
12:44:04: CBR: yes
12:44:04: CFR: no
12:44:04: max bitrate: 1200
12:44:04: buffer size: 1200
12:44:04: MMDeviceAudioSource: Frequency for device 'Alto-falantes (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:44:04: MMDeviceAudioSource: Frequency for device 'Microfone (Turtle Beach COD EFF Headset)' is 384000, samples per sec is 48000
12:44:05: Using RTMP service: Twitch / Justin.tv
12:44:05: Server selection: rtmp://live-jfk.justin.tv/app
12:44:05: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
12:44:06: Completed handshake with rtmp://live-jfk.justin.tv/app in 794 ms.
12:44:09: SO_SNDBUF was at 8192
12:44:09: SO_SNDBUF is now 65536
12:44:12: RTMPPublisher::SendLoop: Stalled for 2218 ms to write 166047 bytes (buffer: 0 / 169984), unstable connection?
12:44:16: RTMPPublisher::SendLoop: Stalled for 4750 ms to write 167363 bytes (buffer: 0 / 169984), unstable connection?
12:44:23: RTMPPublisher::SendLoop: Stalled for 6952 ms to write 168361 bytes (buffer: 0 / 169984), unstable connection?
12:44:32: RTMPPublisher::SendLoop: Stalled for 8543 ms to write 167103 bytes (buffer: 0 / 169984), unstable connection?
12:44:43: RTMPPublisher::SendLoop: Stalled for 10899 ms to write 168596 bytes (buffer: 0 / 169984), unstable connection?
12:44:47: Total frames encoded: 1283, total frames duplicated: 61 (4.75%)
12:44:47: Total frames rendered: 1289, number of late frames: 1 (0.08%) (it's okay for some frames to be late)
12:44:51: RTMPPublisher::SendLoop: Stalled for 8469 ms to write 168207 bytes (buffer: 0 / 169984), unstable connection?
12:44:59: RTMPPublisher::SendLoop: Stalled for 7295 ms to write 169231 bytes (buffer: 0 / 169984), unstable connection?
12:45:05: RTMPPublisher::SendLoop: Stalled for 6172 ms to write 167003 bytes (buffer: 0 / 169984), unstable connection?
