Question / Help PLEASE HELP i got 80 - 90 % cpu and less then 20 fps
L3G3-_-BAM
15:18:38.783: CPU Name: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
15:18:38.784: CPU Speed: 2808MHz
15:18:38.784: Physical Cores: 4, Logical Cores: 8
15:18:38.784: Physical Memory: 16252MB Total, 11852MB Free
15:18:38.784: Windows Version: 10.0 Build 16299 (revision: 522; 64-bit)
15:18:38.784: Running as administrator: false
15:18:38.784: Aero is Enabled (Aero is always on for windows 8 and above)
15:18:38.784: Windows 10 Gaming Features:
15:18:38.784: Game DVR: On
15:18:38.789: Sec. Software Status:
15:18:38.792: Windows Defender Antivirus: enabled (AV)
15:18:38.792: Windows Firewall: enabled (FW)
15:18:38.793: Windows Defender Antivirus: enabled (ASW)
15:18:38.794: Portable mode: false
15:18:38.921: OBS 21.1.2 (64bit, windows)
15:18:38.921: ---------------------------------
15:18:38.950: ---------------------------------
15:18:38.950: audio settings reset:
15:18:38.950: samples per sec: 44100
15:18:38.950: speakers: 2
15:18:38.964: ---------------------------------
15:18:38.964: Initializing D3D11...
15:18:38.964: Available Video Adapters:
15:18:38.971: Adapter 1: NVIDIA GeForce GTX 1050
15:18:38.971: Dedicated VRAM: 4216324096
15:18:38.971: Shared VRAM: 4225878016
15:18:38.971: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:18:38.971: Adapter 2: Intel(R) HD Graphics 630
15:18:38.971: Dedicated VRAM: 134217728
15:18:38.974: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 (0)
15:18:39.061: device_create (D3D11): Failed to create device (887A0004)
15:18:39.062: Failed to initialize obs video (-2) with graphics_module='libobs-d3d11.dll', retrying with graphics_module='libobs-opengl.dll'
15:18:39.148: ---------------------------------
15:18:39.148: Initializing OpenGL...
15:18:39.186: OpenGL extension ARB_pixel_format is required
15:18:39.186: gl_platform_create failed
15:18:39.187: device_create (GL) failed
15:18:39.190: Failed to initialize video. Your GPU may not be supported, or your graphics drivers may need to be updated.
15:18:42.424: Freeing OBS context data
15:18:42.428: == Profiler Results =============================
15:18:42.428: run_program_init: 13766.7 ms
15:18:42.428: ┣OBSApp::AppInit: 51.468 ms
15:18:42.428: ┃ ┗OBSApp::InitLocale: 11.317 ms
15:18:42.428: ┗OBSApp::OBSInit: 10434.6 ms
15:18:42.428: ┣obs_startup: 11.599 ms
15:18:42.428: ┗OBSBasic::OBSInit: 266.238 ms
15:18:42.428: ┣OBSBasic::InitBasicConfig: 29.443 ms
15:18:42.428: ┣OBSBasic::ResetAudio: 0.485 ms
15:18:42.428: ┗OBSBasic::ResetVideo: 236.238 ms
15:18:42.428: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.006 ms, max=0.284 ms, 99th percentile=0.204 ms, 100% below 25 ms
15:18:42.428: audio_thread(Audio): min=0 ms, median=0.015 ms, max=0.096 ms, 99th percentile=0.092 ms
15:18:42.428: =================================================
15:18:42.428: == Profiler Time Between Calls ==================
15:18:42.428: obs_hotkey_thread(25 ms): min=24.98 ms, median=25.294 ms, max=26.019 ms, 71.6312% within ±2% of 25 ms (0% lower, 28.3688% higher)
15:18:42.441: Number of memory leaks: 172
this is my obs log wich i copied and paste ... whatever i do i cant seem to fix the cpu and fps so now i cant stream in any way .. i got an elgato hd60 s wich also now wont show my ps4 screen on my tv ...
It's running poorly because OBS is somehow getting forced into using the OpenGL renderer, which has bad performance on Windows. That's probably an indication that your Nvidia drivers are out of date or corrupted. Try downloading the latest drivers, uninstalling your current drivers, restarting, and then installing the new drivers.
For future reference, it's generally best to post a link to your log file (hosted on hastebin.com or pastebin.com) or attach it to your forum post. Posting it inline is a bit harder to read.
hehe thanks :) i really hope it will work though i use directX latest version and all is up to date and still its really going bad
DirectX is not the same as your Nvidia Drivers (or your Intel Drivers, for that matter).
