Picture and sound has offset after 1 hour used
jky
OBS Studio Version​
29.0.2
Expected Behavior​
I would like to ask is there any setting that is not done well or is this a problem?
Current Behavior​
I connected the GC553 to the computer and captured the screen
no problem at first
But after about an hour of use, the sound will be cut off for a short time
From then on the video and sound will have a fixed offset
I need to restart OBS to get back to normal
But look at the sound effects section
GC553 output sound effect is normal without fixed deviation
is a fixed offset of the video from the streaming and monitor output
Steps to Reproduce​
  1. Use GC553
  2. After streaming or recording for 1~2 hours
  3. there is a short sound disappearing
  4. If it is not reopened, it will be held continuously, even if the recording is stopped.
Anything else we should know?​
CPU : i7 - 13700
GPU : RTX3060
RAM: DDR5 32G
Board : ROG STRIX B660-I GAMING WIFI
or maybe can watch this video:
