01:57:26: Open Broadcaster Software v0.584b - 32bit (´・ω・`)
01:57:26: -------------------------------
01:57:26: CPU Name: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz
01:57:26: CPU Speed: 2395MHz
01:57:26: Physical Memory: 4095MB Total, 3228MB Free
01:57:26: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
01:57:26: monitor 1: pos={0, 0}, size={1600, 900}
01:57:26: Windows Version: 6.2 Build 9200
01:57:26: Aero is Enabled
01:57:26: OBS Modules:
01:57:26: Base Address Module
01:57:26: 01090000 OBS.exe
01:57:26: 61440000 OBSApi.dll
01:57:26: 64B80000 DShowPlugin.dll
01:57:26: 62D70000 GraphicsCapture.dll
01:57:26: 62D50000 NoiseGate.dll
01:57:26: 62BF0000 PSVPlugin.dll
01:57:26: ------------------------------------------
01:57:26: Adapter 1
01:57:26: Video Adapter: Intel(R) HD Graphics 4000
01:57:26: Video Adapter Dedicated Video Memory: 33554432
01:57:26: Video Adapter Shared System Memory: 1845493760
01:57:26: Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
01:57:26: =====Stream Start: 2013-11-27, 01:57:26===============================================
01:57:26: Multithreaded optimizations: On
01:57:26: Base resolution: 1280x720
01:57:26: Output resolution: 1280x720
01:57:26: Loading up D3D10 on Intel(R) HD Graphics 4000...
01:57:26: Audio Format: 48000hz
01:57:26: Playback device Default
01:57:26: Using desktop audio input: Speakers and Headphones (IDT High Definition Audio CODEC)
01:57:26: Using auxilary audio input: Internal Mic (IDT High Definition Audio CODEC)
01:57:27: ------------------------------------------
01:57:27: Audio Encoding: AAC
01:57:27: bitrate: 160
01:57:27: Using bitmap image
01:57:27: device: Dynex 1.3MP Webcam,
01:57:27: device id \\?\usb#vid_19ff&pid_0102&mi_00#7&4d28b35&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
01:57:27: chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000
01:57:27: use buffering: true - 15000000, fourCC: 'YUY2'
01:57:27: audio device: Disable,
01:57:27: audio device id Disabled,
01:57:27:
01:57:27: Using directshow input
01:57:28: ------------------------------------------
01:57:28: device: Elgato Game Capture HD,
01:57:28: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:57:28: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
01:57:28: use buffering: true - 0, fourCC: 'UYVY'
01:57:28:
01:57:28: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:57:28: Using directshow input
01:57:28: Scene buffering time set to 400
01:57:29: ------------------------------------------
01:57:29: Video Encoding: x264
01:57:29: fps: 60
01:57:29: width: 1280, height: 720
01:57:29: preset: veryfast
01:57:29: profile: high
01:57:29: keyint: 120
01:57:29: CBR: yes
01:57:29: CFR: no
01:57:29: max bitrate: 2900
01:57:29: buffer size: 3000
01:57:29: MMDeviceAudioSource: Frequency for device 'Speakers and Headphones (IDT High Definition Audio CODEC)' is 384000, samples per sec is 48000
01:57:29: MMDeviceAudioSource: Frequency for device 'Internal Mic (IDT High Definition Audio CODEC)' is 384000, samples per sec is 48000
02:29:32: Total frames encoded: 115337, total frames duplicated: 526 (0.46%)
02:29:32: Number of frames skipped due to encoder lag: 130 (0.11%)
02:29:32: Total frames rendered: 115196, number of late frames: 25 (0.02%) (it's okay for some frames to be late)
02:29:35:
02:29:35: Profiler time results:
02:29:35:
02:29:35: ==============================================================
02:29:35: video thread frame - [100%] [avg time: 0.768 ms] [children: 44%] [unaccounted: 56%]
02:29:35: | scene->Preprocess - [32.9%] [avg time: 0.253 ms]
02:29:35: | GPU download and conversion - [11.1%] [avg time: 0.085 ms] [children: 4.82%] [unaccounted: 6.25%]
02:29:35: | | flush - [0.521%] [avg time: 0.004 ms]
02:29:35: | | CopyResource - [3.91%] [avg time: 0.03 ms]
02:29:35: | | conversion to 4:2:0 - [0.391%] [avg time: 0.003 ms]
02:29:35: Convert444Thread - [100%] [avg time: 1.516 ms] [children: 99%] [unaccounted: 0.989%]
02:29:35: | Convert444toNV12 - [99%] [avg time: 1.501 ms]
02:29:35: encoder thread frame - [100%] [avg time: 1.404 ms]
02:29:35:
02:29:35:
02:29:35: Profiler CPU results:
02:29:35:
02:29:35: video thread frame - [cpu time: avg 0.295 ms, total 34015.6 ms] [avg calls per frame: 1]
02:29:35: | scene->Preprocess - [cpu time: avg 0.145 ms, total 16796.9 ms] [avg calls per frame: 1]
02:29:35: | GPU download and conversion - [cpu time: avg 0.014 ms, total 1671.88 ms] [avg calls per frame: 1]
02:29:35: | | flush - [cpu time: avg 0.001 ms, total 140.625 ms] [avg calls per frame: 1]
02:29:35: | | CopyResource - [cpu time: avg 0.005 ms, total 593.75 ms] [avg calls per frame: 1]
02:29:35: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 62.5 ms] [avg calls per frame: 1]
02:29:35: Convert444Thread - [cpu time: avg 1.464 ms, total 168688 ms] [avg calls per frame: 1]
02:29:35: | Convert444toNV12 - [cpu time: avg 1.458 ms, total 168000 ms] [avg calls per frame: 1]
02:29:35: encoder thread frame - [cpu time: avg 1.069 ms, total 123313 ms] [avg calls per frame: 1]
02:29:35:
02:29:35: =====Stream End: 2013-11-27, 02:29:35=================================================
02:29:42: Memory Leaks Were Detected.
02:29:42:
