Bug Report OBS streams audio, does not record audio
Sliq
I finally managed to get OBS up and running, and after streaming for a bit I went to check on the recording and it had no audio from neither the gameplay nor my microphone.
I tested it earlier and it worked, but not it isn't I have attached a log from my current session in which I did a quick record to see if it still wasn't working and it wasn't.
  • 2015-10-17 22-57-40.txt
Sliq
I seemed to have solved this myself. According to the log, I was missing "CoreAudioToolbox.dll", which is apparently a DLL associated with Apple for the AAC file format. So I installed iTunes and apparently it works now.
I'd still like some opinions on the log, as there seems to be a lot of DLL failures in the log, and I'm curious if I should try to seek these out.
Sliq
I also posted this in the wrong forum like an idiot. I am using multiplatform, and this is not the correct forum.
