OBS Streamlabs + audio interface + browser audio
crisJm
I can enable loopback on my audio interface to route both the music playing from the browser mixed with my voice from the mic connected to the audio interface and it works fine. However, I need to be able to route my voice and music separately into obs streamlabs, effect my voice with a plugin and then mix them together while also continuing to monitor through my headphones that are connected to my audio interface. This seems to be easier to do on a pc, but so far, no luck on the Mac.
I can get only the following options so far:
* my voice mixed with music if using loopback as a single audio input into obs.
* my voice by itself and no other audio source if not using loopback.
I have tried using the existential black hole driver to create a multi output device but I cannot figure out how to use that with obs and monitor voice + music through my audio interface (headphones) at the same time.
If anyone has tried something similar and has any insight it would be much appreciated!
crisJm
Figured it out. Installed obs studio instead. It turned out be easier. Configured blackhole and now it works!
