Question / Help Plugins Problem , plz help me
neverrofl
Everytime i install a plugin (and im sure the os version and the way i install is correct) , it doesnt show at the sources part or the settings part
it really confused me , anyway i figured out that i could press the "check for updates" button to relaunch OBS and the plugin worked
but yesterday after i updated to 636b , i found i could no longer use plugin by clicking the "check for updates" , it showed "no updates are available"
its just terrible for me , can someone help me ? becuz the video sources plugin im using is really important for my stream
