Question / Help Odd Problem, help appreciated
zootiex
Hello since today when i tryed too stream , in the OBS window it says 0kbps upload in the bottom right , usually it buffers from 1500-4500kbps, but its just say 0 kpbs....., and i just drop frames continously in OBS (not ingame), im not being traffic management by my isp as im getting 125/11 speeds
For last month ive streamed 1080-30 fps with no problems, here a pic with OBS saying 0kbps, when usually it would say 1500-4500kbps in bottom right
FullSize link http://i.imgur.com/9woehv5.jpg
any help/advice would be greatly appreciated, ive tryed streaming too different twitch servers, doesnt make a difference.
Could this my ISP? or another issue?
Shadowmist
I am having the same problem this morning I was having no problems last night and this morning I can't stream. I think it is an ISP issue though because at speedtest.net my download is 30mbps but it can't connect to upload at all.
Below is my log file
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
CPU Speed: 3502MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
monitor 2: pos={-1680, 0}, size={1680, 1050}
Aero is Enabled
Adapter 1
  Video Adapter: AMD Radeon HD 7800 Series
  Video Adapter Dedicated Video Memory: 2119376896
  Video Adapter Shared System Memory: 2175524864
Adapter 2
  Video Adapter: Intel(R) HD Graphics 4000
  Video Adapter Dedicated Video Memory: 67108864
  Video Adapter Shared System Memory: 1711276032
  Base resolution: 1920x1080
  Output resolution: 1920x1080
Loading up D3D10...
Playback device {0.0.0.00000000}.{1177f551-10ff-4198-923a-d58593309c1d}
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Turtle Beach PX3 (PS3))
Audio Encoding: AAC
    bitrate: 128
Using graphics capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264: profile High, level 4.0
Video Encoding: x264
    fps: 25
    width: 1920, height: 1080
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 2000
    buffer size: 2000
    quality: 9
SharedTexCapture hooked
  Server selection: rtmp://live-mia.justin.tv/app
bufferTime: 2129, outputRateWindowTime: 1000, dropThreshold: 2629
RTMPPublisher::BufferedSend: Socket buffer is full (272278 / 272384 bytes), waiting to send 796 bytes
RTMPPublisher::SocketLoop: Socket error, send() returned -1, GetLastError() 10053
Total frames rendered: 346, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
okay, this is strange
librtmp error: WriteN, RTMP send error 10053 (79 bytes)
librtmp error: WriteN, RTMP send error 10038 (42 bytes)
Number of b-frames dropped: 96 (33%), Number of p-frames dropped: 71 (24%), Total 167 (57%)
x264: frame I:2     Avg QP:26.36  size:108568
x264: frame P:77    Avg QP:23.42  size: 16489
x264: frame B:226   Avg QP:28.40  size:  1564
x264: consecutive B-frames:  1.0%  0.0%  0.0% 99.0%
x264: mb I  I16..4: 23.4% 48.0% 28.6%
x264: mb P  I16..4:  1.0%  1.3%  0.1%  P16..4: 17.2%  7.1%  3.5%  0.0%  0.0%    skip:69.6%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  1.7%  0.7%  0.2%  direct: 1.2%  skip:96.3%  L0:26.6% L1:44.2% BI:29.3%
x264: 8x8 transform intra:50.4% inter:37.0%
x264: coded y,uvDC,uvAC intra: 52.2% 59.2% 24.6% inter: 2.7% 3.8% 0.5%
x264: i16 v,h,dc,p: 39% 37% 14% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 40% 21%  2%  3%  3%  4%  4%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 19% 12%  7%  7%  8%  7%  8%  6%
x264: i8c dc,h,v,p: 41% 31% 19%  8%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:1206.53
Profiler results:
frame - [100%] [avg time: 3.942 ms] [avg calls per frame: 1] [children: 84%] [unaccounted: 16%]
| scene->Preprocess - [0.127%] [avg time: 0.005 ms] [avg calls per frame: 1]
| video encoding and uploading - [83.8%] [avg time: 3.305 ms] [avg calls per frame: 1] [children: 55.3%] [unaccounted: 28.5%]
| | CopyResource - [0.203%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0761%] [avg time: 0.003 ms] [avg calls per frame: 0]
| | call to encoder - [54.9%] [avg time: 2.163 ms] [avg calls per frame: 0]
| | sending stuff out - [0.152%] [avg time: 0.006 ms] [avg calls per frame: 0]
zootiex
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: AMD FX(tm)-4100 Quad-Core Processor
CPU Speed: 4414MHz
Physical Memory:  16329MB Total, 12987MB Free
stepping id: 2, model 1, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 4
monitor 1: pos={1920, 0}, size={1920, 1080}
monitor 2: pos={0, 0}, size={1920, 1080}
Aero is Enabled
Adapter 1
  Video Adapter Dedicated Video Memory: 2115276800
  Video Adapter Shared System Memory: 3997884416
Loading up D3D10...
Playback device Default
Using desktop audio input: Headphones (High Definition Audio Device)
Using auxilary audio input: Microphone (High Definition Audio Device)
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
Using Monitor Capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX XOP FMA4 SSEMisalign LZCNT
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
  Server selection: rtmp://live-lhr.justin.tv/app
bufferTime: 2938, outputRateWindowTime: 1000, dropThreshold: 3438
Total frames rendered: 199, number of frames that lagged: 99 (49.75%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:25.98  size: 88198
x264: frame P:51    Avg QP:20.85  size:  5308
x264: frame B:117   Avg QP:29.55  size:   209
x264: consecutive B-frames:  7.1%  1.2%  1.8% 89.9%
x264: mb I  I16..4: 76.1%  2.4% 21.5%
x264: mb P  I16..4:  4.5%  0.8%  0.5%  P16..4:  2.3%  0.1%  0.1%  0.0%  0.0%    skip:91.8%
x264: mb B  I16..4:  0.3%  0.0%  0.0%  B16..8:  0.2%  0.0%  0.0%  direct: 0.0%  skip:99.4%  L0:26.7% L1:72.4% BI: 0.9%
x264: 8x8 transform intra:10.5% inter:42.7%
x264: coded y,uvDC,uvAC intra: 20.0% 9.1% 8.0% inter: 0.4% 0.1% 0.0%
x264: i16 v,h,dc,p: 64% 32%  4%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 23% 42%  4%  3%  3%  3%  3%  4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 34% 15%  3%  4%  5%  4%  3%  4%
x264: i8c dc,h,v,p: 81% 14%  4%  0%
x264: kb/s:402.78
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 3067, outputRateWindowTime: 1000, dropThreshold: 3567
Total frames rendered: 353, number of frames that lagged: 351 (99.43%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
librtmp error: WriteN, RTMP send error 10035 (79 bytes)
x264: frame I:2     Avg QP:18.02  size:250331
x264: frame P:81    Avg QP:23.31  size:   411
x264: frame B:239   Avg QP:31.77  size:   105
x264: consecutive B-frames:  0.9%  0.0%  0.0% 99.1%
x264: mb I  I16..4: 47.6% 26.2% 26.1%
x264: mb P  I16..4:  0.1%  0.0%  0.0%  P16..4:  0.4%  0.0%  0.0%  0.0%  0.0%    skip:99.4%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.1%  0.0%  0.0%  direct: 0.0%  skip:99.9%  L0:42.0% L1:57.0% BI: 1.1%
x264: 8x8 transform intra:24.0% inter:11.6%
x264: coded y,uvDC,uvAC intra: 56.8% 21.0% 18.7% inter: 0.0% 0.1% 0.0%
x264: i16 v,h,dc,p: 48% 33% 18%  1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu:  7%  5% 60%  5%  5%  4%  3%  5%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 30% 13%  3%  5%  6%  4%  4%  4%
x264: i8c dc,h,v,p: 76% 12% 11%  1%
x264: kb/s:269.05
Loading up D3D10...
Using desktop audio input: Speakers (High Definition Audio Device)
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 3127, outputRateWindowTime: 1000, dropThreshold: 3627
Total frames rendered: 637, number of frames that lagged: 449 (70.49%) (it's okay for some frames to lag)
x264: frame I:3     Avg QP:20.86  size:194343
x264: frame P:163   Avg QP:20.52  size:  4376
x264: frame B:441   Avg QP:26.66  size:   182
x264: consecutive B-frames:  2.5%  1.0%  1.5% 95.1%
x264: mb I  I16..4: 57.9% 11.4% 30.7%
x264: mb P  I16..4:  4.6%  0.4%  0.5%  P16..4:  1.9%  0.1%  0.1%  0.0%  0.0%    skip:92.4%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.2%  0.0%  0.0%  direct: 0.1%  skip:99.6%  L0:41.2% L1:55.5% BI: 3.3%
x264: 8x8 transform intra:8.2% inter:31.8%
x264: coded y,uvDC,uvAC intra: 23.0% 11.9% 9.7% inter: 0.3% 0.2% 0.0%
x264: i16 v,h,dc,p: 76% 20%  4%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 12% 55%  4%  3%  4%  4%  3%  5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 32% 14%  3%  4%  4%  5%  4%  5%
x264: i8c dc,h,v,p: 84%  9%  6%  1%
x264: kb/s:379.81
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 3008, outputRateWindowTime: 1000, dropThreshold: 3508
RTMPPublisher::BufferedSend: Socket buffer is full (597031 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599651 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
RTMPPublisher::BufferedSend: Socket buffer is full (597580 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597588 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597983 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599978 / 600064 bytes), waiting to send 2262 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (600035 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596416 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596643 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598237 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (600055 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598914 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596227 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597274 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597607 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598287 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598620 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598564 / 600064 bytes), waiting to send 4097 bytes
Total frames rendered: 47003, number of frames that lagged: 44700 (95.10%) (it's okay for some frames to lag)
Number of b-frames dropped: 1019 (2.2%), Number of p-frames dropped: 855 (1.8%), Total 1874 (4%)
x264: frame I:193   Avg QP:23.01  size:268677
x264: frame P:20307 Avg QP:26.21  size: 40099
x264: frame B:26473 Avg QP:28.84  size:  9966
x264: consecutive B-frames:  9.1% 42.3% 14.9% 33.7%
x264: mb I  I16..4: 14.2% 25.2% 60.6%
x264: mb P  I16..4:  5.0%  6.3%  2.1%  P16..4: 22.6%  8.8%  4.5%  0.0%  0.0%    skip:50.7%
x264: mb B  I16..4:  0.6%  0.5%  0.1%  B16..8:  9.7%  4.2%  0.9%  direct: 3.1%  skip:81.0%  L0:37.2% L1:49.9% BI:12.8%
x264: 8x8 transform intra:45.3% inter:26.3%
x264: coded y,uvDC,uvAC intra: 55.4% 45.4% 21.3% inter: 8.8% 8.8% 2.4%
x264: i16 v,h,dc,p: 30% 35% 27%  8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 23% 27%  5%  6%  6%  8%  4%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 23% 18%  6%  7%  7%  8%  6%  7%
x264: i8c dc,h,v,p: 56% 25% 15%  4%
x264: Weighted P-Frames: Y:0.1% UV:0.1%
x264: kb/s:3595.12
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 2813, outputRateWindowTime: 1000, dropThreshold: 3313
RTMPPublisher::BufferedSend: Socket buffer is full (599181 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599604 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598402 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597219 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599589 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599384 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596361 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
RTMPPublisher::BufferedSend: Socket buffer is full (599879 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599170 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596929 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596722 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599610 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599070 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599592 / 600064 bytes), waiting to send 635 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599919 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597759 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597304 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596515 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599437 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598259 / 600064 bytes), waiting to send 2230 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596011 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598214 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599095 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598702 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599517 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597769 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599312 / 600064 bytes), waiting to send 3901 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599862 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599994 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598649 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599910 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599136 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596311 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598344 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598626 / 600064 bytes), waiting to send 3686 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596834 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597761 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596660 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598429 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597528 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598887 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598449 / 600064 bytes), waiting to send 2952 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599471 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599912 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598927 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597381 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596649 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597789 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598986 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596696 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598406 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598231 / 600064 bytes), waiting to send 4097 bytes
Total frames rendered: 28223, number of frames that lagged: 26173 (92.74%) (it's okay for some frames to lag)
Number of b-frames dropped: 306 (1.1%), Number of p-frames dropped: 243 (0.86%), Total 549 (1.9%)
x264: frame I:116   Avg QP:22.27  size:284655
x264: frame P:11329 Avg QP:25.57  size: 39627
x264: frame B:16747 Avg QP:28.94  size:  9816
x264: consecutive B-frames:  6.1% 38.3% 17.8% 37.9%
x264: mb I  I16..4: 12.5% 23.2% 64.2%
x264: mb P  I16..4:  3.3%  3.6%  1.8%  P16..4: 20.9%  8.4%  4.8%  0.0%  0.0%    skip:57.1%
x264: mb B  I16..4:  0.4%  0.2%  0.1%  B16..8:  8.0%  3.6%  1.0%  direct: 2.6%  skip:84.1%  L0:36.5% L1:49.1% BI:14.4%
x264: 8x8 transform intra:39.0% inter:24.9%
x264: coded y,uvDC,uvAC intra: 57.4% 52.8% 28.9% inter: 7.9% 8.0% 2.8%
x264: i16 v,h,dc,p: 32% 38% 24%  6%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 22% 27%  5%  6%  5%  8%  5%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 23% 17%  6%  7%  7%  8%  6%  7%
x264: i8c dc,h,v,p: 53% 26% 16%  5%
x264: Weighted P-Frames: Y:0.2% UV:0.2%
x264: kb/s:3529.92
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
Total frames rendered: 45, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:20.50  size:199343
x264: frame P:3     Avg QP:21.46  size: 12464
x264: frame B:7     Avg QP:29.34  size:  2326
x264: consecutive B-frames:  7.7%  0.0%  0.0% 92.3%
x264: mb I  I16..4: 20.8% 40.2% 39.0%
x264: mb P  I16..4:  1.0%  0.8%  0.3%  P16..4:  9.7%  2.6%  1.9%  0.0%  0.0%    skip:83.7%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  1.6%  1.1%  0.2%  direct: 0.9%  skip:96.1%  L0:41.6% L1:36.3% BI:22.1%
x264: 8x8 transform intra:40.2% inter:21.6%
x264: coded y,uvDC,uvAC intra: 76.3% 52.8% 30.3% inter: 2.0% 2.7% 0.4%
x264: i16 v,h,dc,p: 39% 28% 23% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 22% 22%  6%  6%  6%  8%  5% 10%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 25% 12%  6%  7%  7%  7%  6%  6%
x264: i8c dc,h,v,p: 52% 25% 18%  5%
x264: kb/s:4600.35
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 2971, outputRateWindowTime: 1000, dropThreshold: 3471
RTMPPublisher::BufferedSend: Socket buffer is full (596369 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598814 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598657 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596024 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597587 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599453 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597779 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597262 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597509 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596167 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597602 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599193 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597873 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598944 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596973 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597411 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597932 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596306 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599674 / 600064 bytes), waiting to send 1394 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596387 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597800 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597778 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599622 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597752 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598256 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599480 / 600064 bytes), waiting to send 2253 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599174 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598330 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596375 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597369 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599166 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598962 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599734 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596710 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599750 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598151 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596307 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597978 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598824 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596131 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598002 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599801 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597200 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598682 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599681 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596763 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599594 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599319 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599687 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597040 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597623 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596603 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597908 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596934 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599810 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597722 / 600064 bytes), waiting to send 2789 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597179 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599410 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598811 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596717 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597664 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599588 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596475 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597051 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596536 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598127 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599935 / 600064 bytes), waiting to send 2599 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596802 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598465 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598242 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597591 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598215 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597545 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597678 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598317 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598047 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598856 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597705 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599516 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599295 / 600064 bytes), waiting to send 3555 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596071 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596442 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597909 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597902 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596768 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599953 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597829 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598743 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596601 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596335 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599562 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598263 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596485 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597446 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599192 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596003 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598949 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596653 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599815 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598265 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599905 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596238 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598248 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596836 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599551 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598594 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596341 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596888 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597734 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599584 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597236 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599949 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597717 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599948 / 600064 bytes), waiting to send 2627 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598215 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599563 / 600064 bytes), waiting to send 632 bytes
Total frames rendered: 114861, number of frames that lagged: 105 (0.09%) (it's okay for some frames to lag)
Number of b-frames dropped: 936 (0.82%), Number of p-frames dropped: 555 (0.48%), Total 1491 (1.3%)
x264: frame I:462   Avg QP:20.96  size:261591
x264: frame P:43105 Avg QP:24.84  size: 29144
x264: frame B:71260 Avg QP:27.00  size:  6885
x264: consecutive B-frames:  8.1% 22.2% 15.9% 53.9%
x264: mb I  I16..4: 18.2% 27.0% 54.8%
x264: mb P  I16..4:  6.1%  5.1%  1.2%  P16..4: 17.4%  6.5%  3.4%  0.0%  0.0%    skip:60.4%
x264: mb B  I16..4:  0.5%  0.3%  0.1%  B16..8:  6.7%  2.8%  0.6%  direct: 2.4%  skip:86.6%  L0:35.8% L1:51.2% BI:13.0%
x264: 8x8 transform intra:39.7% inter:25.5%
x264: coded y,uvDC,uvAC intra: 38.1% 47.2% 21.6% inter: 5.5% 7.2% 1.9%
x264: i16 v,h,dc,p: 40% 33% 21%  7%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 22% 34%  4%  5%  5%  6%  4%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 24% 18%  6%  7%  6%  7%  6%  7%
x264: i8c dc,h,v,p: 55% 24% 17%  5%
x264: kb/s:3233.78
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 3043, outputRateWindowTime: 1000, dropThreshold: 3543
RTMPPublisher::BufferedSend: Socket buffer is full (598943 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599443 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599382 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599501 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597865 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599846 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597786 / 600064 bytes), waiting to send 3619 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598043 / 600064 bytes), waiting to send 2368 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598819 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596804 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598806 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597933 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598229 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599637 / 600064 bytes), waiting to send 635 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599255 / 600064 bytes), waiting to send 2755 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596328 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597715 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597288 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596592 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (600058 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597561 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597722 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599670 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598211 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597119 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598007 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599158 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597480 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597483 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597463 / 600064 bytes), waiting to send 3795 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599189 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596943 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597866 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599954 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596153 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598182 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599695 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597724 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599626 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599579 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596709 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599535 / 600064 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598878 / 600064 bytes), waiting to send 4097 bytes
Total frames rendered: 58515, number of frames that lagged: 49 (0.08%) (it's okay for some frames to lag)
Number of b-frames dropped: 203 (0.35%), Number of p-frames dropped: 75 (0.13%), Total 278 (0.48%)
x264: frame I:234   Avg QP:22.15  size:289601
x264: frame P:20777 Avg QP:25.13  size: 31075
x264: frame B:37470 Avg QP:27.84  size:  6763
x264: consecutive B-frames:  5.5% 21.5% 17.5% 55.5%
x264: mb I  I16..4: 13.7% 25.9% 60.4%
x264: mb P  I16..4:  4.4%  4.3%  1.2%  P16..4: 20.5%  6.9%  3.6%  0.0%  0.0%    skip:59.1%
x264: mb B  I16..4:  0.4%  0.2%  0.0%  B16..8:  7.0%  2.8%  0.6%  direct: 2.4%  skip:86.7%  L0:36.0% L1:51.5% BI:12.5%
x264: 8x8 transform intra:41.0% inter:24.6%
x264: coded y,uvDC,uvAC intra: 48.8% 52.8% 30.6% inter: 5.6% 7.8% 2.2%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 24% 30%  5%  6%  5%  7%  4%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 24% 16%  6%  7%  7%  8%  6%  7%
x264: i8c dc,h,v,p: 53% 27% 15%  5%
x264: Weighted P-Frames: Y:0.1% UV:0.0%
x264: kb/s:3283.32
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
RTMPPublisher::BufferedSend: Socket buffer is full (597543 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599961 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598244 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597897 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597727 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598873 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599438 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597901 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599976 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598365 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596963 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598169 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597024 / 600064 bytes), waiting to send 4097 bytes
Total frames rendered: 194187, number of frames that lagged: 742 (0.38%) (it's okay for some frames to lag)
Number of b-frames dropped: 688 (0.35%), Number of p-frames dropped: 375 (0.19%), Total 1063 (0.55%)
x264: frame I:783   Avg QP:23.31  size:277663
x264: frame P:73388 Avg QP:26.90  size: 29103
x264: frame B:119982 Avg QP:29.81  size:  6272
x264: consecutive B-frames:  5.9% 30.4% 14.4% 49.3%
x264: mb I  I16..4: 11.5% 24.3% 64.2%
x264: mb P  I16..4:  2.9%  3.4%  1.2%  P16..4: 17.3%  6.7%  3.8%  0.0%  0.0%    skip:64.7%
x264: mb B  I16..4:  0.3%  0.2%  0.1%  B16..8:  5.3%  2.5%  0.6%  direct: 2.1%  skip:89.1%  L0:35.1% L1:50.1% BI:14.8%
x264: 8x8 transform intra:42.4% inter:24.8%
x264: coded y,uvDC,uvAC intra: 51.7% 55.1% 31.5% inter: 5.7% 6.9% 2.1%
x264: i16 v,h,dc,p: 35% 36% 22%  7%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 23% 28%  5%  6%  5%  8%  4%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 25% 16%  6%  7%  6%  9%  5%  8%
x264: i8c dc,h,v,p: 53% 26% 16%  6%
x264: kb/s:3149.27
Profiler results:
frame - [100%] [avg time: 14.215 ms] [avg calls per frame: 1] [children: 93.1%] [unaccounted: 6.94%]
| scene->Preprocess - [58.9%] [avg time: 8.372 ms] [avg calls per frame: 1]
| video encoding and uploading - [34.2%] [avg time: 4.857 ms] [avg calls per frame: 1] [children: 22.3%] [unaccounted: 11.9%]
| | CopyResource - [0.0985%] [avg time: 0.014 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.113%] [avg time: 0.016 ms] [avg calls per frame: 0]
| | call to encoder - [21.4%] [avg time: 3.042 ms] [avg calls per frame: 0]
| | sending stuff out - [0.661%] [avg time: 0.094 ms] [avg calls per frame: 0]
zootiex
CPU Speed: 4414MHz
Physical Memory:  16329MB Total, 13432MB Free
Aero is Enabled
Adapter 1
Loading up D3D10...
Using desktop audio input: 1 - DSGR (AMD High Definition Audio Device)
Audio Encoding: MP3
    bitrate: 192
Using bitmap image
Using bitmap image
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
Total frames rendered: 71, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:13.43  size: 17247
x264: frame P:9     Avg QP:11.77  size:   121
x264: frame B:27    Avg QP:12.88  size:    70
x264: consecutive B-frames:  2.7%  0.0%  0.0% 97.3%
x264: mb I  I16..4: 92.4%  3.1%  4.5%
x264: mb P  I16..4:  0.0%  0.0%  0.0%  P16..4:  0.3%  0.0%  0.0%  0.0%  0.0%    skip:99.7%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.0%  0.0%  0.0%  direct: 0.0%  skip:100.0%
x264: 8x8 transform intra:3.1% inter:18.8%
x264: coded y,uvDC,uvAC intra: 8.2% 7.6% 5.8% inter: 0.0% 0.1% 0.0%
x264: i16 v,h,dc,p: 97%  1%  2%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 28% 13%  5%  5%  3%  7%  6%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 39%  8%  4%  4%  4%  6%  4%  6%
x264: i8c dc,h,v,p: 95%  3%  2%  1%
x264: kb/s:109.37
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
Total frames rendered: 46, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP: 8.00  size:  1216
x264: frame P:3     Avg QP: 9.00  size:    72
x264: frame B:9     Avg QP:11.67  size:    68
x264: mb I  I16..4: 100.0%  0.0%  0.0%
x264: mb P  I16..4:  0.0%  0.0%  0.0%  P16..4:  0.0%  0.0%  0.0%  0.0%  0.0%    skip:100.0%
x264: 8x8 transform intra:0.0%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 99%  0%  1%  0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu:  0%  0% 100%  0%  0%  0%  0%  0%  0%
x264: i8c dc,h,v,p: 100%  0%  0%  0%
x264: kb/s:31.49
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
x264: frame I:1     Avg QP:26.96  size:190408
x264: frame P:12    Avg QP:25.86  size: 31062
x264: frame B:25    Avg QP:30.97  size:  3870
x264: consecutive B-frames: 10.0%  0.0%  0.0% 90.0%
x264: mb I  I16..4: 11.9% 33.8% 54.4%
x264: mb P  I16..4:  0.7%  1.5%  0.7%  P16..4: 21.6%  4.8%  3.6%  0.0%  0.0%    skip:67.0%
x264: mb B  I16..4:  0.2%  0.6%  0.1%  B16..8:  2.7%  1.3%  0.3%  direct: 2.1%  skip:92.8%  L0:47.7% L1:36.8% BI:15.5%
x264: 8x8 transform intra:42.5% inter:23.9%
x264: coded y,uvDC,uvAC intra: 69.6% 77.1% 54.2% inter: 5.1% 8.1% 2.7%
x264: i16 v,h,dc,p: 44% 25% 21% 10%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 21% 17%  6%  8%  7%  9%  7%  7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 25% 11%  6%  7%  7%  7%  6%  7%
x264: i8c dc,h,v,p: 45% 26% 21%  8%
x264: kb/s:3473.21
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4500
    buffer size: 4500
    quality: 10
bufferTime: 2942, outputRateWindowTime: 1000, dropThreshold: 3442
RTMPPublisher::BufferedSend: Socket buffer is full (598069 / 600064 bytes), waiting to send 3687 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598149 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597693 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598720 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599749 / 600064 bytes), waiting to send 3746 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597417 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597905 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598705 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596049 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599250 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598414 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599422 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596207 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597920 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597814 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597998 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598959 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596172 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597953 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598735 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (596843 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598524 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597374 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597142 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (597437 / 600064 bytes), waiting to send 4053 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598893 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (600025 / 600064 bytes), waiting to send 2287 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598107 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598997 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599373 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598741 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (598130 / 600064 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599202 / 600064 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (599835 / 600064 bytes), waiting to send 632 bytes
Total frames rendered: 3681, number of frames that lagged: 16 (0.43%) (it's okay for some frames to lag)
Number of b-frames dropped: 490 (13%), Number of p-frames dropped: 426 (12%), Total 916 (25%)
x264: frame I:17    Avg QP:25.37  size:270041
x264: frame P:1451  Avg QP:27.55  size: 32501
x264: frame B:2180  Avg QP:30.49  size:  5853
x264: consecutive B-frames:  9.6% 30.8%  3.6% 56.0%
x264: mb I  I16..4: 11.3% 29.0% 59.7%
x264: mb P  I16..4:  4.2%  4.9%  0.9%  P16..4: 23.2%  7.9%  3.9%  0.0%  0.0%    skip:55.0%
x264: mb B  I16..4:  0.3%  0.3%  0.0%  B16..8:  6.2%  2.4%  0.5%  direct: 2.3%  skip:87.9%  L0:38.5% L1:49.4% BI:12.1%
x264: 8x8 transform intra:46.5% inter:31.7%
x264: coded y,uvDC,uvAC intra: 46.1% 51.6% 22.8% inter: 6.6% 7.5% 1.7%
x264: i16 v,h,dc,p: 38% 31% 21%  9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 19% 30%  5%  6%  6%  6%  5%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 21% 16%  6%  8%  7%  8%  6%  8%
x264: i8c dc,h,v,p: 53% 24% 17%  6%
x264: kb/s:3420.14
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 10
bufferTime: 5047, outputRateWindowTime: 1000, dropThreshold: 5547
RTMPPublisher::BufferedSend: Socket buffer is full (533492 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (532731 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (534085 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (533638 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (535536 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (532846 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (532492 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (536410 / 536576 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (532784 / 536576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (535128 / 536576 bytes), waiting to send 4104 bytes
Total frames rendered: 2741, number of frames that lagged: 15 (0.55%) (it's okay for some frames to lag)
Number of b-frames dropped: 534 (20%), Number of p-frames dropped: 772 (29%), Total 1306 (48%)
x264: frame I:13    Avg QP:32.17  size:150021
x264: frame P:1314  Avg QP:31.47  size: 30516
x264: frame B:1381  Avg QP:33.32  size:  5954
x264: consecutive B-frames: 16.0% 45.8%  6.3% 31.9%
x264: mb I  I16..4: 19.3% 49.5% 31.2%
x264: mb P  I16..4:  5.7%  7.9%  0.8%  P16..4: 26.9%  8.8%  3.5%  0.0%  0.0%    skip:46.4%
x264: mb B  I16..4:  0.4%  0.4%  0.0%  B16..8:  9.4%  3.1%  0.4%  direct: 2.5%  skip:83.8%  L0:38.6% L1:51.3% BI:10.1%
x264: 8x8 transform intra:54.2% inter:31.8%
x264: coded y,uvDC,uvAC intra: 44.3% 51.1% 18.3% inter: 7.6% 8.7% 1.1%
x264: i16 v,h,dc,p: 34% 31% 23% 12%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 19% 32%  5%  5%  6%  6%  5%  6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 20% 19%  6%  7%  7%  7%  6%  6%
x264: i8c dc,h,v,p: 57% 23% 15%  6%
x264: kb/s:3643.91
  Output resolution: 1280x720
Loading up D3D10...
Audio Encoding: MP3
    bitrate: 192
x264: profile High, level 3.2
    fps: 40
    width: 1280, height: 720
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 6000
    buffer size: 6000
    quality: 10
bufferTime: 5894, outputRateWindowTime: 1000, dropThreshold: 6394
RTMPPublisher::BufferedSend: Socket buffer is full (791848 / 792576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (792026 / 792576 bytes), waiting to send 632 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (790637 / 792576 bytes), waiting to send 4094 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (791406 / 792576 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (788870 / 792576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (792050 / 792576 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (789939 / 792576 bytes), waiting to send 4097 bytes
Total frames rendered: 6561, number of frames that lagged: 10 (0.15%) (it's okay for some frames to lag)
Number of b-frames dropped: 1807 (28%), Number of p-frames dropped: 2535 (39%), Total 4342 (67%)
x264: frame I:27    Avg QP:20.64  size:147743
x264: frame P:2581  Avg QP:24.47  size: 16517
x264: frame B:3913  Avg QP:28.63  size:  2727
x264: consecutive B-frames: 10.4% 21.5% 21.3% 46.7%
x264: mb I  I16..4:  8.9% 28.7% 62.3%
x264: mb P  I16..4:  2.6%  3.9%  0.9%  P16..4: 28.5% 10.8%  5.0%  0.0%  0.0%    skip:48.3%
x264: mb B  I16..4:  0.3%  0.2%  0.0%  B16..8: 10.0%  3.3%  0.4%  direct: 2.1%  skip:83.8%  L0:37.3% L1:50.2% BI:12.5%
x264: 8x8 transform intra:48.9% inter:29.1%
x264: coded y,uvDC,uvAC intra: 65.4% 40.9% 16.8% inter: 8.3% 5.4% 1.5%
x264: i16 v,h,dc,p: 22% 36% 33%  8%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 25% 30%  5%  6%  5%  7%  4%  8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 23% 18%  6%  7%  7%  7%  6%  8%
x264: i8c dc,h,v,p: 59% 25% 13%  3%
x264: kb/s:2788.92
Profiler results:
frame - [100%] [avg time: 6.197 ms] [avg calls per frame: 1] [children: 80.2%] [unaccounted: 19.8%]
| scene->Preprocess - [0.0645%] [avg time: 0.004 ms] [avg calls per frame: 1]
| video encoding and uploading - [80.1%] [avg time: 4.966 ms] [avg calls per frame: 1] [children: 40.8%] [unaccounted: 39.4%]
| | CopyResource - [0.339%] [avg time: 0.021 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.452%] [avg time: 0.028 ms] [avg calls per frame: 0]
| | call to encoder - [38.8%] [avg time: 2.402 ms] [avg calls per frame: 0]
| | sending stuff out - [1.21%] [avg time: 0.075 ms] [avg calls per frame: 0]
zootiex
Post 1 being a log from days ago when stuff worked for sure no problems, and second post being one from today when had these issues
zootiex
DiffProbe release. January 2012. Build 1008.
Shaper Detection Module.
Connected to server 80.239.168.202.
Estimating capacity:
Upstream: 11807 Kbps.
Downstream: 179013 Kbps.
The measurement will take upto 2.5 minutes. Please wait.
Checking for traffic shapers:
Upstream: No shaper detected.
Median received rate: 11573 Kbps.
Downstream: No shaper detected.
Median received rate: 120960 Kbps.
For more information, visit: http://www.cc.gatech.edu/~partha/diffprobe
Krazy
Town drunk
Is this still happening? Apparently some Call of Duty tournament was destroying Twitch earlier, it may have just been a temporary problem. You could also try different servers.
