PLEASE HELP! MICROPHONE ISSUE
rmc320
So, I replaced my old reliable Snowball microphone with a Rode Podmic and Scarlett Solo interface and it has been a nightmare lol. When I stream live through OBS, the Microphone will work anywhere from 2-10 minutes and then will cut out. The only way to get the microphone back up and running is to close and restart OBS which obviously kills my live stream. I've searched and searched for a remedy, but no luck so far. Any one heard of this issue or have a fix? Thanks in advance!
Have look at
It contains important hints regarding your audio setup, too. And is self-explanatory.
The wifi connection may have important influence on your issue, too. Wireless uplink connections may suddenly stall during streaming.
Additional: You have two usb cameras and the scarlett via usb too. I assume its a laptop? Be aware of possible bottlenecks by the internal usb hub. Proof if uncabling one of the cameras does help, too.
You have different audio sample rates
OBS set to 48khz
Microphone set to 44khz
Either set OBS to run at 44khz or change your Microphone to 48khz (through windows properties)
