Kingchickenz
This is the crash log below
Thread 704: (Crashed)
Stack EIP Arg0 Arg1 Arg2 Arg3 Address
00000027B70ECD10 00007FF9D968478C FFFFFFFFFFFFFFFE 00000027B70ECEE0 000001F222CF2E00 00007FF94846EE01 kernelbase.dll!0x7ff9d968478c
00000027B70ECDF0 00007FF94877115E 00007FF948220000 000001F22319AF00 00007FF94912CBF8 00000027B70F0DB8 libmfxhw64.dll!0x7ff94877115e
00000027B70ECE70 00007FF948485760 0000000000000000 00000027B70F0C38 00007FF949124818 0000000000000001 libmfxhw64.dll!0x7ff948485760
00000027B70ECF50 00007FF9484A3A96 0000000000000000 00000027B70FCF20 FF00363149786600 0000000000000000 libmfxhw64.dll!0x7ff9484a3a96
00000027B70ECFD0 00007FF948487305 000001F222D05860 0000000000000005 0000000000000300 00007FF9DBFC7551 libmfxhw64.dll!0x7ff948487305
00000027B70FCD40 00007FF94848359B 00000027B70FE4C9 0000000000000000 0000000000000000 00007FF94848389E libmfxhw64.dll!0x7ff94848359b
00000027B70FCD70 00007FF948468FD2 0000000000000001 000001F223175558 000001F223175558 00007FF9C06896D0 libmfxhw64.dll!0x7ff948468fd2
00000027B70FCEE0 00007FF9C067ABED 000001F223197BE0 000001F2231860F8 000001F222CD8720 000001F222D84860 obs-qsv11.dll!0x7ff9c067abed
00000027B70FE370 00007FF9C0679977 0000000000000000 0000000000000000 0000000000000000 000001F22306DA80 obs-qsv11.dll!0x7ff9c0679977
00000027B70FE3F0 00007FF9C0678FD0 000001F200010000 0000000000000000 000001F222E6B880 00000000000000E0 obs-qsv11.dll!0x7ff9c0678fd0
00000027B70FE420 00007FF997B22E01 0000000000000000 000001F222CD8720 00000027B70FE4C9 00000027B70FE4C9 obs.dll!obs_init_module+0x51
00000027B70FE450 00007FF997B22C4B 00007FF997B22420 0000000000000000 000001F222DBDFA0 000001F21EC68780 obs.dll!obs_find_modules+0x39b
00000027B70FE530 00007FF997B22E5E 000001F21C711080 00007FF7E78FE038 000001F21A0D5040 0000000000000001 obs.dll!obs_load_all_modules+0x1e
00000027B70FE560 00007FF7E7756684 000001F21C4C3DF0 000001F21C4C3DF0 FFFFFFFFFFFFFFFF 00000027B70FFA00 obs64.exe!OBSBasic::OBSInit+0x454
00000027B70FF460 00007FF7E7730A22 00000027B70FF850 00007FF7E79D5ED0 00000027B70FFB60 000001F21A231EE0 obs64.exe!OBSApp::OBSInit+0x342
00000027B70FF7B0 00007FF7E7736F53 0000000000000000 000001F21A22A620 000001F200000000 000001F21A226F20 obs64.exe!run_program+0x703
00000027B70FFB20 00007FF7E7739290 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!main+0x6c0
00000027B70FFCF0 00007FF7E78CE3D7 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!WinMain+0x157
00000027B70FFD80 00007FF7E78CDC96 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs64.exe!__scrt_common_main_seh+0x106
00000027B70FFDC0 00007FF9DA4D54E0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ff9da4d54e0
00000027B70FFDF0 00007FF9DBFA485B 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ff9dbfa485b
12:02:59.776: CPU Name: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
12:02:59.776: CPU Speed: 2208MHz
12:02:59.776: Physical Cores: 6, Logical Cores: 12
12:02:59.776: Physical Memory: 16262MB Total, 9346MB Free
12:02:59.776: Windows Version: 10.0 Build 22000 (release: 2009; revision: 376; 64-bit)
12:02:59.776: Running as administrator: false
12:02:59.776: Aero is Enabled (Aero is always on for windows 8 and above)
12:02:59.776: Windows 10 Gaming Features:
12:02:59.776: Game Bar: On
12:02:59.776: Game DVR: On
12:02:59.776: Game DVR Background Recording: On
12:02:59.776: Game Mode: On
12:02:59.777: Sec. Software Status:
12:02:59.779: Microsoft Defender Antivirus: enabled (AV)
12:02:59.779: Microsoft Firewall: enabled (FW)
12:02:59.780: Current Date/Time: 2021-12-30, 12:02:59
12:02:59.780: Browser Hardware Acceleration: true
12:02:59.780: Portable mode: false
12:03:00.188: OBS 27.1.3 (64-bit, windows)
12:03:00.188: ---------------------------------
12:03:00.190: ---------------------------------
12:03:00.190: audio settings reset:
12:03:00.190: samples per sec: 48000
12:03:00.190: speakers: 2
12:03:00.216: ---------------------------------
12:03:00.217: Initializing D3D11...
12:03:00.217: Available Video Adapters:
12:03:00.241: Adapter 0: NVIDIA GeForce GTX 1060
12:03:00.241: Dedicated VRAM: 2051014656
12:03:00.241: Shared VRAM: 4231157760
12:03:00.241: PCI ID: 10de:1c20
12:03:00.241: Driver Version: 27.21.14.6647
12:03:00.241: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=144, name=
12:03:00.241: Adapter 1: Intel(R) UHD Graphics 630
12:03:00.241: Dedicated VRAM: 134217728
12:03:00.241: PCI ID: 8086:3e9b
12:03:00.242: Driver Version: 23.20.16.4974
12:03:00.259: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 (0)
12:03:01.299: D3D11 loaded successfully, feature level used: b000
12:03:01.299: DXGI increase maximum frame latency success
12:03:01.299: D3D11 GPU priority setup failed (not admin?)
12:03:01.797: ---------------------------------
12:03:01.798: video settings reset:
12:03:01.798: base resolution: 1920x1080
12:03:01.798: output resolution: 1280x720
12:03:01.798: downscale filter: Bicubic
12:03:01.798: fps: 30/1
12:03:01.798: format: NV12
12:03:01.798: YUV mode: 709/Partial
12:03:01.798: NV12 texture support enabled
12:03:01.799: Audio monitoring device:
12:03:01.799: name: Default
12:03:01.799: id: default
12:03:01.800: ---------------------------------
12:03:01.843: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
12:03:01.863: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:03:01.880: Failed to load 'en-US' text for module: 'decklink-captions.dll'
12:03:01.898: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
12:03:01.958: [AMF] Unable to load 'amfrt64.dll', error code 126.
12:03:01.960: [AMF] AMF Test failed due to one or more errors.
12:03:01.960: Failed to initialize module 'enc-amf.dll'
12:03:02.122: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
12:03:02.179: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
12:03:02.219: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
12:03:02.266: [obs-browser]: Version 2.16.3
12:03:02.266: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
12:03:02.363: NVENC supported
12:03:02.393: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
I am on windows 11 btw
