Question / Help path of exile no audio and curser problem.
derminion
this is the only game that does this.
http://www.twitch.tv/derminion/b/474177839
obs isn't picking up the sound.
10:36:42: Open Broadcaster Software v0.583b - 64bit ( ^ω^)
10:36:42: -------------------------------
10:36:42: CPU Name: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
10:36:42: CPU Speed: 3600MHz
10:36:42: Physical Memory:  16336MB Total, 12776MB Free
10:36:42: stepping id: 7, model 45, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
10:36:42: monitor 1: pos={0, 0}, size={1920, 1080}
10:36:42: Windows Version: 6.1 Build 7601 S
10:36:42: Aero is Enabled
10:36:42: OBS Modules:
10:36:42: Base Address     Module
10:36:42: 000000003FF60000 OBS.exe
10:36:42: 00000000EB9A0000 OBSApi.dll
10:36:42: 00000000F2D10000 DShowPlugin.dll
10:36:42: 00000000F2CE0000 GraphicsCapture.dll
10:36:42: 00000000F3280000 NoiseGate.dll
10:36:42: 00000000EFD10000 PSVPlugin.dll
10:36:42: ------------------------------------------
10:36:42: Adapter 1
10:36:42:   Video Adapter: NVIDIA GeForce GTX 670
10:36:42:   Video Adapter Dedicated Video Memory: 2087387136
10:36:42:   Video Adapter Shared System Memory: 2147807232
10:36:42:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
10:36:42: =====Stream Start: 2013-10-27, 10:36:42===============================================
10:36:42:   Multithreaded optimizations: On
10:36:42:   Base resolution: 1920x1080
10:36:42:   Output resolution: 1920x1080
10:36:42: Loading up D3D10 on NVIDIA GeForce GTX 670...
10:36:42: Audio Format: 48000hz
10:36:42: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
10:36:42: Using desktop audio input: Speakers (Creative SB X-Fi)
10:36:42: Using 5.1 speaker setup
10:36:42: Audio Encoding: AAC
10:36:42:     bitrate: 192
10:36:42:     device: Dxtory Video 1,
10:36:42:     device id (null),
10:36:42:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
10:36:42:     use buffering: false - 0, fourCC: 00000000
10:36:42:     audio device: Disable,
10:36:42:     audio device id Disabled,
10:36:42:
10:36:42: Using directshow input
10:36:42: Scene buffering time set to 400
10:36:42: Video Encoding: x264
10:36:42:     fps: 30
10:36:42:     width: 1920, height: 1080
10:36:42:     preset: veryfast
10:36:42:     profile: high
10:36:42:     keyint: 60
10:36:42:     CBR: no
10:36:42:     CFR: no
10:36:42:     max bitrate: 6000
10:36:42:     buffer size: 6200
10:36:42:     quality: 7
10:36:42: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
10:42:16: Total frames encoded: 9991, total frames duplicated: 10 (0.10%)
10:42:16: Total frames rendered: 9994, number of late frames: 1 (0.01%) (it's okay for some frames to be late)
10:42:37:
10:42:37: Profiler time results:
10:42:37:
10:42:37: ==============================================================
10:42:37: video thread frame - [100%] [avg time: 1.871 ms] [children: 90.8%] [unaccounted: 9.19%]
10:42:37: | scene->Preprocess - [85.2%] [avg time: 1.594 ms]
10:42:37: | GPU download and conversion - [5.61%] [avg time: 0.105 ms] [children: 5.08%] [unaccounted: 0.534%]
10:42:37: | | flush - [3.42%] [avg time: 0.064 ms]
10:42:37: | | CopyResource - [1.5%] [avg time: 0.028 ms]
10:42:37: | | conversion to 4:2:0 - [0.16%] [avg time: 0.003 ms]
10:42:37: Convert444Threads - [100%] [avg time: 1.138 ms] [children: 99.6%] [unaccounted: 0.439%]
10:42:37: | Convert444toNV12 - [99.6%] [avg time: 1.133 ms]
10:42:37: encoder thread frame - [100%] [avg time: 1.978 ms]
10:42:37:
10:42:37:
10:42:37: Profiler CPU results:
10:42:37:
10:42:37: video thread frame - [cpu time: avg 1.389 ms, total 13884.1 ms] [avg calls per frame: 1]
10:42:37: | scene->Preprocess - [cpu time: avg 1.342 ms, total 13416.1 ms] [avg calls per frame: 1]
10:42:37: | GPU download and conversion - [cpu time: avg 0.017 ms, total 171.603 ms] [avg calls per frame: 1]
10:42:37: | | flush - [cpu time: avg 0.01 ms, total 109.201 ms] [avg calls per frame: 1]
10:42:37: | | CopyResource - [cpu time: avg 0.004 ms, total 46.801 ms] [avg calls per frame: 1]
10:42:37: | | conversion to 4:2:0 - [cpu time: avg 0.001 ms, total 15.601 ms] [avg calls per frame: 1]
10:42:37: Convert444Threads - [cpu time: avg 1.075 ms, total 21465.7 ms] [avg calls per frame: 2]
10:42:37: | Convert444toNV12 - [cpu time: avg 1.07 ms, total 21372.1 ms] [avg calls per frame: 2]
10:42:37: encoder thread frame - [cpu time: avg 1.227 ms, total 12246.1 ms] [avg calls per frame: 1]
10:42:37:
10:42:37: =====Stream End: 2013-10-27, 10:42:37=================================================
10:42:55: =====Stream Start: 2013-10-27, 10:42:55===============================================
10:42:55:   Multithreaded optimizations: On
10:42:55:   Base resolution: 1920x1080
10:42:55:   Output resolution: 1920x1080
10:42:55: ------------------------------------------
10:42:55: Loading up D3D10 on NVIDIA GeForce GTX 670...
10:42:56: ------------------------------------------
10:42:56: Audio Format: 48000hz
10:42:56: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
10:42:56: Using desktop audio input: Speakers (Creative SB X-Fi)
10:42:56: Using 5.1 speaker setup
10:42:56: Audio Encoding: AAC
10:42:56:     bitrate: 192
10:42:56:     device: Dxtory Video 1,
10:42:56:     device id (null),
10:42:56:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
10:42:56:     use buffering: false - 0, fourCC: 00000000
10:42:56:     audio device: Disable,
10:42:56:     audio device id Disabled,
10:42:56:
10:42:56: Using directshow input
10:42:56: Scene buffering time set to 400
10:42:56: Video Encoding: x264
10:42:56:     fps: 30
10:42:56:     width: 1920, height: 1080
10:42:56:     preset: veryfast
10:42:56:     profile: high
10:42:56:     keyint: 60
10:42:56:     CBR: no
10:42:56:     CFR: no
10:42:56:     max bitrate: 6000
10:42:56:     buffer size: 6200
10:42:56:     quality: 7
10:42:56: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
10:43:03: Using RTMP service: Twitch / Justin.tv
10:43:03:   Server selection: rtmp://live.justin.tv/app
10:43:03:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
10:43:03: Total frames encoded: 190, total frames duplicated: 0 (0.00%)
10:43:03: Total frames rendered: 194, number of late frames: 2 (1.03%) (it's okay for some frames to be late)
10:43:03: Completed handshake with rtmp://live.justin.tv/app in 86 ms.
10:43:04: SO_SNDBUF was at 8192
10:43:04: SO_SNDBUF is now 65536
10:43:05: RTMPPublisher::SocketLoop: Graceful loop exit
10:43:05: Average send payload: 1675 bytes, average send interval: 28 ms
10:43:05: Number of times waited to send: 0, Waited for a total of 0 bytes
10:43:05: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
10:43:05: Number of bytes sent: 77053
10:43:05:
10:43:05: Profiler time results:
10:43:05:
10:43:05: ==============================================================
10:43:05: video thread frame - [100%] [avg time: 0.684 ms] [children: 80.6%] [unaccounted: 19.4%]
10:43:05: | scene->Preprocess - [58%] [avg time: 0.397 ms]
10:43:05: | GPU download and conversion - [22.5%] [avg time: 0.154 ms] [children: 18.3%] [unaccounted: 4.24%]
10:43:05: | | flush - [14.3%] [avg time: 0.098 ms]
10:43:05: | | CopyResource - [3.65%] [avg time: 0.025 ms]
10:43:05: | | conversion to 4:2:0 - [0.292%] [avg time: 0.002 ms]
10:43:05: Convert444Threads - [100%] [avg time: 1.205 ms] [children: 99.2%] [unaccounted: 0.83%]
10:43:05: | Convert444toNV12 - [99.2%] [avg time: 1.195 ms]
10:43:05: encoder thread frame - [100%] [avg time: 2.573 ms]
10:43:05:
10:43:05:
10:43:05: Profiler CPU results:
10:43:05:
10:43:05: video thread frame - [cpu time: avg 0.402 ms, total 78 ms] [avg calls per frame: 1]
10:43:05: | scene->Preprocess - [cpu time: avg 0.402 ms, total 78 ms] [avg calls per frame: 1]
10:43:05: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
10:43:05: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
10:43:05: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
10:43:05: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
10:43:05: Convert444Threads - [cpu time: avg 1.22 ms, total 436.802 ms] [avg calls per frame: 2]
10:43:05: | Convert444toNV12 - [cpu time: avg 1.22 ms, total 436.802 ms] [avg calls per frame: 2]
10:43:05: encoder thread frame - [cpu time: avg 1.84 ms, total 327.602 ms] [avg calls per frame: 1]
10:43:05:
10:43:05: =====Stream End: 2013-10-27, 10:43:05=================================================
10:43:46: =====Stream Start: 2013-10-27, 10:43:46===============================================
10:43:46:   Multithreaded optimizations: On
10:43:46:   Base resolution: 1920x1080
10:43:46:   Output resolution: 1920x1080
10:43:46: ------------------------------------------
10:43:46: Loading up D3D10 on NVIDIA GeForce GTX 670...
10:43:46: Audio Format: 48000hz
10:43:46: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
10:43:46: Using desktop audio input: Speakers (Creative SB X-Fi)
10:43:46: Using 5.1 speaker setup
10:43:46: Audio Encoding: AAC
10:43:46:     bitrate: 192
10:43:46:     device: Dxtory Video 1,
10:43:46:     device id (null),
10:43:46:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
10:43:46:     use buffering: false - 0, fourCC: 00000000
10:43:46:     audio device: Disable,
10:43:46:     audio device id Disabled,
10:43:46:
10:43:46: Using directshow input
10:43:46: Scene buffering time set to 400
10:43:46: Video Encoding: x264
10:43:46:     fps: 30
10:43:46:     width: 1920, height: 1080
10:43:46:     preset: veryfast
10:43:46:     profile: high
10:43:46:     keyint: 60
10:43:46:     CBR: no
10:43:46:     CFR: no
10:43:46:     max bitrate: 6000
10:43:46:     buffer size: 6200
10:43:46:     quality: 7
10:43:46: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
10:43:53: Using RTMP service: Twitch / Justin.tv
10:43:53:   Server selection: rtmp://live.justin.tv/app
10:43:53:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
10:43:53: Completed handshake with rtmp://live.justin.tv/app in 89 ms.
10:43:54: SO_SNDBUF was at 8192
10:43:54: SO_SNDBUF is now 65536
10:43:56: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 15 / 792576)
13:00:39: RTMPPublisher::SocketLoop: Stalled for 1513 ms to write 791113 bytes (buffer: 0 / 792576), unstable connection?
13:00:43: RTMPPublisher::SocketLoop: Stalled for 1716 ms to write 790034 bytes (buffer: 0 / 792576), unstable connection?
13:01:08: RTMPPublisher::SocketLoop: Stalled for 2150 ms to write 791024 bytes (buffer: 0 / 792576), unstable connection?
13:01:09: RTMPPublisher::SocketLoop: Stalled for 1533 ms to write 791588 bytes (buffer: 0 / 792576), unstable connection?
13:01:11: RTMPPublisher::SocketLoop: Stalled for 1917 ms to write 791075 bytes (buffer: 0 / 792576), unstable connection?
13:05:30: RTMPPublisher::SocketLoop: Stalled for 2141 ms to write 791151 bytes (buffer: 0 / 792576), unstable connection?
13:10:27: RTMPPublisher::SocketLoop: Stalled for 1542 ms to write 788720 bytes (buffer: 0 / 792576), unstable connection?
13:11:54: RTMPPublisher::SocketLoop: Stalled for 1505 ms to write 707688 bytes (buffer: 0 / 792576), unstable connection?
13:11:57: RTMPPublisher::SocketLoop: Stalled for 1763 ms to write 788701 bytes (buffer: 0 / 792576), unstable connection?
13:11:59: RTMPPublisher::SocketLoop: Stalled for 2527 ms to write 790962 bytes (buffer: 0 / 792576), unstable connection?
13:13:02: RTMPPublisher::SocketLoop: Stalled for 1741 ms to write 790264 bytes (buffer: 0 / 792576), unstable connection?
13:13:06: RTMPPublisher::SocketLoop: Stalled for 2065 ms to write 788861 bytes (buffer: 0 / 792576), unstable connection?
13:13:08: RTMPPublisher::SocketLoop: Stalled for 1829 ms to write 500073 bytes (buffer: 0 / 792576), unstable connection?
13:40:59: RTMPPublisher::SocketLoop: Stalled for 1943 ms to write 788895 bytes (buffer: 0 / 792576), unstable connection?
13:41:02: RTMPPublisher::SocketLoop: Stalled for 3313 ms to write 789894 bytes (buffer: 0 / 792576), unstable connection?
13:41:06: RTMPPublisher::SocketLoop: Stalled for 4592 ms to write 790879 bytes (buffer: 0 / 792576), unstable connection?
13:41:09: RTMPPublisher::SocketLoop: Stalled for 2738 ms to write 792010 bytes (buffer: 0 / 792576), unstable connection?
13:41:12: RTMPPublisher::SocketLoop: Stalled for 2625 ms to write 791830 bytes (buffer: 0 / 792576), unstable connection?
13:41:13: RTMPPublisher::SocketLoop: Stalled for 1656 ms to write 792024 bytes (buffer: 0 / 792576), unstable connection?
13:41:16: RTMPPublisher::SocketLoop: Stalled for 2711 ms to write 791352 bytes (buffer: 0 / 792576), unstable connection?
13:41:19: RTMPPublisher::SocketLoop: Stalled for 3011 ms to write 790533 bytes (buffer: 0 / 792576), unstable connection?
13:41:21: RTMPPublisher::SocketLoop: Stalled for 1997 ms to write 792002 bytes (buffer: 0 / 792576), unstable connection?
13:41:23: RTMPPublisher::SocketLoop: Stalled for 1763 ms to write 790666 bytes (buffer: 0 / 792576), unstable connection?
13:41:25: RTMPPublisher::SocketLoop: Stalled for 1673 ms to write 791394 bytes (buffer: 0 / 792576), unstable connection?
13:41:28: RTMPPublisher::SocketLoop: Stalled for 1540 ms to write 544907 bytes (buffer: 0 / 792576), unstable connection?
13:41:29: RTMPPublisher::SocketLoop: Stalled for 1603 ms to write 790907 bytes (buffer: 0 / 792576), unstable connection?
13:41:42: RTMPPublisher::SocketLoop: Stalled for 1571 ms to write 789484 bytes (buffer: 0 / 792576), unstable connection?
13:41:43: RTMPPublisher::SocketLoop: Stalled for 1734 ms to write 789311 bytes (buffer: 0 / 792576), unstable connection?
13:41:53: RTMPPublisher::SocketLoop: Stalled for 3169 ms to write 792500 bytes (buffer: 0 / 792576), unstable connection?
13:41:59: RTMPPublisher::SocketLoop: Stalled for 2045 ms to write 791798 bytes (buffer: 0 / 792576), unstable connection?
13:42:05: RTMPPublisher::SocketLoop: Stalled for 1983 ms to write 790357 bytes (buffer: 0 / 792576), unstable connection?
13:43:00: RTMPPublisher::SocketLoop: Stalled for 1616 ms to write 504081 bytes (buffer: 0 / 792576), unstable connection?
13:43:10: RTMPPublisher::SocketLoop: Stalled for 2038 ms to write 789505 bytes (buffer: 0 / 792576), unstable connection?
13:43:12: RTMPPublisher::SocketLoop: Stalled for 1578 ms to write 792235 bytes (buffer: 0 / 792576), unstable connection?
13:44:25: RTMPPublisher::SocketLoop: Stalled for 2059 ms to write 791117 bytes (buffer: 0 / 792576), unstable connection?
14:02:16: RTMPPublisher::SocketLoop: Stalled for 1658 ms to write 788756 bytes (buffer: 0 / 792576), unstable connection?
14:02:18: RTMPPublisher::SocketLoop: Stalled for 1743 ms to write 791156 bytes (buffer: 0 / 792576), unstable connection?
14:02:21: RTMPPublisher::SocketLoop: Stalled for 2005 ms to write 789436 bytes (buffer: 0 / 792576), unstable connection?
14:02:25: RTMPPublisher::SocketLoop: Stalled for 2587 ms to write 792092 bytes (buffer: 0 / 792576), unstable connection?
14:02:27: RTMPPublisher::SocketLoop: Stalled for 1519 ms to write 623822 bytes (buffer: 0 / 792576), unstable connection?
14:02:29: RTMPPublisher::SocketLoop: Stalled for 2431 ms to write 791154 bytes (buffer: 0 / 792576), unstable connection?
14:02:42: RTMPPublisher::SocketLoop: Stalled for 1526 ms to write 792439 bytes (buffer: 0 / 792576), unstable connection?
14:02:52: RTMPPublisher::SocketLoop: Stalled for 2225 ms to write 792441 bytes (buffer: 0 / 792576), unstable connection?
14:02:59: RTMPPublisher::SocketLoop: Stalled for 1805 ms to write 790101 bytes (buffer: 0 / 792576), unstable connection?
14:03:03: RTMPPublisher::SocketLoop: Stalled for 1991 ms to write 792141 bytes (buffer: 0 / 792576), unstable connection?
14:56:59: Total frames encoded: 455780, total frames duplicated: 16 (0.00%)
14:56:59: Total frames rendered: 455781, number of late frames: 3 (0.00%) (it's okay for some frames to be late)
14:57:06: RTMPPublisher::SocketLoop: Graceful loop exit
14:57:06: Average send payload: 11263 bytes, average send interval: 24 ms
14:57:06: Number of times waited to send: 153, Waited for a total of 587257 bytes
14:57:06: Number of b-frames dropped: 504 (0.11%), Number of p-frames dropped: 1080 (0.24%), Total 1584 (0.35%)
14:57:06: Number of bytes sent: 7097388159
14:57:06:
14:57:06: Profiler time results:
14:57:06:
14:57:06: ==============================================================
14:57:06: video thread frame - [100%] [avg time: 3.027 ms] [children: 93.7%] [unaccounted: 6.34%]
14:57:06: | scene->Preprocess - [86.7%] [avg time: 2.623 ms]
14:57:06: | GPU download and conversion - [7%] [avg time: 0.212 ms] [children: 3.73%] [unaccounted: 3.27%]
14:57:06: | | flush - [2.58%] [avg time: 0.078 ms]
14:57:06: | | CopyResource - [1.02%] [avg time: 0.031 ms]
14:57:06: | | conversion to 4:2:0 - [0.132%] [avg time: 0.004 ms]
14:57:06: Convert444Threads - [100%] [avg time: 1.291 ms] [children: 99.4%] [unaccounted: 0.62%]
14:57:06: | Convert444toNV12 - [99.4%] [avg time: 1.283 ms]
14:57:06: encoder thread frame - [100%] [avg time: 2.267 ms]
14:57:06:
14:57:06:
14:57:06: Profiler CPU results:
14:57:06:
14:57:06: video thread frame - [cpu time: avg 2.387 ms, total 1.08795e+006 ms] [avg calls per frame: 1]
14:57:06: | scene->Preprocess - [cpu time: avg 2.168 ms, total 988204 ms] [avg calls per frame: 1]
14:57:06: | GPU download and conversion - [cpu time: avg 0.102 ms, total 46550.7 ms] [avg calls per frame: 1]
14:57:06: | | flush - [cpu time: avg 0.066 ms, total 30092.6 ms] [avg calls per frame: 1]
14:57:06: | | CopyResource - [cpu time: avg 0.025 ms, total 11450.5 ms] [avg calls per frame: 1]
14:57:06: | | conversion to 4:2:0 - [cpu time: avg 0.003 ms, total 1419.6 ms] [avg calls per frame: 1]
14:57:06: Convert444Threads - [cpu time: avg 1.284 ms, total 1.17073e+006 ms] [avg calls per frame: 2]
14:57:06: | Convert444toNV12 - [cpu time: avg 1.279 ms, total 1.16615e+006 ms] [avg calls per frame: 2]
14:57:06: encoder thread frame - [cpu time: avg 1.594 ms, total 726700 ms] [avg calls per frame: 1]
14:57:06:
14:57:06: =====Stream End: 2013-10-27, 14:57:06=================================================
15:05:12: =====Stream Start: 2013-10-27, 15:05:12===============================================
15:05:12:   Multithreaded optimizations: On
15:05:12:   Base resolution: 1920x1080
15:05:12:   Output resolution: 1920x1080
15:05:12: ------------------------------------------
15:05:12: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:05:12: Audio Format: 48000hz
15:05:12: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:05:12: Using desktop audio input: Speakers (Creative SB X-Fi)
15:05:12: Using 5.1 speaker setup
15:05:12: Audio Encoding: AAC
15:05:12:     bitrate: 192
15:05:12:     device: Dxtory Video 1,
15:05:12:     device id (null),
15:05:12:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:05:12:     use buffering: false - 0, fourCC: 00000000
15:05:12:     audio device: Disable,
15:05:12:     audio device id Disabled,
15:05:12:
15:05:12: Using directshow input
15:05:12: Scene buffering time set to 400
15:05:12: Video Encoding: x264
15:05:12:     fps: 30
15:05:12:     width: 1920, height: 1080
15:05:12:     preset: veryfast
15:05:12:     profile: high
15:05:12:     keyint: 60
15:05:12:     CBR: no
15:05:12:     CFR: no
15:05:12:     max bitrate: 6000
15:05:12:     buffer size: 6200
15:05:12:     quality: 7
15:05:12: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:05:19: Using RTMP service: Twitch / Justin.tv
15:05:19:   Server selection: rtmp://live.justin.tv/app
15:05:19:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
15:05:19: Completed handshake with rtmp://live.justin.tv/app in 107 ms.
15:05:20: SO_SNDBUF was at 8192
15:05:20: SO_SNDBUF is now 65536
15:05:22: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 792576)
15:06:09: Total frames encoded: 1700, total frames duplicated: 4 (0.24%)
15:06:09: Total frames rendered: 1703, number of late frames: 2 (0.12%) (it's okay for some frames to be late)
15:06:11: RTMPPublisher::SocketLoop: Graceful loop exit
15:06:12: Average send payload: 15051 bytes, average send interval: 43 ms
15:06:12: Number of times waited to send: 0, Waited for a total of 0 bytes
15:06:12: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:06:12: Number of bytes sent: 17971702
15:06:12:
15:06:12: Profiler time results:
15:06:12:
15:06:12: ==============================================================
15:06:12: video thread frame - [100%] [avg time: 3.05 ms] [children: 94.5%] [unaccounted: 5.54%]
15:06:12: | scene->Preprocess - [88.8%] [avg time: 2.707 ms]
15:06:12: | GPU download and conversion - [5.7%] [avg time: 0.174 ms] [children: 3.31%] [unaccounted: 2.39%]
15:06:12: | | flush - [2.1%] [avg time: 0.064 ms]
15:06:12: | | CopyResource - [0.984%] [avg time: 0.03 ms]
15:06:12: | | conversion to 4:2:0 - [0.23%] [avg time: 0.007 ms]
15:06:12: Convert444Threads - [100%] [avg time: 1.271 ms] [children: 98.3%] [unaccounted: 1.73%]
15:06:12: | Convert444toNV12 - [98.3%] [avg time: 1.249 ms]
15:06:12: encoder thread frame - [100%] [avg time: 1.936 ms]
15:06:12:
15:06:12:
15:06:12: Profiler CPU results:
15:06:12:
15:06:12: video thread frame - [cpu time: avg 2.39 ms, total 4071.63 ms] [avg calls per frame: 1]
15:06:12: | scene->Preprocess - [cpu time: avg 2.235 ms, total 3806.43 ms] [avg calls per frame: 1]
15:06:12: | GPU download and conversion - [cpu time: avg 0.082 ms, total 140.401 ms] [avg calls per frame: 1]
15:06:12: | | flush - [cpu time: avg 0.045 ms, total 78.001 ms] [avg calls per frame: 1]
15:06:12: | | CopyResource - [cpu time: avg 0.018 ms, total 31.2 ms] [avg calls per frame: 1]
15:06:12: | | conversion to 4:2:0 - [cpu time: avg 0.009 ms, total 15.6 ms] [avg calls per frame: 1]
15:06:12: Convert444Threads - [cpu time: avg 1.216 ms, total 4102.83 ms] [avg calls per frame: 2]
15:06:12: | Convert444toNV12 - [cpu time: avg 1.206 ms, total 4071.63 ms] [avg calls per frame: 2]
15:06:12: encoder thread frame - [cpu time: avg 1.145 ms, total 1934.41 ms] [avg calls per frame: 1]
15:06:12:
15:06:12: =====Stream End: 2013-10-27, 15:06:12=================================================
15:10:05: =====Stream Start: 2013-10-27, 15:10:05===============================================
15:10:05:   Multithreaded optimizations: On
15:10:05:   Base resolution: 1920x1080
15:10:05:   Output resolution: 1920x1080
15:10:05: ------------------------------------------
15:10:05: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:10:05: Audio Format: 48000hz
15:10:05: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:10:05: Using desktop audio input: Speakers (Creative SB X-Fi)
15:10:05: Using 5.1 speaker setup
15:10:05: Using auxilary audio input: Microphone (Samson C03U              )
15:10:05: Audio Encoding: AAC
15:10:05:     bitrate: 192
15:10:05:     device: Dxtory Video 1,
15:10:05:     device id (null),
15:10:05:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:10:05:     use buffering: false - 0, fourCC: 00000000
15:10:05:     audio device: Disable,
15:10:05:     audio device id Disabled,
15:10:05:
15:10:05: Using directshow input
15:10:05: Scene buffering time set to 400
15:10:05: Video Encoding: x264
15:10:05:     fps: 30
15:10:05:     width: 1920, height: 1080
15:10:05:     preset: veryfast
15:10:05:     profile: high
15:10:05:     keyint: 60
15:10:05:     CBR: no
15:10:05:     CFR: no
15:10:05:     max bitrate: 6000
15:10:05:     buffer size: 6200
15:10:05:     quality: 7
15:10:05: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:10:05: MMDeviceAudioSource: Frequency for device 'Microphone (Samson C03U              )' is 352800, samples per sec is 44100
15:10:12: Using RTMP service: Twitch / Justin.tv
15:10:12:   Server selection: rtmp://live.justin.tv/app
15:10:12:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
15:10:12: Completed handshake with rtmp://live.justin.tv/app in 105 ms.
15:10:13: SO_SNDBUF was at 8192
15:10:13: SO_SNDBUF is now 65536
15:10:14: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 14394 / 792576)
15:10:14: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 535 / 792576)
15:10:48: Total frames encoded: 1269, total frames duplicated: 0 (0.00%)
15:10:48: Total frames rendered: 1274, number of late frames: 1 (0.08%) (it's okay for some frames to be late)
15:10:50: RTMPPublisher::SocketLoop: Graceful loop exit
15:10:50: Average send payload: 9497 bytes, average send interval: 20 ms
15:10:50: Number of times waited to send: 0, Waited for a total of 0 bytes
15:10:50: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:10:50: Number of bytes sent: 16659406
15:10:50:
15:10:50: Profiler time results:
15:10:50:
15:10:50: ==============================================================
15:10:50: video thread frame - [100%] [avg time: 3.483 ms] [children: 81.1%] [unaccounted: 18.9%]
15:10:50: | scene->Preprocess - [78.6%] [avg time: 2.739 ms]
15:10:50: | GPU download and conversion - [2.5%] [avg time: 0.087 ms] [children: 1.95%] [unaccounted: 0.546%]
15:10:50: | | flush - [1.23%] [avg time: 0.043 ms]
15:10:50: | | CopyResource - [0.632%] [avg time: 0.022 ms]
15:10:50: | | conversion to 4:2:0 - [0.0861%] [avg time: 0.003 ms]
15:10:50: Convert444Threads - [100%] [avg time: 1.186 ms] [children: 99.5%] [unaccounted: 0.506%]
15:10:50: | Convert444toNV12 - [99.5%] [avg time: 1.18 ms]
15:10:50: encoder thread frame - [100%] [avg time: 3.651 ms]
15:10:50:
15:10:50:
15:10:50: Profiler CPU results:
15:10:50:
15:10:50: video thread frame - [cpu time: avg 2.889 ms, total 3681.62 ms] [avg calls per frame: 1]
15:10:50: | scene->Preprocess - [cpu time: avg 2.142 ms, total 2730.02 ms] [avg calls per frame: 1]
15:10:50: | GPU download and conversion - [cpu time: avg 0.097 ms, total 124.801 ms] [avg calls per frame: 1]
15:10:50: | | flush - [cpu time: avg 0.073 ms, total 93.601 ms] [avg calls per frame: 1]
15:10:50: | | CopyResource - [cpu time: avg 0.024 ms, total 31.2 ms] [avg calls per frame: 1]
15:10:50: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:10:50: Convert444Threads - [cpu time: avg 1.24 ms, total 3120.02 ms] [avg calls per frame: 2]
15:10:50: | Convert444toNV12 - [cpu time: avg 1.24 ms, total 3120.02 ms] [avg calls per frame: 2]
15:10:50: encoder thread frame - [cpu time: avg 3.549 ms, total 4461.63 ms] [avg calls per frame: 1]
15:10:50:
15:10:50: =====Stream End: 2013-10-27, 15:10:50=================================================
15:13:38: =====Stream Start: 2013-10-27, 15:13:38===============================================
15:13:38:   Multithreaded optimizations: On
15:13:38:   Base resolution: 1920x1080
15:13:38:   Output resolution: 1920x1080
15:13:38: ------------------------------------------
15:13:38: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:13:38: Audio Format: 48000hz
15:13:38: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:13:38: Using desktop audio input: Speakers (Creative SB X-Fi)
15:13:38: Using 5.1 speaker setup
15:13:38: Using auxilary audio input: Microphone (Samson C03U              )
15:13:38: Audio Encoding: AAC
15:13:38:     bitrate: 192
15:13:38:     device: Dxtory Video 1,
15:13:38:     device id (null),
15:13:38:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:13:38:     use buffering: false - 0, fourCC: 00000000
15:13:38:     audio device: Disable,
15:13:38:     audio device id Disabled,
15:13:38:
15:13:38: Using directshow input
15:13:38: Scene buffering time set to 400
15:13:38: Video Encoding: x264
15:13:38:     fps: 30
15:13:38:     width: 1920, height: 1080
15:13:38:     preset: veryfast
15:13:38:     profile: high
15:13:38:     keyint: 60
15:13:38:     CBR: no
15:13:38:     CFR: no
15:13:38:     max bitrate: 6000
15:13:38:     buffer size: 6200
15:13:38:     quality: 7
15:13:38: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:13:38: MMDeviceAudioSource: Frequency for device 'Microphone (Samson C03U              )' is 352800, samples per sec is 44100
15:13:45: Using RTMP service: Twitch / Justin.tv
15:13:45:   Server selection: rtmp://live.justin.tv/app
15:13:45:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
15:13:45: Completed handshake with rtmp://live.justin.tv/app in 103 ms.
15:13:46: SO_SNDBUF was at 8192
15:13:46: SO_SNDBUF is now 65536
15:13:46: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 28422 / 792576)
15:13:46: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 55175 / 792576)
15:14:17: Using graphics capture
15:14:25: SharedTexCapture hooked
15:14:37: Using Window Capture
15:14:52: Total frames encoded: 2195, total frames duplicated: 0 (0.00%)
15:14:52: Total frames rendered: 2200, number of late frames: 1 (0.05%) (it's okay for some frames to be late)
15:14:53: RTMPPublisher::SocketLoop: Graceful loop exit
15:14:53: Average send payload: 11781 bytes, average send interval: 24 ms
15:14:53: Number of times waited to send: 0, Waited for a total of 0 bytes
15:14:53: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:14:53: Number of bytes sent: 31669660
15:14:53:
15:14:53: Profiler time results:
15:14:53:
15:14:53: ==============================================================
15:14:53: video thread frame - [100%] [avg time: 3.83 ms] [children: 77.9%] [unaccounted: 22.1%]
15:14:53: | scene->Preprocess - [75.4%] [avg time: 2.886 ms]
15:14:53: | GPU download and conversion - [2.53%] [avg time: 0.097 ms] [children: 1.93%] [unaccounted: 0.601%]
15:14:53: | | flush - [1.15%] [avg time: 0.044 ms]
15:14:53: | | CopyResource - [0.574%] [avg time: 0.022 ms]
15:14:53: | | conversion to 4:2:0 - [0.209%] [avg time: 0.008 ms]
15:14:53: Convert444Threads - [100%] [avg time: 1.401 ms] [children: 99.4%] [unaccounted: 0.571%]
15:14:53: | Convert444toNV12 - [99.4%] [avg time: 1.393 ms]
15:14:53: encoder thread frame - [100%] [avg time: 2.006 ms]
15:14:53:
15:14:53:
15:14:53: Profiler CPU results:
15:14:53:
15:14:53: video thread frame - [cpu time: avg 3.141 ms, total 6910.84 ms] [avg calls per frame: 1]
15:14:53: | scene->Preprocess - [cpu time: avg 2.162 ms, total 4758.03 ms] [avg calls per frame: 1]
15:14:53: | GPU download and conversion - [cpu time: avg 0.099 ms, total 218.401 ms] [avg calls per frame: 1]
15:14:53: | | flush - [cpu time: avg 0.056 ms, total 124.8 ms] [avg calls per frame: 1]
15:14:53: | | CopyResource - [cpu time: avg 0.035 ms, total 78 ms] [avg calls per frame: 1]
15:14:53: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:14:53: Convert444Threads - [cpu time: avg 1.428 ms, total 6240.04 ms] [avg calls per frame: 2]
15:14:53: | Convert444toNV12 - [cpu time: avg 1.428 ms, total 6240.04 ms] [avg calls per frame: 2]
15:14:53: encoder thread frame - [cpu time: avg 1.314 ms, total 2870.42 ms] [avg calls per frame: 1]
15:14:53:
15:14:53: =====Stream End: 2013-10-27, 15:14:53=================================================
15:15:07: =====Stream Start: 2013-10-27, 15:15:07===============================================
15:15:07:   Multithreaded optimizations: On
15:15:07:   Base resolution: 1920x1080
15:15:07:   Output resolution: 1920x1080
15:15:07: ------------------------------------------
15:15:07: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:15:07: Audio Format: 48000hz
15:15:07: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:15:07: Using desktop audio input: Speakers (Creative SB X-Fi)
15:15:07: Using 5.1 speaker setup
15:15:07: Using auxilary audio input: Microphone (Samson C03U              )
15:15:07: Audio Encoding: AAC
15:15:07:     bitrate: 160
15:15:07:     device: Dxtory Video 1,
15:15:07:     device id (null),
15:15:07:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:15:07:     use buffering: false - 0, fourCC: 00000000
15:15:07:     audio device: Disable,
15:15:07:     audio device id Disabled,
15:15:07:
15:15:07: Using directshow input
15:15:07: Scene buffering time set to 400
15:15:07: Video Encoding: x264
15:15:07:     fps: 30
15:15:07:     width: 1920, height: 1080
15:15:07:     preset: veryfast
15:15:07:     profile: high
15:15:07:     keyint: 60
15:15:07:     CBR: no
15:15:07:     CFR: no
15:15:07:     max bitrate: 6000
15:15:07:     buffer size: 6200
15:15:07:     quality: 7
15:15:07: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:15:07: MMDeviceAudioSource: Frequency for device 'Microphone (Samson C03U              )' is 352800, samples per sec is 44100
15:15:14: Using RTMP service: Twitch / Justin.tv
15:15:14:   Server selection: rtmp://live.justin.tv/app
15:15:14:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
15:15:14: Completed handshake with rtmp://live.justin.tv/app in 104 ms.
15:15:15: SO_SNDBUF was at 8192
15:15:15: SO_SNDBUF is now 65536
15:15:16: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 732 / 788480)
15:15:16: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 10774 / 788480)
15:15:20: Total frames encoded: 358, total frames duplicated: 0 (0.00%)
15:15:20: Total frames rendered: 363, number of late frames: 1 (0.28%) (it's okay for some frames to be late)
15:15:21: RTMPPublisher::SocketLoop: Graceful loop exit
15:15:21: Average send payload: 12895 bytes, average send interval: 16 ms
15:15:21: Number of times waited to send: 0, Waited for a total of 0 bytes
15:15:21: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:15:21: Number of bytes sent: 4345879
15:15:21:
15:15:21: Profiler time results:
15:15:21:
15:15:21: ==============================================================
15:15:21: video thread frame - [100%] [avg time: 3.851 ms] [children: 78.3%] [unaccounted: 21.7%]
15:15:21: | scene->Preprocess - [76.1%] [avg time: 2.931 ms]
15:15:21: | GPU download and conversion - [2.16%] [avg time: 0.083 ms] [children: 1.56%] [unaccounted: 0.597%]
15:15:21: | | flush - [0.987%] [avg time: 0.038 ms]
15:15:21: | | CopyResource - [0.519%] [avg time: 0.02 ms]
15:15:21: | | conversion to 4:2:0 - [0.0519%] [avg time: 0.002 ms]
15:15:21: Convert444Threads - [100%] [avg time: 1.209 ms] [children: 99.2%] [unaccounted: 0.827%]
15:15:21: | Convert444toNV12 - [99.2%] [avg time: 1.199 ms]
15:15:21: encoder thread frame - [100%] [avg time: 2.558 ms]
15:15:21:
15:15:21:
15:15:21: Profiler CPU results:
15:15:21:
15:15:21: video thread frame - [cpu time: avg 3.566 ms, total 1294.81 ms] [avg calls per frame: 1]
15:15:21: | scene->Preprocess - [cpu time: avg 2.492 ms, total 904.805 ms] [avg calls per frame: 1]
15:15:21: | GPU download and conversion - [cpu time: avg 0.128 ms, total 46.8 ms] [avg calls per frame: 1]
15:15:21: | | flush - [cpu time: avg 0.042 ms, total 15.6 ms] [avg calls per frame: 1]
15:15:21: | | CopyResource - [cpu time: avg 0.044 ms, total 15.6 ms] [avg calls per frame: 1]
15:15:21: | | conversion to 4:2:0 - [cpu time: avg 0.044 ms, total 15.6 ms] [avg calls per frame: 1]
15:15:21: Convert444Threads - [cpu time: avg 1.034 ms, total 717.604 ms] [avg calls per frame: 2]
15:15:21: | Convert444toNV12 - [cpu time: avg 1.034 ms, total 717.604 ms] [avg calls per frame: 2]
15:15:21: encoder thread frame - [cpu time: avg 1.893 ms, total 655.204 ms] [avg calls per frame: 1]
15:15:21:
15:15:21: =====Stream End: 2013-10-27, 15:15:21=================================================
15:15:22: =====Stream Start: 2013-10-27, 15:15:22===============================================
15:15:22:   Multithreaded optimizations: On
15:15:22:   Base resolution: 1920x1080
15:15:22:   Output resolution: 1920x1080
15:15:22: ------------------------------------------
15:15:22: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:15:22: Audio Format: 48000hz
15:15:22: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:15:22: Using desktop audio input: Speakers (Creative SB X-Fi)
15:15:22: Using 5.1 speaker setup
15:15:22: Using auxilary audio input: Microphone (Samson C03U              )
15:15:22: Audio Encoding: AAC
15:15:22:     bitrate: 160
15:15:22:     device: Dxtory Video 1,
15:15:22:     device id (null),
15:15:22:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:15:22:     use buffering: false - 0, fourCC: 00000000
15:15:22:     audio device: Disable,
15:15:22:     audio device id Disabled,
15:15:22:
15:15:22: Using directshow input
15:15:22: Scene buffering time set to 400
15:15:22: Video Encoding: x264
15:15:22:     fps: 30
15:15:22:     width: 1920, height: 1080
15:15:22:     preset: veryfast
15:15:22:     profile: high
15:15:22:     keyint: 60
15:15:22:     CBR: no
15:15:22:     CFR: no
15:15:22:     max bitrate: 6000
15:15:22:     buffer size: 6200
15:15:22:     quality: 7
15:15:22: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:15:22: MMDeviceAudioSource: Frequency for device 'Microphone (Samson C03U              )' is 352800, samples per sec is 44100
15:15:37: ------------------------------------------
15:15:37:     device: Dxtory Video 1,
15:15:37:     device id (null),
15:15:37:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:15:37:     use buffering: false - 0, fourCC: 00000000
15:15:37:     audio device: Microphone (Samson C03U        ,
15:15:37:     audio device id (null),
15:15:37:
15:15:37:     device audio info - bits per sample: 16, channels: 2, samples per sec: 44100, block size: 4
15:15:55: ------------------------------------------
15:15:55:     device: Dxtory Video 1,
15:15:55:     device id (null),
15:15:55:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:15:55:     use buffering: false - 0, fourCC: 00000000
15:15:55:     audio device: Disable,
15:15:55:     audio device id Disabled,
15:15:55:
15:20:08: Total frames encoded: 8560, total frames duplicated: 7 (0.08%)
15:20:08: Total frames rendered: 8564, number of late frames: 2 (0.02%) (it's okay for some frames to be late)
15:20:08:
15:20:08: Profiler time results:
15:20:08:
15:20:08: ==============================================================
15:20:08: video thread frame - [100%] [avg time: 3.157 ms] [children: 88.9%] [unaccounted: 11.1%]
15:20:08: | scene->Preprocess - [86%] [avg time: 2.714 ms]
15:20:08: | GPU download and conversion - [2.88%] [avg time: 0.091 ms] [children: 2.57%] [unaccounted: 0.317%]
15:20:08: | | flush - [1.62%] [avg time: 0.051 ms]
15:20:08: | | CopyResource - [0.824%] [avg time: 0.026 ms]
15:20:08: | | conversion to 4:2:0 - [0.127%] [avg time: 0.004 ms]
15:20:08: Convert444Threads - [100%] [avg time: 1.14 ms] [children: 99.4%] [unaccounted: 0.614%]
15:20:08: | Convert444toNV12 - [99.4%] [avg time: 1.133 ms]
15:20:08: encoder thread frame - [100%] [avg time: 2.726 ms]
15:20:08:
15:20:08:
15:20:08: Profiler CPU results:
15:20:08:
15:20:08: video thread frame - [cpu time: avg 2.637 ms, total 22588.9 ms] [avg calls per frame: 1]
15:20:08: | scene->Preprocess - [cpu time: avg 2.142 ms, total 18345.7 ms] [avg calls per frame: 1]
15:20:08: | GPU download and conversion - [cpu time: avg 0.123 ms, total 1060.81 ms] [avg calls per frame: 1]
15:20:08: | | flush - [cpu time: avg 0.072 ms, total 624.006 ms] [avg calls per frame: 1]
15:20:08: | | CopyResource - [cpu time: avg 0.034 ms, total 296.405 ms] [avg calls per frame: 1]
15:20:08: | | conversion to 4:2:0 - [cpu time: avg 0.009 ms, total 78 ms] [avg calls per frame: 1]
15:20:08: Convert444Threads - [cpu time: avg 1.16 ms, total 19843.3 ms] [avg calls per frame: 2]
15:20:08: | Convert444toNV12 - [cpu time: avg 1.153 ms, total 19718.5 ms] [avg calls per frame: 2]
15:20:08: encoder thread frame - [cpu time: avg 2.149 ms, total 18376.9 ms] [avg calls per frame: 1]
15:20:08:
15:20:08: =====Stream End: 2013-10-27, 15:20:08=================================================
15:23:18: =====Stream Start: 2013-10-27, 15:23:18===============================================
15:23:18:   Multithreaded optimizations: On
15:23:18:   Base resolution: 1920x1080
15:23:18:   Output resolution: 1920x1080
15:23:18: ------------------------------------------
15:23:18: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:23:18: Audio Format: 48000hz
15:23:18: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:23:18: Using desktop audio input: Speakers (Creative SB X-Fi)
15:23:18: Using 5.1 speaker setup
15:23:18: Using auxilary audio input: Microphone (Samson C03U              )
15:23:18: Audio Encoding: AAC
15:23:18:     bitrate: 192
15:23:18:     device: Dxtory Video 1,
15:23:18:     device id (null),
15:23:18:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:23:18:     use buffering: false - 0, fourCC: 00000000
15:23:18:     audio device: Disable,
15:23:18:     audio device id Disabled,
15:23:18:
15:23:19: Using directshow input
15:23:19: Scene buffering time set to 400
15:23:19: ------------------------------------------
15:23:19: Video Encoding: x264
15:23:19:     fps: 30
15:23:19:     width: 1920, height: 1080
15:23:19:     preset: veryfast
15:23:19:     profile: high
15:23:19:     keyint: 60
15:23:19:     CBR: no
15:23:19:     CFR: no
15:23:19:     max bitrate: 6000
15:23:19:     buffer size: 6200
15:23:19:     quality: 7
15:23:19: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:23:19: MMDeviceAudioSource: Frequency for device 'Microphone (Samson C03U              )' is 352800, samples per sec is 44100
Warning -- MMDeviceAudioSource::GetBuffer: GetNextPacketSize failed, result = 88890004
15:32:10: Total frames encoded: 15919, total frames duplicated: 24 (0.15%)
15:32:10: Total frames rendered: 15924, number of late frames: 1 (0.01%) (it's okay for some frames to be late)
15:32:10:
15:32:10: Profiler time results:
15:32:10:
15:32:10: ==============================================================
15:32:10: video thread frame - [100%] [avg time: 2.594 ms] [children: 91%] [unaccounted: 8.98%]
15:32:10: | scene->Preprocess - [87.7%] [avg time: 2.274 ms]
15:32:10: | GPU download and conversion - [3.35%] [avg time: 0.087 ms] [children: 2.97%] [unaccounted: 0.386%]
15:32:10: | | flush - [1.93%] [avg time: 0.05 ms]
15:32:10: | | CopyResource - [0.887%] [avg time: 0.023 ms]
15:32:10: | | conversion to 4:2:0 - [0.154%] [avg time: 0.004 ms]
15:32:10: Convert444Threads - [100%] [avg time: 1.157 ms] [children: 99.5%] [unaccounted: 0.519%]
15:32:10: | Convert444toNV12 - [99.5%] [avg time: 1.151 ms]
15:32:10: encoder thread frame - [100%] [avg time: 2.074 ms]
15:32:10:
15:32:10:
15:32:10: Profiler CPU results:
15:32:10:
15:32:10: video thread frame - [cpu time: avg 2.033 ms, total 32385.8 ms] [avg calls per frame: 1]
15:32:10: | scene->Preprocess - [cpu time: avg 1.936 ms, total 30841.4 ms] [avg calls per frame: 1]
15:32:10: | GPU download and conversion - [cpu time: avg 0.018 ms, total 296.401 ms] [avg calls per frame: 1]
15:32:10: | | flush - [cpu time: avg 0.01 ms, total 171.601 ms] [avg calls per frame: 1]
15:32:10: | | CopyResource - [cpu time: avg 0.005 ms, total 93.6 ms] [avg calls per frame: 1]
15:32:10: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:32:10: Convert444Threads - [cpu time: avg 1.103 ms, total 35100.2 ms] [avg calls per frame: 2]
15:32:10: | Convert444toNV12 - [cpu time: avg 1.103 ms, total 35100.2 ms] [avg calls per frame: 2]
15:32:10: encoder thread frame - [cpu time: avg 1.182 ms, total 18813.7 ms] [avg calls per frame: 1]
15:32:10:
15:32:10: =====Stream End: 2013-10-27, 15:32:10=================================================
15:32:10: =====Stream Start: 2013-10-27, 15:32:10===============================================
15:32:10:   Multithreaded optimizations: On
15:32:10:   Base resolution: 1920x1080
15:32:10:   Output resolution: 1920x1080
15:32:10: ------------------------------------------
15:32:10: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:32:10: Audio Format: 48000hz
15:32:10: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:32:10: Using desktop audio input: Speakers (Creative SB X-Fi)
15:32:10: Using 5.1 speaker setup
15:32:10: Audio Encoding: AAC
15:32:10:     bitrate: 192
15:32:10:     device: Dxtory Video 1,
15:32:10:     device id (null),
15:32:10:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:32:10:     use buffering: false - 0, fourCC: 00000000
15:32:10:     audio device: Disable,
15:32:10:     audio device id Disabled,
15:32:10:
15:32:10: Using directshow input
15:32:10: Scene buffering time set to 400
15:32:10: Video Encoding: x264
15:32:10:     fps: 30
15:32:10:     width: 1920, height: 1080
15:32:10:     preset: veryfast
15:32:10:     profile: high
15:32:10:     keyint: 60
15:32:10:     CBR: no
15:32:10:     CFR: no
15:32:10:     max bitrate: 6000
15:32:10:     buffer size: 6200
15:32:10:     quality: 7
15:32:10: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:34:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:34:01:   New Scene
15:34:15: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
15:34:15:   New Scene
15:34:18: Using Window Capture
15:34:18: Using graphics capture
15:34:19: SharedTexCapture hooked
15:41:13: Total frames encoded: 16268, total frames duplicated: 0 (0.00%)
15:41:13: Total frames rendered: 16272, number of late frames: 2 (0.01%) (it's okay for some frames to be late)
15:41:13:
15:41:13: Profiler time results:
15:41:13:
15:41:13: ==============================================================
15:41:13: video thread frame - [100%] [avg time: 2.888 ms] [children: 90.5%] [unaccounted: 9.49%]
15:41:13: | scene->Preprocess - [87.8%] [avg time: 2.536 ms]
15:41:13: | GPU download and conversion - [2.7%] [avg time: 0.078 ms] [children: 2.39%] [unaccounted: 0.312%]
15:41:13: | | flush - [1.45%] [avg time: 0.042 ms]
15:41:13: | | CopyResource - [0.831%] [avg time: 0.024 ms]
15:41:13: | | conversion to 4:2:0 - [0.104%] [avg time: 0.003 ms]
15:41:13: Convert444Threads - [100%] [avg time: 1.222 ms] [children: 99.4%] [unaccounted: 0.573%]
15:41:13: | Convert444toNV12 - [99.4%] [avg time: 1.215 ms]
15:41:13: encoder thread frame - [100%] [avg time: 2.182 ms]
15:41:13:
15:41:13:
15:41:13: Profiler CPU results:
15:41:13:
15:41:13: video thread frame - [cpu time: avg 2.232 ms, total 36332.6 ms] [avg calls per frame: 1]
15:41:13: | scene->Preprocess - [cpu time: avg 2.046 ms, total 33306.2 ms] [avg calls per frame: 1]
15:41:13: | GPU download and conversion - [cpu time: avg 0.036 ms, total 592.805 ms] [avg calls per frame: 1]
15:41:13: | | flush - [cpu time: avg 0.023 ms, total 390.002 ms] [avg calls per frame: 1]
15:41:13: | | CopyResource - [cpu time: avg 0.007 ms, total 124.802 ms] [avg calls per frame: 1]
15:41:13: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 46.801 ms] [avg calls per frame: 1]
15:41:13: Convert444Threads - [cpu time: avg 1.238 ms, total 40263.9 ms] [avg calls per frame: 2]
15:41:13: | Convert444toNV12 - [cpu time: avg 1.235 ms, total 40170.3 ms] [avg calls per frame: 2]
15:41:13: encoder thread frame - [cpu time: avg 1.433 ms, total 23306.5 ms] [avg calls per frame: 1]
15:41:13:
15:41:13: =====Stream End: 2013-10-27, 15:41:13=================================================
15:41:15: =====Stream Start: 2013-10-27, 15:41:15===============================================
15:41:15:   Multithreaded optimizations: On
15:41:15:   Base resolution: 1920x1080
15:41:15:   Output resolution: 1920x1080
15:41:15: ------------------------------------------
15:41:15: Loading up D3D10 on NVIDIA GeForce GTX 670...
15:41:15: Audio Format: 48000hz
15:41:15: Playback device {0.0.0.00000000}.{a38fb9f3-2bba-45be-84db-1b9e583e6c39}
15:41:15: Using desktop audio input: Speakers (Creative SB X-Fi)
15:41:15: Using 5.1 speaker setup
15:41:15: Audio Encoding: AAC
15:41:15:     bitrate: 192
15:41:15:     device: Dxtory Video 1,
15:41:15:     device id (null),
15:41:15:     chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-333333
15:41:15:     use buffering: false - 0, fourCC: 00000000
15:41:15:     audio device: Disable,
15:41:15:     audio device id Disabled,
15:41:15:
15:41:15: Using directshow input
15:41:15: Scene buffering time set to 400
15:41:15: Video Encoding: x264
15:41:15:     fps: 30
15:41:15:     width: 1920, height: 1080
15:41:15:     preset: veryfast
15:41:15:     profile: high
15:41:15:     keyint: 60
15:41:15:     CBR: no
15:41:15:     CFR: no
15:41:15:     max bitrate: 6000
15:41:15:     buffer size: 6200
15:41:15:     quality: 7
15:41:15: MMDeviceAudioSource: Frequency for device 'Speakers (Creative SB X-Fi)' is 2304000, samples per sec is 96000
15:41:22: Using RTMP service: Twitch / Justin.tv
15:41:22:   Server selection: rtmp://live.justin.tv/app
15:41:22:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
15:41:22: Completed handshake with rtmp://live.justin.tv/app in 108 ms.
15:41:23: SO_SNDBUF was at 8192
15:41:23: SO_SNDBUF is now 65536
15:41:23: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 28673 / 792576)
15:41:23: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 31496 / 792576)
15:42:22: Total frames encoded: 1989, total frames duplicated: 0 (0.00%)
15:42:22: Total frames rendered: 1994, number of late frames: 1 (0.05%) (it's okay for some frames to be late)
15:42:28: RTMPPublisher::SocketLoop: Graceful loop exit
15:42:28: Average send payload: 12144 bytes, average send interval: 19 ms
15:42:28: Number of times waited to send: 0, Waited for a total of 0 bytes
15:42:28: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
15:42:28: Number of bytes sent: 40551636
15:42:28:
15:42:28: Profiler time results:
15:42:28:
15:42:28: ==============================================================
15:42:28: video thread frame - [100%] [avg time: 3.034 ms] [children: 90.8%] [unaccounted: 9.16%]
15:42:28: | scene->Preprocess - [87.8%] [avg time: 2.664 ms]
15:42:28: | GPU download and conversion - [3.03%] [avg time: 0.092 ms] [children: 2.6%] [unaccounted: 0.428%]
15:42:28: | | flush - [1.65%] [avg time: 0.05 ms]
15:42:28: | | CopyResource - [0.857%] [avg time: 0.026 ms]
15:42:28: | | conversion to 4:2:0 - [0.0989%] [avg time: 0.003 ms]
15:42:28: Convert444Threads - [100%] [avg time: 1.293 ms] [children: 99.2%] [unaccounted: 0.773%]
15:42:28: | Convert444toNV12 - [99.2%] [avg time: 1.283 ms]
15:42:28: encoder thread frame - [100%] [avg time: 2.121 ms]
15:42:28:
15:42:28:
15:42:28: Profiler CPU results:
15:42:28:
15:42:28: video thread frame - [cpu time: avg 2.37 ms, total 4726.83 ms] [avg calls per frame: 1]
15:42:28: | scene->Preprocess - [cpu time: avg 2.096 ms, total 4180.83 ms] [avg calls per frame: 1]
15:42:28: | GPU download and conversion - [cpu time: avg 0.109 ms, total 218.402 ms] [avg calls per frame: 1]
15:42:28: | | flush - [cpu time: avg 0.062 ms, total 124.801 ms] [avg calls per frame: 1]
15:42:28: | | CopyResource - [cpu time: avg 0.015 ms, total 31.201 ms] [avg calls per frame: 1]
15:42:28: | | conversion to 4:2:0 - [cpu time: avg 0.007 ms, total 15.6 ms] [avg calls per frame: 1]
15:42:28: Convert444Threads - [cpu time: avg 1.447 ms, total 5725.24 ms] [avg calls per frame: 2]
15:42:28: | Convert444toNV12 - [cpu time: avg 1.439 ms, total 5694.04 ms] [avg calls per frame: 2]
15:42:28: encoder thread frame - [cpu time: avg 1.451 ms, total 2870.42 ms] [avg calls per frame: 1]
15:42:28:
15:42:28: =====Stream End: 2013-10-27, 15:42:28=================================================
It's because it uses OpenAL for audio I believe, which bypasses the windows mixer. I don't know if there's an option to use directsound or xaudio, but if there is, use it. It doesn't appear that you're using a mic, so here's what I suggest as a workaround. Mute desktop, then in audio settings, use "What you hear" or "Stereo mix" for your mic channel. It will play your desktop, plus should also include PoE
The sounds from PoE don't even get picked up by my speakers in playback, is this some sort of magic?
I got it to work with stereo mix, but only if I want to hear double.
adding -swa to the launch options fixes this.
Thank you very much for the command line option, I've been trying to make note of a way to solve that issue for some time now.
