Question / Help OBS [SOUND PROBLEM]
NordgrenTv
Hello guys!
my name is kevin and i have a small but also big problem. when i stream everyting works very good exept one little thing. The only sound that my "headset" or what you should call it records is my voice. If i start the stream and for example go to someone else stream and hear nothing from hes stream. Same way goes if i wanna put on music on spotify or youtube. I hear the sound but it's does not get recorded to the stream... please help me guys! thx
dodgepong
Administrator
Community Helper
Make sure you select the correct Desktop Audio device in your OBS Audio settings. It should be set to whatever device audio is being output to.
