Question / Help Possible OBS/Hardware Issue Help
CrazyKipps
Hey Everyone :)
So i have recently been streaming with a dual PC setup, due to technical issues i swapped back to a single PC to stream on, the problem i am facing is, the PC i stream on, the hardware in my opinion is by far enough to stream in the settings i have on OBS, but the huge problem i have is when i try to play some games, my FPS is eaten up so much, it doesn't make sense. I will upload a log file of my most recent stream, where i ran in 720P 2500Bit 30 FPS. Below are my hardware specs also ^^ The issue which i need help with is, have i set something up wrong in OBS or maybe i could have some faulty hardware etc, any thought would be greatly appreciated :D
HARDWARE:::
Motherboard - Asus P9X79 Pro
Ram - 16GB 2200 MHz Trident
CPU - Intel I7-3770K 3.50GHz OC to 4.5GHz
GFX - EVGA GTX 780 SuperClocked
PSU - Corsair 800W
Cooling - Corsair H60
INTERNET::::
80 Down 20 Up
Example fps drop, cs:go on lowest settings before stream = 200 when stream = 30
Thank you very much for taking your time to read this! Have a great day ^^
Kipps
