Periodic frame drops? (Didn't have issue on SLOBS)
Mr4
So for my past few streams, I've noticed that I get occasional "blocks" of dropped frames. Sometimes it's less than 100, sometimes it's 200-400ish. It isn't (or rather, shouldn't be) my internet, my internet can handle the settings/bitrate that I have set... I never had this issue on SLOBS. I've gone 6+ hour streams on SLOBS with 0 dropped frames before, and if not 0 than usually something minor and not re-occurring throughout the stream like the current problem.
I'd have to assume it's a setting or something in OBS... I did run the auto-wizard setup when I swapped, and then went through and changed some settings afterwards, not sure if that helps/could be a potential culprit.
I have my most recent stream log linked (which also ended up cutting the vod into 2 parts and missing out on some of the footage, sadly... Not sure if that was a temporary internet lapse or the frame-drop block problem that caused it)... at least I hope they are the two logs from the same 1 stream (but if not hopefully both still help, as I've said it's been the past few anyways)
