Question / Help Pixilation and Clarity problems/help
Hei
I have watched many twitch streams to compare the quality but cant seem to get my stream quality to that degree. I have watched many videos for best recommended settings for OBS but i still cant seems to get the quality i am looking for.
Specs
GPU: NVIDIA GeForce GTX 980
CPU: Intel(R) Core(TM) i7-5820k CPU @ 3.30ghz
Ram: 16GB DDR4
Operating system: Windows 64bit
Network specs
OBS settings
Video encoding:
- Encoder x264
- CBR Enabled
- CBR Padding Enabled
- Bitrate 3500
- Buffer Size 3500
Video:
- Base resolution 1920 by 1080 Aspect Ratio: 16:9
- Resolution Downscale 1,50 (1280x720)
- Filter lanczos
- fps 60
Downscale seems to be weird i could just be stupid and be doing it wrong any help on that would be great. - FIXED
Advanced:
-General
- Mutli thread enabled
- Priority class normal
- scene buffer time 400
-Video
- CPU Preset Faster
- encoding profile main
- Keyframe interval 2
- Use CFR Enabled
The rest is just default
Any help Whatsoever would be greatly Appreciated
short clip of stream to show example http://www.twitch.tv/hei_jman/v/27847287
OBS Logs Here
Hei
define "broken"
idk if your familiar with the csgo but the kill feed in the top right and the chat in the bottom are cut off some
