DarkMoon376
Log click this for this also a favor I ask if for it to be a little in depth as I don't know much about OBS studio so I might be lost trying to find a setting you show, thank you.
1. Enable Game Mode via the Windows 10 "Settings" app, under Gaming > Game Mode.
2. Previous posters have stated Roblox caps the FPS at 60, so change the refresh rate on your monitor from 144 Hz to 120 Hz.
3. One of your audio devices has a sample rate that doesn't match the rest. This can result in audio drift over time or sound distortion. Check your audio devices in Windows settings (both Playback and Recording) and ensure the Default Format (under Advanced) is consistent. 48000 Hz is recommended.
OBS Sample Rate: 48000 Hz
Headphones (Realtek(R) Audio): 48000 Hz
Headset Microphone (Wireless Controller): 16000 Hz
Microphone Array (Realtek(R) Audio): 48000 Hz
Microphone (Realtek(R) Audio): 48000 Hz
3. Run OBS as Admin. Right click on the shortcut, properties, advanced, check box, ok, apply, ok.
4. Uncheck the box for Psycho Visual Tuning.
5. Record to MKV. If you record to MP4 or MOV and the recording is interrupted, the file will be corrupted and unrecoverable.
If you require MP4 files for some other purpose like editing, remux them afterwards by selecting File > Remux Recordings in the main OBS Studio window or enable Auto Remux in the Advanced Settings.
6. What resolution does Roblox run at?
7. Does this happen in regular, non-beta, Roblox?
Ok also, for the 7. this happens all the time In and not in roblox, I go to my desktop same thing or rocket league or rust it shows the same weird looksOkay I will try this
