Question / Help Pixelated stream when moving
btw the video is not existing
math example
you have 6.000kbit/s for the picture
compression works with known even more known even smaller
so if you have a no movement 60fps its hiquallity
but even more movement the 6.000Kbits too less so the quallity will decreased von 98% in nomotion
to 80% in slowmotion
and 30% quallity on highmotion
even more % of the 1080P is changing even more bits its need
btw the AMD encoder need a massive move bits/s then x264 or Nvenc from nvidia for the same quality results
if you will hold on the 60fps try 720P but 1080P will not work with 60FPS without blocking on high change rates
