Question / Help OBS turns volume of mic low after a few minutes of tests
Robert Kennedy
Hey there!
need some advice. I use a Akai EiE Pro Interface. I have a Condenser mic. When i first set it up, things work beautifully. I do tests, sounds great. Within 10 minutes or when i'm ready to stream, the volume for the mic is automatically low. Streaming doesnt cause it, it just auto happens in the application after its been turned on for about minutes.
When I turn off my computer/ set up for a few hours, I re test and the sound is fine for 5 minutes and then back to reverting.
In my Windows sound and recording settings, I have enhancements turns off for all devices, i also have the exclusive modes turned off in all devices.
However My Akai Pro in the recording tab of the sound window, doesnt have an advanced tab like the other mics, where i can turn off "allow applications to take exclusive control"
My other mic set ups work fine with not problem, but this set up, after 5 minutes, turns quiet for no reason
any input would be appreciated.
