Question / Help *PLEASE HELP ME!* - Rendering problems
Wombatten
Hey, i'm new at using OBS. I really like OBS, but i don't know how to render.. I use Sony Vegas PRO 12. Can some of you guys give me some good render settings, or other programs to render with? I would really appriciate that!
- Wombat
To maintain compatibility between files saved by OBS and NLEs (Non-Linear Editors) like Sony Vegas, make sure that you capture your video with Constant Frame Rate set to On or Yes.
For good settings for local hard drive saves with OBS, here's a guide: viewtopic.php?f=18&t=2972
Other than that, any problems you have with Vegas is probably one you should be asking on Vegas-specific forums.
