Possible Encoding Problem?
Gelicide
I updated OBS recently, but I can't remember exactly when I updated it, but ever since when I assume I updated it, none of my video recordings work in Sony Vegas. All of my recordings in my files are named with the date and time they were captured (via replay buffer), and after a specific day, those videos don't work in Sony Vegas. Basically any recording that was made after 2/27/2022 has an issue where when I import it into Sony Vegas, only the audio track shows up, although I can watch the video perfectly fine from my files and there is no issue if I import it to Adobe Premier. I can only assume I updated OBS on the 26th or 27th and every recording after has had that issue. If I import any recording to vegas that is older, there is no issue. I made sure all of my settings in OBS remained the same, and I even compared the file properties of a file that worked and a file that had an issue, and everything seems to be normal. I even updated OBS today with the hotfix (27.2.3) to see if that would solve the issue, but it didn't work. I switched from mp4 to flv recording format and remuxed flv recordings to mp4 to see if that was a solution, but that didn't solve anything. I have provided the log from the day the issue started, as well as the logs from today (3/4/2022) when I tried to figure out the problem and was testing things and making small recordings. I'm not sure if this is an OBS issue or a Sony Vegas issue, but considering that it happened after I updated OBS and previous files still work, then it must be an OBS issue.
