Good day Jim.
I was fixing up a scene where I want to capture part of an application screen and adding a colorkey to it, in this case green in the color picker. I expected that colorkey is the same as setting a chroma key so some color in the captured screen will be filtered out and transparent. While I did so and added the capture to the scene I tried to preview it and the application hung up on me and generated an error log. It reads as follows:
Hope there can be some sense in this info to make it work. I have the latest DirectX installed, tried it just to make sure that wasn't the problem.
Open Broadcaster Software v0.432a - 64bit ( ^ω^)
CPU Name: AMD Phenom(tm) II N830 Triple-Core Processor
CPU Speed: 2094MHz
Physical Memory: 3578MB Total, 1589MB Free
stepping id: 3, model 5, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 3, total cores 3
Adapter 1
Video Adapter: AMD Radeon HD 6500M/5600/5700 Series
Video Adapeter Dedicated Video Memory: 1064222720
Video Adapeter Shared System Memory: 1607938048
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Audio Encoding: AAC
bitrate: 64
Warning -- DShowPlugin: Could not create device filter
Warning -- D3D10Texture::CreateTexture: CreateTexture2D failed, result = 0x80070057
Video Encoding: x264
fps: 30
width: 1280, height: 720
quality: 10
preset: superfast
i444: no
max bitrate: 5000
buffer size: 5000
Exception Fault - Stack Trace:
OBS::MainCaptureLoop -> Scene::Render
