Question / Help Please Help. First time streamer with Quality problems, etc.
TayTayHD
So I just recently downloaded OBS and ive looked at tutorials but of course everyone's settings will be different depending on their pc specs, internet connection, etc. I have set up everything to capture my WoW and any other gameplay and when I go to preview my stream, the preview stream looks pretty good but it does not look the same when I look up my channel on Twitch.tv. The stream looks terrible, Quality wise and it lags really bad. I am looking at my stream on the laptop im streaming from, not sure if this matters. Now my speed tests shows about 18-20 mbps Download and about 3.14 Upload with about 71 ping. I am trying to stream at 1280 x 720 to have a good looking stream that ppl want to see. Either my Sony Vaio can't handle my stream or my settings are off. Ive seen vids that say to keep your bitrate about halfway down from your max Upload, etc. Well with my 3.16 mbps Upload my setting for bitrate is 1200 & buffer is 1100. I am not sure if these settings are correct but in the end my Preview Stream looks great and my actual Stream looks bad. Also, for PC games like WoW, LoL, etc. should I always use Game capture or Window capture? I play window-mode on WoW so obv I have WoW set up as Window Capture. If I can just figure out why the resolution and lag are so bad then ill be ready to go! Sorry for the long question. If someone could please help, that would be great! Thank you!
SpeedTest:
Download: 18-20 mbps
Upload: 3.14-3.16 mbps
Ping: 71-73 ms
Laptop Specs:
Sony Vaio
Intel(R) Core(TM) i5 CPU M 460 @ 2.53GHz with Turbo Boost
RAM: 4GB
OS: Windows 7 Home Premium 64-bit
Display (Grahpics): ATI Mobility Radeon HD 5650
Monitor (Vaio Screen): Digital Flat Panel (1920x1080 60 Hz)
TayTayHD
Re: Please Help. First time streamer with Quality problems,
This is the most recent log:
12:23:51: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
12:23:51: -------------------------------
12:23:51: CPU Name: Intel(R) Core(TM) i5 CPU M 460 @ 2.53GHz
12:23:51: CPU Speed: 2527MHz
12:23:51: Physical Memory: 3950MB Total, 1143MB Free
12:23:51: stepping id: 5, model 5, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
12:23:51: monitor 1: pos={0, 0}, size={1920, 1080}
12:23:51: Windows Version: 6.1 Build 7600
12:23:51: Aero is Enabled
12:23:51: OBS Modules:
12:23:51: Base Address Module
12:23:51: 00DB0000 OBS.exe
12:23:51: 66580000 OBSApi.dll
12:23:51: 66CA0000 DShowPlugin.dll
12:23:51: 66950000 GraphicsCapture.dll
12:23:51: 66DC0000 NoiseGate.dll
12:23:51: ------------------------------------------
12:23:51: Adapter 1
12:23:51: Video Adapter: ATI Mobility Radeon HD 5650
12:23:51: Video Adapter Dedicated Video Memory: 1063755776
12:23:51: Video Adapter Shared System Memory: 1802553344
12:23:51: =====Stream Start: 2013-05-20, 12:23:51===============================================
12:23:51: Multithreaded optimizations: On
12:23:51: Base resolution: 1920x1080
12:23:51: Output resolution: 1280x720
12:23:51: Loading up D3D10...
12:23:51: Playback device Default
12:23:51: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:23:51: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:23:51: Audio Encoding: AAC
12:23:51: bitrate: 128
12:23:51: Using text output
12:23:52: ------------------------------------------
12:23:52: device: USB 2.0 Camera,
12:23:52: device id \\?\usb#vid_0c45&pid_6464&mi_00#7&18021772&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
12:23:52: chosen type: YUY2, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-2000000, fourCC: 'YUY2'
12:23:52: audio device: Disable,
12:23:52: audio device id Disabled,
12:23:52:
12:23:52: Using directshow input
12:23:52: Using Window Capture
12:23:52: Video Encoding: x264
12:23:52: fps: 30
12:23:52: width: 1280, height: 720
12:23:52: preset: veryfast
12:23:52: CBR: no
12:23:52: CFR: no
12:23:52: max bitrate: 1200
12:23:52: buffer size: 1100
12:23:52: quality: 7
12:24:21: Total frames rendered: 860, number of frames that lagged: 6 (0.70%) (it's okay for some frames to lag)
12:24:21: =====Stream End: 2013-05-20, 12:24:21=================================================
12:24:37: =====Stream Start: 2013-05-20, 12:24:37===============================================
12:24:37: Multithreaded optimizations: On
12:24:37: Base resolution: 1920x1080
12:24:37: Output resolution: 1280x720
12:24:37: ------------------------------------------
12:24:37: Loading up D3D10...
12:24:38: Playback device Default
12:24:38: ------------------------------------------
12:24:38: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:24:38: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:24:38: Audio Encoding: AAC
12:24:38: bitrate: 128
12:24:38: Using text output
12:24:38: Using Window Capture
12:24:38: Video Encoding: x264
12:24:38: fps: 30
12:24:38: width: 1280, height: 720
12:24:38: preset: veryfast
12:24:38: CBR: no
12:24:38: CFR: no
12:24:38: max bitrate: 1200
12:24:38: buffer size: 1100
12:24:38: quality: 7
12:24:39: Total frames rendered: 55, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
12:24:39: =====Stream End: 2013-05-20, 12:24:39=================================================
12:24:48: =====Stream Start: 2013-05-20, 12:24:48===============================================
12:24:48: Multithreaded optimizations: On
12:24:48: Base resolution: 1920x1080
12:24:48: Output resolution: 1280x720
12:24:48: ------------------------------------------
12:24:48: Loading up D3D10...
12:24:48: Playback device Default
12:24:48: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:24:48: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:24:48: Audio Encoding: AAC
12:24:48: bitrate: 128
12:24:48: Using Window Capture
12:24:48: Video Encoding: x264
12:24:48: fps: 30
12:24:48: width: 1280, height: 720
12:24:48: preset: veryfast
12:24:48: CBR: no
12:24:48: CFR: no
12:24:48: max bitrate: 1200
12:24:48: buffer size: 1100
12:24:48: quality: 7
12:24:50: Using RTMP service: Twitch / Justin.tv
12:24:50: Server selection: rtmp://live-mia.justin.tv/app
12:24:52: SO_SNDBUF was at 8192
12:24:52: SO_SNDBUF is now 65536
12:26:15: Total frames rendered: 703, number of frames that lagged: 30 (4.27%) (it's okay for some frames to lag)
12:26:15: okay, this is strange
12:26:15: RTMPPublisher::SocketLoop: Aborting due to loop exit
12:26:15: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
12:26:15: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:26:15: Number of times waited to send: 7, Waited for a total of 21232 bytes
12:26:15: Number of b-frames dropped: 23 (4.1%), Number of p-frames dropped: 23 (4.1%), Total 46 (8.2%)
12:26:15: =====Stream End: 2013-05-20, 12:26:15=================================================
12:26:55: =====Stream Start: 2013-05-20, 12:26:55===============================================
12:26:55: Multithreaded optimizations: On
12:26:55: Base resolution: 1920x1080
12:26:55: Output resolution: 1280x720
12:26:55: ------------------------------------------
12:26:55: Loading up D3D10...
12:26:55: Playback device Default
12:26:55: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:26:55: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:26:55: Audio Encoding: AAC
12:26:55: bitrate: 128
12:26:55: Using Window Capture
12:26:55: Video Encoding: x264
12:26:55: fps: 30
12:26:55: width: 1280, height: 720
12:26:55: preset: veryfast
12:26:55: CBR: no
12:26:55: CFR: no
12:26:55: max bitrate: 1200
12:26:55: buffer size: 1100
12:26:55: quality: 7
12:27:04: Total frames rendered: 249, number of frames that lagged: 53 (21.29%) (it's okay for some frames to lag)
12:27:04: =====Stream End: 2013-05-20, 12:27:04=================================================
12:27:07: =====Stream Start: 2013-05-20, 12:27:07===============================================
12:27:07: Multithreaded optimizations: On
12:27:07: Base resolution: 1920x1080
12:27:07: Output resolution: 1280x720
12:27:07: ------------------------------------------
12:27:07: Loading up D3D10...
12:27:07: Playback device Default
12:27:07: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:27:07: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:27:07: Audio Encoding: AAC
12:27:07: bitrate: 128
12:27:07: Using Window Capture
12:27:07: Video Encoding: x264
12:27:07: fps: 30
12:27:07: width: 1280, height: 720
12:27:07: preset: veryfast
12:27:07: CBR: no
12:27:07: CFR: no
12:27:07: max bitrate: 1200
12:27:07: buffer size: 1100
12:27:07: quality: 7
12:27:08: Using RTMP service: Twitch / Justin.tv
12:27:08: Server selection: rtmp://live-mia.justin.tv/app
12:27:10: SO_SNDBUF was at 8192
12:27:10: SO_SNDBUF is now 65536
12:27:48: Total frames rendered: 732, number of frames that lagged: 53 (7.24%) (it's okay for some frames to lag)
12:27:48: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:27:48: Number of times waited to send: 0, Waited for a total of 0 bytes
12:27:48: Number of b-frames dropped: 21 (3.6%), Number of p-frames dropped: 19 (3.3%), Total 40 (6.9%)
12:27:48: =====Stream End: 2013-05-20, 12:27:48=================================================
12:33:54: =====Stream Start: 2013-05-20, 12:33:54===============================================
12:33:54: Multithreaded optimizations: On
12:33:54: Base resolution: 1920x1080
12:33:54: Output resolution: 1280x720
12:33:54: ------------------------------------------
12:33:54: Loading up D3D10...
12:33:54: Playback device Default
12:33:54: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:33:54: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:33:54: Audio Encoding: AAC
12:33:54: bitrate: 128
12:33:54: Using Window Capture
12:33:54: Video Encoding: x264
12:33:54: fps: 30
12:33:54: width: 1280, height: 720
12:33:54: preset: veryfast
12:33:54: CBR: no
12:33:54: CFR: no
12:33:54: max bitrate: 1200
12:33:54: buffer size: 1100
12:33:54: quality: 7
12:33:56: Using RTMP service: Twitch / Justin.tv
12:33:56: Server selection: rtmp://live-mia.justin.tv/app
12:33:58: SO_SNDBUF was at 8192
12:33:58: SO_SNDBUF is now 65536
12:35:05: RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10053
12:35:08: Total frames rendered: 637, number of frames that lagged: 20 (3.14%) (it's okay for some frames to lag)
12:35:08: librtmp error: WriteN, RTMP send error 10053 (79 bytes)
12:35:08: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:35:08: Number of times waited to send: 2, Waited for a total of 664 bytes
12:35:08: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
12:35:08: =====Stream End: 2013-05-20, 12:35:08=================================================
12:35:19: =====Stream Start: 2013-05-20, 12:35:19===============================================
12:35:19: Multithreaded optimizations: On
12:35:19: Base resolution: 1920x1080
12:35:19: Output resolution: 1280x720
12:35:19: ------------------------------------------
12:35:19: Loading up D3D10...
12:35:19: Playback device Default
12:35:19: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:35:19: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:35:19: Audio Encoding: AAC
12:35:19: bitrate: 128
12:35:19: Using Window Capture
12:35:19: Video Encoding: x264
12:35:19: fps: 30
12:35:19: width: 1280, height: 720
12:35:19: preset: veryfast
12:35:19: CBR: no
12:35:19: CFR: no
12:35:19: max bitrate: 1200
12:35:19: buffer size: 1100
12:35:19: quality: 7
12:35:20: Using RTMP service: Twitch / Justin.tv
12:35:20: Server selection: rtmp://live-mia.justin.tv/app
12:35:22: SO_SNDBUF was at 8192
12:35:22: SO_SNDBUF is now 65536
12:35:23: Total frames rendered: 124, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
12:35:23: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:35:23: Number of times waited to send: 0, Waited for a total of 0 bytes
12:35:23: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
12:35:23: =====Stream End: 2013-05-20, 12:35:23=================================================
12:43:45: =====Stream Start: 2013-05-20, 12:43:45===============================================
12:43:45: Multithreaded optimizations: On
12:43:45: Base resolution: 1920x1080
12:43:45: Output resolution: 1280x720
12:43:45: ------------------------------------------
12:43:45: Loading up D3D10...
12:43:45: Playback device Default
12:43:45: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:43:45: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:43:45: Audio Encoding: AAC
12:43:45: bitrate: 128
12:43:45: Using Window Capture
12:43:45: Video Encoding: x264
12:43:45: fps: 30
12:43:45: width: 1280, height: 720
12:43:45: preset: veryfast
12:43:45: CBR: no
12:43:45: CFR: no
12:43:45: max bitrate: 1200
12:43:45: buffer size: 1100
12:43:45: quality: 7
12:43:46: Using RTMP service: Twitch / Justin.tv
12:43:46: Server selection: rtmp://live-mia.justin.tv/app
12:43:48: SO_SNDBUF was at 8192
12:43:48: SO_SNDBUF is now 65536
12:44:35: RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10053
12:44:35: Total frames rendered: 545, number of frames that lagged: 51 (9.36%) (it's okay for some frames to lag)
12:44:35: librtmp error: WriteN, RTMP send error 10053 (79 bytes)
12:44:35: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:44:35: Number of times waited to send: 2, Waited for a total of 822 bytes
12:44:35: Number of b-frames dropped: 10 (2.4%), Number of p-frames dropped: 27 (6.5%), Total 37 (8.9%)
12:44:35: =====Stream End: 2013-05-20, 12:44:35=================================================
12:44:46: =====Stream Start: 2013-05-20, 12:44:46===============================================
12:44:46: Multithreaded optimizations: On
12:44:46: Base resolution: 1920x1080
12:44:46: Output resolution: 1280x720
12:44:46: ------------------------------------------
12:44:46: Loading up D3D10...
12:44:46: Playback device Default
12:44:46: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:44:46: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:44:46: Audio Encoding: AAC
12:44:46: bitrate: 128
12:44:46: Using Window Capture
12:44:46: Video Encoding: x264
12:44:46: fps: 30
12:44:46: width: 1280, height: 720
12:44:46: preset: veryfast
12:44:46: CBR: no
12:44:46: CFR: no
12:44:46: max bitrate: 1200
12:44:46: buffer size: 1100
12:44:46: quality: 7
12:44:50: Using RTMP service: Twitch / Justin.tv
12:44:50: Server selection: rtmp://live-mia.justin.tv/app
12:44:52: SO_SNDBUF was at 8192
12:44:52: SO_SNDBUF is now 65536
12:45:08: Total frames rendered: 286, number of frames that lagged: 14 (4.90%) (it's okay for some frames to lag)
12:45:08: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:45:08: Number of times waited to send: 0, Waited for a total of 0 bytes
12:45:08: Number of b-frames dropped: 2 (1.4%), Number of p-frames dropped: 0 (0%), Total 2 (1.4%)
12:45:08: =====Stream End: 2013-05-20, 12:45:08=================================================
12:45:28: =====Stream Start: 2013-05-20, 12:45:28===============================================
12:45:28: Multithreaded optimizations: On
12:45:28: Base resolution: 1920x1080
12:45:28: Output resolution: 1280x720
12:45:28: ------------------------------------------
12:45:28: Loading up D3D10...
12:45:28: Playback device Default
12:45:28: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:45:28: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:45:28: Audio Encoding: AAC
12:45:28: bitrate: 128
12:45:28: Using Window Capture
12:45:28: Video Encoding: x264
12:45:28: fps: 30
12:45:28: width: 1280, height: 720
12:45:28: preset: veryfast
12:45:28: CBR: no
12:45:28: CFR: no
12:45:28: max bitrate: 1200
12:45:28: buffer size: 1100
12:45:28: quality: 7
12:45:30: Using RTMP service: Twitch / Justin.tv
12:45:30: Server selection: rtmp://live-mia.justin.tv/app
12:45:31: SO_SNDBUF was at 8192
12:45:31: SO_SNDBUF is now 65536
12:46:16: Total frames rendered: 594, number of frames that lagged: 39 (6.57%) (it's okay for some frames to lag)
12:46:16: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:46:16: Number of times waited to send: 3, Waited for a total of 1196 bytes
12:46:16: Number of b-frames dropped: 18 (4%), Number of p-frames dropped: 26 (5.7%), Total 44 (9.7%)
12:46:16: =====Stream End: 2013-05-20, 12:46:16=================================================
12:46:51: =====Stream Start: 2013-05-20, 12:46:51===============================================
12:46:51: Multithreaded optimizations: On
12:46:51: Base resolution: 1920x1080
12:46:51: Output resolution: 1280x720
12:46:51: ------------------------------------------
12:46:51: Loading up D3D10...
12:46:51: Playback device Default
12:46:51: Using desktop audio input: Speaker/HP (Realtek High Definition Audio)
12:46:51: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:46:51: Audio Encoding: AAC
12:46:51: bitrate: 128
12:46:51: Using Window Capture
12:46:51: Video Encoding: x264
12:46:51: fps: 30
12:46:51: width: 1280, height: 720
12:46:51: preset: veryfast
12:46:51: CBR: no
12:46:51: CFR: no
12:46:51: max bitrate: 1200
12:46:51: buffer size: 1100
12:46:51: quality: 7
12:53:56: Total frames rendered: 12592, number of frames that lagged: 41 (0.33%) (it's okay for some frames to lag)
12:53:56: =====Stream End: 2013-05-20, 12:53:56=================================================
12:54:04:
12:54:04: Profiler results:
12:54:04:
12:54:04: ==============================================================
12:54:04: frame - [100%] [avg time: 19.739 ms] [avg calls per frame: 1] [children: 96.2%] [unaccounted: 3.78%]
12:54:04: | scene->Preprocess - [83.7%] [avg time: 16.524 ms] [avg calls per frame: 1]
12:54:04: | video encoding and uploading - [12.5%] [avg time: 2.469 ms] [avg calls per frame: 1] [children: 12.2%] [unaccounted: 0.289%]
12:54:04: | | CopyResource - [0.076%] [avg time: 0.015 ms] [avg calls per frame: 0]
12:54:04: | | conversion to 4:2:0 - [0.269%] [avg time: 0.053 ms] [avg calls per frame: 0]
12:54:04: | | call to encoder - [11.8%] [avg time: 2.331 ms] [avg calls per frame: 0]
12:54:04: | | sending stuff out - [0.0659%] [avg time: 0.013 ms] [avg calls per frame: 0]
12:54:04:
Here are some short clips:
http://www.twitch.tv/taytayhd/videos?ki ... broadcasts
Sound quality isn't good and I'm noticing that the sound echoes continuously if I'm listening to music or watching something. Not sure why.
Speed Test for testmy.net
Download :: 9 Mbps 1.1 MB/s Upload :: 2.2 Mbps 273 kB/s
This speed test shows worse download & upload speeds then Charter Speed Test. Any reason?
Thank you for your help!
IceVamp
While I'm very new at OBS and streaming in general my self, it seems to me that your CPU is not powerful enough to handle 720p, after checking some benchmarks. It doesn't appear to be that old, but it is a weak dual core CPU.
Using Game Capture instead might work better as well?
Krazy
Town drunk
You should really consider downscaling all the way to 480p. With your CPU + bandwith limitations, you don't really have enough juice to properly do 720p, especially a game like WoW where the full scene is almost constantly in motion. 480p will give your hardware more breathing room, and you should have plenty of bitrate for that resolution.
dodgepong
Administrator
Community Helper
Testmy.net is more accurate than flash-based tests like the ones Charter uses, so I would rely on that more than Charter.
IceVamp is correct...your CPU is on the weak side for streaming, but it could potentially work.
Try these settings:
1000/1000 bit rate
CBR enabled
1920x1080 downscaled x2 to 960x540 (Bilinear)
30fps
If that is still resulting is poor performance, change the downscale to 2.25 (480p), drop the frame rate to 25fps, and maybe even consider changing your preset to superfast.
I do find it interesting that you were dropping frames with 1200 bit rate and a 2.2 Mbps connection, though...are you doing this over wireless?
TayTayHD
Thank you all for the quick replies! Yes dodgepong I am running this over wireless. Also, for the sound echoing, what should I do for that?
dodgepong
Administrator
Community Helper
Mute your stream while streaming so it doesn't loop back.
TayTayHD
You mean mute it in OBS? Because when I do that theres no sound at all. Sorry confused. Also, I think my laptop just sucks. I tried the settings and they work a lot better with lag on the stream, but it just makes my game on my screen lag a bit. The best is 480p atm. It just doesnt look as good as other streamers who stream at 480, 540, etc. So I'm not sure at this point.
dodgepong
Administrator
Community Helper
No, mute your stream on Twitch. It's echoing because you're watching your own stream to see what it looks and sounds like, but then your computer hears your stream and broadcasts it, which continues to loop over and over.
ThoNohT
Developer
If your system is struggling to stream, don't watch it at all on twitch (at least on the same pc). That's unnecessary use of resources that are better spent on the game and livestreaming.
