Hello everyone, I know there is another thread where it explains why OBS uses that much CPU and yes, I did read it but this problem started happening recently.
I have been streaming 720p60fps for months now and I never had any problems at all, until a couple days ago. OBS keeps warning me about High CPU usage, consider lowering/decreasing quality. The stream then starts to lag every 2-3 seconds which leaves it pretty much "unwatchable"(if that's even a word)I don't get it! I am using the same exact PC, with the same exact settings just for the part where I added an AverMedia Live Gamer HD capture card(currently 1 PC setup).
Also another issue I started having is that whenever I open the 64bit version of OBS it always keeps saying there are new updates:
OBS Software (0.654b), <Currently using this version, doesn't make sense to update to it again!
Directshow Plugin,
Game Capture Plugin,
Noise Gate plugin,
Per-Scene Volume Plugin,
Scene switcher Plugin,
and if I want to download them, when I click yes it simply tells me "All available updates are already installed".
This happens everytime I open the 64 bit version but 32 bit works just fine, except for that high CPU usage problem.
One last thing I wanna add is that when I tried adding the CLRBrowser plugin from twitch alerts for both 32bit and 64bit, it only works with 32bit versions. I did copy the 64bit files to the 64bit version of OBS but somehow I cannot add the CLR Browser while using the 64bit, so I opened the 32 bit version, added it and it worked as expected. I then opened the 64bit version of OBS and I could see the CLR Browser there...I just dont get it!
I know this is a lot and I am not expecting to fix everything all at once, so even help on only one of these problems will be appreciated.
-Blaze
Directshow Plugin,
Noise Gate plugin,
-Blaze
