Question / Help Problem with Frame drop
droga22
Hi, lately i'm trying to stream but i always drop at least 70% of my frames, someone bring me a solution please @_@
Here's one of my logs:
19:15:33: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
19:15:33: CUDA loaded successfully
19:15:33: 1 CUDA capable devices found
19:15:33: [ GPU #0 - < GeForce GTX 770 > has Compute SM 3.0, NVENC Available ]
19:15:56: Settings::Video: Enabling Aero
19:16:01: Open Broadcaster Software v0.624b - 32bit (´・ω・`)
19:16:01: -------------------------------
19:16:01: CPU Name: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
19:16:01: CPU Speed: 3518MHz
19:16:01: Physical Memory:  4095MB Total, 4095MB Free
19:16:01: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
19:16:01: monitor 1: pos={0, 0}, size={1920, 1080}
19:16:01: Windows Version: 6.1 Build 7601 S
19:16:01: Aero is Enabled
19:16:01: OBS Modules:
19:16:01: Base Address     Module
19:16:01: 002C0000         OBS.exe
19:16:01: 54570000         OBSApi.dll
19:16:01: 5CCC0000         DShowPlugin.dll
19:16:01: 5CF10000         GraphicsCapture.dll
19:16:01: 5CEE0000         NoiseGate.dll
19:16:01: 5CCA0000         PSVPlugin.dll
19:16:01: ------------------------------------------
19:16:01: Adapter 1
19:16:01:   Video Adapter: NVIDIA GeForce GTX 770
19:16:01:   Video Adapter Dedicated Video Memory: 4223336448
19:16:01:   Video Adapter Shared System Memory: 3994138624
19:16:01:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:16:01: =====Stream Start: 2014-06-18, 19:16:01===============================================
19:16:01:   Multithreaded optimizations: On
19:16:01:   Base resolution: 1920x1080
19:16:01:   Output resolution: 1920x1080
19:16:01: Loading up D3D10 on NVIDIA GeForce GTX 770 (Adapter 1)...
19:16:01: Audio Format: 48000 Hz
19:16:01: Audio Channels: 2 Ch
19:16:01: Playback device Default
19:16:01: Using desktop audio input: Alto-falantes (Realtek High Definition Audio)
19:16:01: Global Audio time adjust: 0
19:16:01: Using auxilary audio input: Microfone (Dispositivo de áudio USB)
19:16:01: Mic time offset: 0
19:16:01: Audio Encoding: AAC
19:16:01:     bitrate: 128
19:16:01: Using Window Capture
19:16:01: Using bitmap image
19:16:01: Scene buffering time set to 700
19:16:01: Video Encoding: x264
19:16:01:     fps: 30
19:16:01:     width: 1920, height: 1080
19:16:01:     preset: veryfast
19:16:01:     profile: high
19:16:01:     keyint: 250
19:16:01:     CBR: yes
19:16:01:     CFR: yes
19:16:01:     max bitrate: 2500
19:16:01:     buffer size: 2500
19:16:04: Using RTMP service: Twitch / Justin.tv
19:16:04:   Server selection: rtmp://live-mia.justin.tv/app
19:16:04:   Interface: Intel(R) Ethernet Connection I217-V (ethernet, 100 mbps)
19:16:05: Completed handshake with rtmp://live-mia.justin.tv/app in 659 ms.
19:16:06: SO_SNDBUF was at 8192
19:16:06: SO_SNDBUF is now 65536
19:16:10: RTMPPublisher::SocketLoop: Stalled for 2231 ms to write 335183 bytes (buffer: 0 / 335872), unstable connection?
19:16:16: RTMPPublisher::SocketLoop: Stalled for 5705 ms to write 333545 bytes (buffer: 0 / 335872), unstable connection?
19:16:22: RTMPPublisher::SocketLoop: Stalled for 5956 ms to write 334330 bytes (buffer: 0 / 335872), unstable connection?
19:16:27: RTMPPublisher::SocketLoop: Stalled for 4958 ms to write 333524 bytes (buffer: 0 / 335872), unstable connection?
19:16:33: RTMPPublisher::SocketLoop: Stalled for 6333 ms to write 333557 bytes (buffer: 0 / 335872), unstable connection?
19:16:41: RTMPPublisher::SocketLoop: Stalled for 8494 ms to write 331949 bytes (buffer: 0 / 335872), unstable connection?
19:16:50: Total frames encoded: 1438, total frames duplicated: 2 (0.14%)
19:16:50: Total frames rendered: 1442, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
19:16:51: RTMPPublisher::SocketLoop: Stalled for 9733 ms to write 332157 bytes (buffer: 0 / 335872), unstable connection?
19:17:00: RTMPPublisher::SocketLoop: Stalled for 8447 ms to write 332663 bytes (buffer: 0 / 335872), unstable connection?
19:17:09: RTMPPublisher::SocketLoop: Stalled for 9569 ms to write 333384 bytes (buffer: 0 / 335872), unstable connection?
19:17:16: RTMPPublisher::SocketLoop: Stalled for 6312 ms to write 334167 bytes (buffer: 0 / 335872), unstable connection?
19:17:23: RTMPPublisher::SocketLoop: Stalled for 7153 ms to write 331992 bytes (buffer: 0 / 335872), unstable connection?
19:17:31: RTMPPublisher::SocketLoop: Stalled for 8118 ms to write 334116 bytes (buffer: 0 / 335872), unstable connection?
19:17:38: RTMPPublisher::SocketLoop: Stalled for 7492 ms to write 334658 bytes (buffer: 0 / 335872), unstable connection?
19:17:40: ~RTMPPublisher: Network appears stalled with 334821 / 335872 buffered, dropping connection!
19:17:40: RTMPPublisher::SocketLoop: Got hSendBacklogEvent but WSAIoctl() returned 10038
19:17:40: RTMPPublisher::SocketLoop: Graceful loop exit
19:17:40: Average send payload: 276287 bytes, average send interval: 5332 ms
19:17:40: Number of times waited to send: 18, Waited for a total of 73767 bytes
19:17:40: Number of b-frames dropped: 427 (33%), Number of p-frames dropped: 425 (33%), Total 852 (66%)
19:17:40: Number of bytes sent: 4696894
19:17:40:
19:17:40: Profiler time results:
19:17:40:
19:17:40: ==============================================================
19:17:40: video thread frame - [100%] [avg time: 0.603 ms] [children: 23.9%] [unaccounted: 76.1%]
19:17:40: | scene->Preprocess - [13.9%] [avg time: 0.084 ms]
19:17:40: | GPU download and conversion - [9.95%] [avg time: 0.06 ms] [children: 6.63%] [unaccounted: 3.32%]
19:17:40: | | flush - [5.14%] [avg time: 0.031 ms]
19:17:40: | | CopyResource - [1.16%] [avg time: 0.007 ms]
19:17:40: | | conversion to 4:2:0 - [0.332%] [avg time: 0.002 ms]
19:17:40: Convert444Threads - [100%] [avg time: 0.918 ms] [children: 99.5%] [unaccounted: 0.545%]
19:17:40: | Convert444toNV12 - [99.5%] [avg time: 0.913 ms]
19:17:40: encoder thread frame - [100%] [avg time: 1.591 ms] [children: 1.01%] [unaccounted: 99%]
19:17:40: | sending stuff out - [1.01%] [avg time: 0.016 ms]
19:17:40:
19:17:40:
19:17:40: Profiler CPU results:
19:17:40:
19:17:40: video thread frame - [cpu time: avg 0.194 ms, total 280.801 ms] [avg calls per frame: 1]
19:17:40: | scene->Preprocess - [cpu time: avg 0.021 ms, total 31.201 ms] [avg calls per frame: 1]
19:17:40: | GPU download and conversion - [cpu time: avg 0.054 ms, total 78 ms] [avg calls per frame: 1]
19:17:40: | | flush - [cpu time: avg 0.032 ms, total 46.8 ms] [avg calls per frame: 1]
19:17:40: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40: Convert444Threads - [cpu time: avg 1.017 ms, total 2886.02 ms] [avg calls per frame: 2]
19:17:40: | Convert444toNV12 - [cpu time: avg 1.017 ms, total 2886.02 ms] [avg calls per frame: 2]
19:17:40: encoder thread frame - [cpu time: avg 1.1 ms, total 1560.01 ms] [avg calls per frame: 1]
19:17:40: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40:
19:17:40: =====Stream End: 2014-06-18, 19:17:40=================================================
Last game capture log:
2014-06-18, 18:46:41: we're booting up:
18:46:41: CaptureThread: attached to process Dwm.exe
18:46:41: DXGI Present
18:46:41: (half life scientist) everything..  seems to be in order
Here's my internet test: http://www.speedtest.net/my-result/3569785892
Sorry for my bad english.
Thank you.
Man, I really love you!
I had read this topic but did not think that the antivirus would do this ... Thank you so much!
i'm sorry for my english xD
