I've been going trough everything in Windows, OBS, my soundcard setting.... looking at 36235 options. I think I found the sollution.
It's not a OBS problem. OBS wants to listen to something it doesn't get, input wise.
I use a A&H SQ5, so that's my soundcard.
Then, go to Windows settings - System - Sound - SOund Control Panel
Right click your sound input device, select properties so you get the Line properties
Click Listen, and checkbox Listen to this device and apply
All good with me know!
If this worked for you, give us a like: https://www.facebook.com/noxgenus/ and https://www.facebook.com/hennttlive666/
www.noxgenus.com
Cheers,
Minotaur Electronics
www.noxgenus.com
Cheers,
