MisterNoName
Hello dear OBS support,
first of all I have to say sorry for my bad english, it's not my native language!
I have following problem:
I have a network-cam which is connected to obs (which is livestreaming).
I want to loop a specific mask "route" and that works.
I want to use this plugin so that I can insert the names of a few buildings in the area.
I timed everything correctly and it worked for 30 minutes. After that I counted every single location and set the correct time for every mask and now it works for nearly an hour and after that time it completely moves about a second per run.
Is it possible that the Cam can give commands to OBS to switch the Scenes?
Could you please tell me how to fix that? I couldn't find anything.
Thanks in advance and kind regards
Bastian G.
Bastian G.
