OBS won't separate audio tracks (TRIED EVERYTHING)
apollo_wg
So I am having trouble with my obs separating audio tracks I have followed multiple videos but seem to end at the same outcome every time.
I am trying to get: Track 1 - Game audio, Track 2 - My Mic and track 3 Discord. I have voicemeeter Banana setup to split all the audio.
When I leave all my audio on track 1 everything works, when I separate my audio it only picks up the audio on track 1 and not 2 or 3.
I have it set up in the advanced setting to record multiple tracks and have the recording format to mkv. and it still only records on one track.
I use filmora 9 to edit and only one audio track shows up.
All devices are picking up the inputs to obs.
OBS Settings
Advance Audio Properties
OBS Sources
Editing Software Tracks
It looks as if you set up OBS correctly. It may be the audio tracks are present, but your video editing software isn't recognizing them.
Verify your tracks are really present or really missing. First, get MediaInfo. This is an app/shell extension that is able to display the properties of every track present in a video file. You're writing 6 audio tracks with OBS, so MediaInfo should show 6 audio tracks.
Additionally, use the VLC media player to see and listen to each track. VLC is known to recognize everything OBS is writing to a video file. You can manually switch through the tracks and verify the content of each track.
