Question / Help Problem with MacBook and OBS
JetLoneStarr
hi i have install on my Macbook Pro Mid 2015
but i can not open it
i have this problem and message
Failled to find locale/en-US.ini
and
Failed to load locale
Can you help me plz
THX
Best regrads
I had the same issue. Here's how I fixed it.
Shift+Command+G and enter ~/Library/Application Support/obs-studio/basic
Then delete the files in the scenes folder. Note that you might lose your scenes. If this doesn't work, you might want to delete the scenes folder completely.
Hope it works!
Hope it works!
Hi thx for your help but a have make it but its also no work
i deinstall OBS
Load it new and the same problem
Please help me please
