Question / Help Problem with lag when using software capture.
DarkChicken
When I am LIveStreaming I can perfectly livestream with no lag or frame issues when using Game Capture. The problem comes when I want to show the music playing on my livestream. I use software capture to capture the image of the song playing on the other monitor. But when I enable the software capture I start to get lag and frames issues. My computer specs are good enough that is should be able to do this.
I also have one question about actually using OBS. When i get done playing a game and it switches to my desktop is there a way that i can have OBS automatically switch to the Software Capture (And with overlays and such).
Any help would be appreciated.
Thanks, DarkChicken
EDIT: I mainly play League of Legends when using OBS
DarkChicken
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
CPU Speed: 3602MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 7, model 13, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
monitor 2: pos={-1920, -106}, size={1920, 1080}
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 670
  Video Adapter Dedicated Video Memory: 2091581440
  Video Adapter Shared System Memory: 2147479552
  Base resolution: 1920x1080
  Output resolution: 1920x1080
Loading up D3D10...
Playback device Default
Using desktop audio input: Realtek Digital Output (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Live! Cam Connect HD VF0750)
Audio Encoding: AAC
    bitrate: 128
Using graphics capture
Using text output
Using text output
Using text output
Using bitmap image
    device: Live! Cam Connect HD VF0750,
    device id \\?\usb#vid_041e&pid_4093&mi_00#7&16a1990a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
    chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, fps: 5-30, fourCC: 'YUY2'
Using directshow input
Using Monitor Capture
Using bitmap image
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264: profile High, level 4.0
Video Encoding: x264
    fps: 30
    width: 1920, height: 1080
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
  Server selection: rtmp://live-jfk.justin.tv/app
bufferTime: 3653, outputRateWindowTime: 1000, dropThreshold: 4153
Total frames rendered: 8591, number of frames that lagged: 3137 (36.51%) (it's okay for some frames to lag)
x264: frame I:35    Avg QP:15.29  size:119649
x264: frame P:2159  Avg QP:17.62  size:  1785
x264: frame B:6353  Avg QP:20.17  size:   265
x264: consecutive B-frames:  0.9%  0.0%  0.0% 99.1%
x264: mb I  I16..4: 68.2%  4.6% 27.2%
x264: mb P  I16..4:  0.1%  0.1%  0.0%  P16..4:  1.3%  0.5%  0.3%  0.0%  0.0%    skip:97.7%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.3%  0.1%  0.0%  direct: 0.1%  skip:99.5%  L0:37.9% L1:45.4% BI:16.7%
x264: 8x8 transform intra:8.9% inter:35.6%
x264: coded y,uvDC,uvAC intra: 34.3% 35.2% 30.2% inter: 0.3% 0.3% 0.0%
x264: i16 v,h,dc,p: 88%  8%  3%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 17% 25%  3%  6%  5%  5%  7%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 24% 11%  6%  7%  7%  7%  6%  7%
x264: i8c dc,h,v,p: 71% 14% 11%  4%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:230.56
Loading up D3D10...
Using desktop audio input: Speakers (2- Razer Megalodon)
Using 7.1 surround speaker setup (experimental)
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2217, outputRateWindowTime: 1000, dropThreshold: 2717
Total frames rendered: 17792, number of frames that lagged: 17472 (98.20%) (it's okay for some frames to lag)
x264: frame I:75    Avg QP:21.33  size:167976
x264: frame P:4864  Avg QP:24.96  size:  5103
x264: frame B:12814 Avg QP:30.03  size:   248
x264: consecutive B-frames:  3.5%  0.4%  0.9% 95.2%
x264: mb I  I16..4: 56.1%  5.7% 38.2%
x264: mb P  I16..4:  1.3%  0.6%  0.7%  P16..4:  2.0%  0.5%  0.3%  0.0%  0.0%    skip:94.6%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.2%  0.1%  0.0%  direct: 0.1%  skip:99.5%  L0:42.5% L1:44.3% BI:13.2%
x264: 8x8 transform intra:16.2% inter:33.1%
x264: coded y,uvDC,uvAC intra: 42.6% 37.0% 24.2% inter: 0.4% 0.4% 0.1%
x264: i16 v,h,dc,p: 62% 33%  3%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 25% 20%  3%  6%  5%  6%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 26% 13%  5%  6%  6%  6%  5%  6%
x264: i8c dc,h,v,p: 60% 22% 15%  4%
x264: kb/s:344.84
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
Total frames rendered: 1615, number of frames that lagged: 848 (52.51%) (it's okay for some frames to lag)
x264: frame I:7     Avg QP:21.56  size:237503
x264: frame P:428   Avg QP:22.73  size:  6370
x264: frame B:1140  Avg QP:24.26  size:   851
x264: consecutive B-frames:  3.0%  0.9%  1.5% 94.6%
x264: mb I  I16..4: 33.3% 11.8% 54.9%
x264: mb P  I16..4:  1.6%  0.5%  0.5%  P16..4:  3.6%  1.1%  0.6%  0.0%  0.0%    skip:92.1%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.9%  0.2%  0.0%  direct: 0.6%  skip:98.1%  L0:37.8% L1:50.0% BI:12.2%
x264: 8x8 transform intra:16.9% inter:29.4%
x264: coded y,uvDC,uvAC intra: 50.2% 47.1% 34.4% inter: 0.8% 1.0% 0.1%
x264: i16 v,h,dc,p: 50% 37%  8%  4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 27% 26%  3%  5%  4%  4%  4%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 30% 12%  5%  6%  6%  6%  5%  6%
x264: i8c dc,h,v,p: 51% 28% 17%  4%
x264: kb/s:670.81
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2088, outputRateWindowTime: 1000, dropThreshold: 2588
SharedTexCapture hooked
Warning -- MMDeviceAudioSource::GetBuffer: GetNextPacketSize failed, result = 88890004
Total frames rendered: 8876, number of frames that lagged: 4606 (51.89%) (it's okay for some frames to lag)
x264: frame I:37    Avg QP:20.40  size:221484
x264: frame P:2276  Avg QP:19.40  size:  2906
x264: frame B:6521  Avg QP:19.63  size:   334
x264: consecutive B-frames:  1.4%  0.3%  0.5% 97.8%
x264: mb I  I16..4: 38.0% 10.4% 51.6%
x264: mb P  I16..4:  0.5%  0.2%  0.2%  P16..4:  1.5%  0.5%  0.3%  0.0%  0.0%    skip:96.8%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.3%  0.1%  0.0%  direct: 0.1%  skip:99.4%  L0:38.8% L1:48.5% BI:12.8%
x264: 8x8 transform intra:16.2% inter:35.7%
x264: coded y,uvDC,uvAC intra: 53.1% 50.3% 39.3% inter: 0.3% 0.3% 0.0%
x264: i16 v,h,dc,p: 53% 41%  4%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 34% 23%  2%  5%  4%  4%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 27% 10%  6%  7%  6%  6%  6%  7%
x264: i8c dc,h,v,p: 48% 28% 18%  5%
x264: kb/s:371.47
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2254, outputRateWindowTime: 1000, dropThreshold: 2754
Total frames rendered: 870, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:5     Avg QP:19.34  size:130033
x264: frame P:210   Avg QP:18.15  size:  4218
x264: frame B:611   Avg QP:19.30  size:   506
x264: consecutive B-frames:  1.2%  0.0%  0.4% 98.4%
x264: mb I  I16..4: 46.9% 14.5% 38.6%
x264: mb P  I16..4:  0.1%  0.2%  0.2%  P16..4:  3.3%  0.7%  0.6%  0.0%  0.0%    skip:94.9%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.3%  0.1%  0.1%  direct: 0.1%  skip:99.4%  L0:37.7% L1:45.4% BI:16.9%
x264: 8x8 transform intra:18.9% inter:32.4%
x264: coded y,uvDC,uvAC intra: 54.9% 54.9% 38.6% inter: 0.7% 0.6% 0.1%
x264: i16 v,h,dc,p: 80% 12%  6%  2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 25% 18%  3%  8%  5%  6%  5%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 21%  9%  8%  8%  8%  8%  8%  8%
x264: i8c dc,h,v,p: 57% 20% 17%  7%
x264: Weighted P-Frames: Y:0.5% UV:0.0%
x264: kb/s:536.16
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
Total frames rendered: 14313, number of frames that lagged: 3 (0.02%) (it's okay for some frames to lag)
x264: frame I:59    Avg QP:21.01  size:216654
x264: frame P:4572  Avg QP:25.12  size: 20934
x264: frame B:9638  Avg QP:31.72  size:  4764
x264: consecutive B-frames:  9.1%  1.5%  3.3% 86.1%
x264: mb I  I16..4: 10.2% 28.5% 61.3%
x264: mb P  I16..4:  2.8%  3.4%  1.1%  P16..4: 17.0%  4.9%  2.5%  0.0%  0.0%    skip:68.2%
x264: mb B  I16..4:  0.1%  0.1%  0.1%  B16..8:  2.4%  1.6%  0.5%  direct: 1.0%  skip:94.3%  L0:35.3% L1:43.7% BI:21.0%
x264: 8x8 transform intra:42.7% inter:31.2%
x264: coded y,uvDC,uvAC intra: 60.8% 60.8% 30.5% inter: 4.2% 4.1% 1.0%
x264: i16 v,h,dc,p: 25% 32% 33% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 16% 35%  4%  7%  5%  6%  5%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 19%  9%  8%  7%  7%  7%  8%
x264: i8c dc,h,v,p: 54% 24% 16%  6%
x264: kb/s:2596.61
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2345, outputRateWindowTime: 1000, dropThreshold: 2845
RTMPPublisher::BufferedSend: Socket buffer is full (525257 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525702 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
RTMPPublisher::BufferedSend: Socket buffer is full (525269 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525227 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
RTMPPublisher::BufferedSend: Socket buffer is full (526974 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528229 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524367 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524881 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527680 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524602 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526676 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527474 / 528384 bytes), waiting to send 4097 bytes
Total frames rendered: 128088, number of frames that lagged: 6824 (5.33%) (it's okay for some frames to lag)
Number of b-frames dropped: 29 (0.023%), Number of p-frames dropped: 0 (0%), Total 29 (0.023%)
x264: frame I:544   Avg QP:22.48  size:190867
x264: frame P:45421 Avg QP:25.85  size: 21558
x264: frame B:82079 Avg QP:30.63  size:  4248
x264: consecutive B-frames: 11.0%  6.5% 11.8% 70.6%
x264: mb I  I16..4: 18.0% 28.6% 53.4%
x264: mb P  I16..4:  3.7%  4.2%  1.3%  P16..4: 17.2%  5.1%  2.5%  0.0%  0.0%    skip:66.1%
x264: mb B  I16..4:  0.1%  0.1%  0.1%  B16..8:  2.5%  1.5%  0.4%  direct: 1.0%  skip:94.4%  L0:34.5% L1:46.5% BI:19.0%
x264: 8x8 transform intra:43.5% inter:31.5%
x264: coded y,uvDC,uvAC intra: 56.2% 52.3% 25.3% inter: 4.4% 4.4% 0.9%
x264: i16 v,h,dc,p: 29% 29% 32% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 16% 36%  4%  8%  5%  6%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 20% 18%  8%  8%  7%  8%  6%  7%
x264: i8c dc,h,v,p: 59% 21% 15%  5%
x264: kb/s:2613.13
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
Total frames rendered: 7290, number of frames that lagged: 1891 (25.94%) (it's okay for some frames to lag)
x264: frame I:30    Avg QP:16.82  size:127424
x264: frame P:1847  Avg QP:16.33  size:  1604
x264: frame B:5369  Avg QP:16.61  size:   217
x264: consecutive B-frames:  1.2%  0.1%  0.1% 98.7%
x264: mb I  I16..4: 62.5%  7.6% 29.9%
x264: mb P  I16..4:  0.2%  0.1%  0.0%  P16..4:  1.3%  0.4%  0.2%  0.0%  0.0%    skip:97.7%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.2%  0.1%  0.0%  direct: 0.1%  skip:99.6%  L0:36.6% L1:46.6% BI:16.7%
x264: 8x8 transform intra:13.1% inter:32.2%
x264: coded y,uvDC,uvAC intra: 36.0% 35.4% 28.8% inter: 0.2% 0.2% 0.0%
x264: i16 v,h,dc,p: 77% 19%  3%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 27% 28%  2%  4%  4%  3%  4%  4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 27% 11%  6%  7%  6%  7%  6%  7%
x264: i8c dc,h,v,p: 63% 20% 13%  4%
x264: kb/s:235.53
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
Total frames rendered: 5813, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
x264: frame I:24    Avg QP:22.17  size:235088
x264: frame P:1679  Avg QP:24.15  size: 15144
x264: frame B:4066  Avg QP:27.66  size:  2433
x264: consecutive B-frames:  5.7%  0.7%  1.3% 92.4%
x264: mb I  I16..4: 22.0% 18.5% 59.5%
x264: mb P  I16..4:  1.9%  1.5%  0.5%  P16..4: 12.7%  2.9%  1.8%  0.0%  0.0%    skip:78.6%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  1.1%  0.6%  0.2%  direct: 0.6%  skip:97.4%  L0:33.3% L1:44.6% BI:22.1%
x264: 8x8 transform intra:33.0% inter:28.9%
x264: coded y,uvDC,uvAC intra: 60.6% 58.6% 30.7% inter: 2.6% 2.0% 0.4%
x264: i16 v,h,dc,p: 30% 27% 33% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 15% 38%  4%  8%  5%  6%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 19% 17%  8%  8%  8%  8%  6%  8%
x264: i8c dc,h,v,p: 55% 23% 16%  5%
x264: kb/s:1703.52
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2279, outputRateWindowTime: 1000, dropThreshold: 2779
RTMPPublisher::BufferedSend: Socket buffer is full (524333 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525190 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 524288
RTMPPublisher::BufferedSend: Socket buffer is full (527980 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527617 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527866 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525023 / 528384 bytes), waiting to send 3779 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525157 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526588 / 528384 bytes), waiting to send 4097 bytes
Total frames rendered: 42862, number of frames that lagged: 6 (0.01%) (it's okay for some frames to lag)
Number of b-frames dropped: 52 (0.12%), Number of p-frames dropped: 25 (0.058%), Total 77 (0.18%)
x264: frame I:174   Avg QP:23.91  size:215205
x264: frame P:15471 Avg QP:27.01  size: 24217
x264: frame B:27173 Avg QP:32.83  size:  5006
x264: consecutive B-frames: 12.0%  6.5% 11.5% 70.1%
x264: mb I  I16..4: 19.5% 26.6% 54.0%
x264: mb P  I16..4:  4.6%  3.6%  1.4%  P16..4: 18.2%  4.5%  2.3%  0.0%  0.0%    skip:65.4%
x264: mb B  I16..4:  0.2%  0.1%  0.1%  B16..8:  2.4%  1.4%  0.4%  direct: 1.1%  skip:94.4%  L0:35.4% L1:46.5% BI:18.1%
x264: 8x8 transform intra:35.6% inter:25.4%
x264: coded y,uvDC,uvAC intra: 56.1% 54.3% 25.8% inter: 4.5% 4.5% 0.9%
x264: i16 v,h,dc,p: 27% 28% 34% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 15% 38%  4%  7%  5%  6%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 21%  8%  7%  7%  7%  6%  7%
x264: i8c dc,h,v,p: 57% 23% 16%  5%
x264: kb/s:3069.25
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using text output
Using text output
Using text output
Using bitmap image
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 8
bufferTime: 2325, outputRateWindowTime: 1000, dropThreshold: 2825
RTMPPublisher::BufferedSend: Socket buffer is full (527089 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526184 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526600 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525109 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525281 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526420 / 528384 bytes), waiting to send 3707 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528265 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528187 / 528384 bytes), waiting to send 362 bytes
Total frames rendered: 20738, number of frames that lagged: 11230 (54.15%) (it's okay for some frames to lag)
Number of b-frames dropped: 2 (0.0097%), Number of p-frames dropped: 0 (0%), Total 2 (0.0097%)
x264: frame I:84    Avg QP:23.07  size:233995
x264: frame P:6415  Avg QP:23.80  size: 13298
x264: frame B:14195 Avg QP:22.91  size:  2199
x264: consecutive B-frames:  4.7%  9.5%  5.8% 80.0%
x264: mb I  I16..4: 26.6% 18.0% 55.5%
x264: mb P  I16..4:  2.1%  2.0%  0.8%  P16..4:  9.4%  2.8%  1.4%  0.0%  0.0%    skip:81.4%
x264: mb B  I16..4:  0.1%  0.1%  0.0%  B16..8:  1.4%  0.7%  0.2%  direct: 0.6%  skip:96.9%  L0:36.6% L1:46.9% BI:16.5%
x264: 8x8 transform intra:36.0% inter:25.6%
x264: coded y,uvDC,uvAC intra: 57.9% 59.0% 34.4% inter: 2.1% 2.3% 0.5%
x264: i16 v,h,dc,p: 32% 31% 26% 11%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 20% 32%  4%  7%  5%  6%  5%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 23% 17%  7%  7%  7%  7%  6%  7%
x264: i8c dc,h,v,p: 55% 24% 16%  6%
x264: Weighted P-Frames: Y:0.1% UV:0.0%
x264: kb/s:1232.12
Profiler results:
frame - [100%] [avg time: 15.523 ms] [avg calls per frame: 1] [children: 95.8%] [unaccounted: 4.23%]
| scene->Preprocess - [61.2%] [avg time: 9.495 ms] [avg calls per frame: 1]
| video encoding and uploading - [34.6%] [avg time: 5.371 ms] [avg calls per frame: 1] [children: 13.3%] [unaccounted: 21.3%]
| | CopyResource - [0.122%] [avg time: 0.019 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.11%] [avg time: 0.017 ms] [avg calls per frame: 0]
| | call to encoder - [12.8%] [avg time: 1.99 ms] [avg calls per frame: 0]
| | sending stuff out - [0.2%] [avg time: 0.031 ms] [avg calls per frame: 0]
dodgepong
Administrator
Community Helper
Yep, you're using Monitor capture with Aero enabled.
Either disable Aero, or use Window capture instead.
