Question / Help OBS says its recording at 60fps, my game is 60fps, it still has frame drops though. Please help.
FrxstyBoy
Ok so you read the title, here are my specs and a log file:
GTX 1080
Intel Core i7 8700k 3.2Ghz 8th Gen
16GB of ram
Log file:https://hastebin.com/qotopavaya (The video is really short because I was just testing to see if it really was dropping frames)
If you need me to give more info, just ask.
18:05:48.591: Windows Version: 10.0 Build 17134 (revision: 590; 64-bit)
Windows is out of date and game mode is on by default and cannot be turned off. Check the signature for instructions on updating and turning this off.
18:05:48.711: OBS 21.1.0 (64bit, windows)
OBS is out of date. Download the latest directly from the website. The latest is 22.0.2.
18:05:48.591: Windows 10 Gaming Features:
18:05:48.592: Game Bar: On
18:05:48.592: Game DVR: On
Turn these off.
18:05:50.659: Loaded scenes:
18:05:50.659: - scene 'Streaming':
18:05:50.659: - source: 'GWF' (game_capture)
18:05:50.659: - source: 'DS3' (game_capture)
18:05:50.659: - source: 'Gmod' (game_capture)
18:05:50.659: - source: 'Kf2' (game_capture)
18:05:50.659: - source: 'brick rigs' (game_capture)
18:05:50.659: - source: 'Fortnite.exe' (game_capture)
18:05:50.659: - source: 'R6' (game_capture)
18:05:50.659: - source: 'Flash Games' (game_capture)
18:05:50.659: - source: 'OVERBATCH' (game_capture)
18:05:50.659: - source: 'Portal 2' (game_capture)
18:05:50.659: - source: 'Minecraft' (game_capture)
18:05:50.660: - source: 'Tabletop' (game_capture)
18:05:50.660: - source: 'tutorials' (monitor_capture)
18:05:50.660: - source: 'OVERBATCH' (game_capture)
18:05:50.660: - source: 'Game Capture' (game_capture)
18:05:50.660: - source: 'Overlay' (image_source)
18:05:50.660: - source: 'Dying Light' (game_capture)
It is not recommended to have multiple game captures in a scene. Either use one game capture and reconfigure it per game, or put them in different scenes or scene collections.
You should not put display and game capture sources in the same scene, this is non-performant.
18:11:39.666: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 1 (0.0%)
18:11:39.666: ==== Recording Stop ================================================
18:11:39.666: Video stopped, number of skipped frames due to encoding lag: 2/19825 (0.0%)
There is no significant frame drop recorded in the log.
Turn these off.
TY for this, i didnt think because they're in a different scene it would affect it but ill try this out and see if it works
