Please help with PTZ Controller plug-in!!!
TCStream
Full disclosure.... I am not a techy! We are using OBS for church livestreaming/ We bought a PTZ NDI camera and i am tring to use the PTZ control plug-in. I should get an option for VISCA over IP, but that does not come up as an option. V 0.15.4
Please help this computer illiterate!!
Hello TC Stream: If your PTZ camera supports NDI, and it is connected to the same network as OBS, then an entry should be presented when you add the camera as a source, under Sources (NDI Source). And if the camera is correctly installed, the PTZ Controls plugin might find it automatically, otherwise you would have to specify the IP Address and Port manually.
I hope this helps. . .
