Question / Help Photoshop - OBS Display Capture and Window Capture don't work
lulumon
Hello everyone,
I have a problem with my Photoshop and OBS. I've been reading around and saw that people suggested not using window capture with Photoshop because Window Capture doesn't display the actual canvas. Just the program. Which is true. But the Display Capture doesn't work either.
  • WINDOW CAPTURE
  • DISPLAY CAPTURE
Also my log files:
https://obsproject.com/logs/UOlVKfH69ZpLf4Is
WizardCM
Community Helper
You will need to separately Game Capture the canvas due to how hardware acceleration works in Photoshop.
Likely your Display Capture doesn't work as you're on a laptop (I wouldn't recommend changing settings).
APZ
I have the same problem with Office 365 apps: I get a blank (white) screen with only the cursor visible. PowerPoint works in the 'reading view', but Word and Excel do not work in any view. Outlook and One Note are showing only parts of the screen. PDFs work fine.
