Bug Report Problem with OBS - 32bit, and unable to use elgato and webcam at same time?
Kelvin
I am running a 64 Bits windows, but i am forced to use 32 bit because 64 bits obs cant detect elgato.
So at 1st it was working then after i manage to tweak it to work (didnt mod and file), so i went to close and shut down my computer. Next day when i open the 32 bit version i get this problem?. My 64 bit on the other hand is fine
OBS has encountered an unhandled exception and has terminated. If you are able to
reproduce this crash, please submit this crash report on the forums at
http://www.obsproject.com/ - include the contents of this crash log and the
minidump .dmp file (if available) as well as your regular OBS log files and
a description of what you were doing at the time of the crash.
This crash appears to have occured in the 'c:\program files (x86)\obs\obsapi.dll' module.
**** UNHANDLED EXCEPTION: c0000005
Fault address: 0F39E2BA (c:\program files (x86)\obs\obsapi.dll)
OBS version: Open Broadcaster Software v0.624b
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Crashing thread stack trace:
Stack EIP Arg0 Arg1 Arg2 Arg3 Address
0029F470 0F39E2BA 3F800000 0F3B4B90 00000000 3F800000 obsapi.dll!AudioSource::SetVolume+0x1a
0029F478 5C685143 0000138A 0013037A 00000000 FFFDB800 dshowplugin.dll!DeviceSource::GlobalSourceEnterScene+0x53
0029F490 00AE24BA 00000000 00000000 0029F694 00B0237D obs.exe!OBS::Start+0x112a
0029F5A0 00AE0DD7 00000000 00B01760 38012534 00000000 obs.exe!OBS::ToggleCapturing+0x37
0029F5B0 00B0237D 002A021E 00000111 0000138A 0013037A obs.exe!OBS::OBSProc+0xc1d
0029F69C 75E462FA 00B01760 002A021E 00000111 0000138A user32.dll!0x75e462fa
0029F6C8 75E46D3A 00000000 00B01760 002A021E 00000111 user32.dll!0x75e46d3a
0029F740 75E46DE8 00D24150 00000000 00000111 0000138A user32.dll!0x75e46de8
0029F79C 75E46E44 0029F7E8 00000000 0029F99C 77AE0070 user32.dll!0x75e46e44
0029F7D8 77AE010A 00D24150 00000000 00B01760 0000138A ntdll.dll!0x77ae010a
0029F850 75E496C5 002A021E 00000111 0000138A 0013037A user32.dll!0x75e496c5
0029F874 717D4601 00337310 00000000 0013037A 00337310 comctl32.dll!0x717d4601
0029F894 717D4663 54010001 00000001 00000000 7175B495 comctl32.dll!0x717d4663
0029F8B0 717D44ED 0013037A 00000202 00000000 000D0012 comctl32.dll!0x717d44ed
0029F910 75E462FA 7175B495 0013037A 00000202 00000000 user32.dll!0x75e462fa
0029F93C 75E46D3A 00000000 7175B495 0013037A 00000202 user32.dll!0x75e46d3a
0029F9B4 75E477C4 7175B495 00000000 0029FA48 75E6C81F user32.dll!0x75e477c4
0029FA14 75E4788A 0029FAE4 004303DD 75E478E2 75E47809 user32.dll!0x75e4788a
0029FA24 75E6C81F 002A021E 00000000 00000000 00000001 user32.dll!0x75e6c81f
0029FA50 00AD6000 00A90000 00000000 002D4BA5 00000001 obs.exe!WinMain+0x8d0
0029FF1C 00B1E8AA FFFDE000 0029FFAC 77B09F72 FFFDE000 obs.exe!__tmainCRTStartup+0xfd
0029FF68 759A338A FFFDE000 778BB679 00000000 00000000 kernel32.dll!0x759a338a
0029FF74 77B09F72 00B1E7A3 FFFDE000 00000000 00000000 ntdll.dll!0x77b09f72
0029FFB4 77B09F45 00B1E7A3 FFFDE000 00000000 00000000 ntdll.dll!0x77b09f45
A minidump was saved to C:\Users\abc\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-06-13_31.dmp.
Please include this file when posting a crash report.
List of loaded modules:
Base Address Module
Kelvin
Seems to be working but currently having WOOOPS crashing when i try to add my webcam Global Source.??
So summarize is only can stream gameplay but my webcam cant be detected on 32bit version
gameplay cant be detected but webcam can on 64bit
Kelvin
Ok i troubleshoot and have that my webcam is causing the problem?
Edit: my webcam only works when on 64 bit version?
R1CH
Forum Admin
Developer
Thanks, the log confirmed my suspicions. This crash will be fixed in the next version of OBS. In the meantime, it seems your problem occurs because your USB bandwidth may be exceeded. Try lowering the resolution of the webcam or moving it to different USB ports.
Kelvin
Tried different USB port 2.0 and 3.0 (i know no diff) , front and back ports at my lowest camera setting 160x280?
Guess i have to wait for next version then :(
R1CH
Forum Admin
Developer
The next version won't fix the issue, it will only prevent the crashing when the device fails to initialize.
