everytime I record a video (mp4 format) no matter if it is 20 fps or 60 fps, its always choppy and low quality!!! why is this? I thought my pc was powerful enough to do this sort of task. I get anywhere from 180-300 fps in game while recording/streaming on max settings, so why can't I do the (what i think should be simple) task of recording a 30-60fps video on a game such as counter strike in at least 720p?
-Thank you, Don.
Radeon Software Version - 16.8.2
Radeon Software Edition - Crimson
Graphics Chipset - AMD Radeon (TM) R7 370 Series
Memory Size - 2048 MB
Memory Type - GDDR5
Core Clock - 985 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 16 GB
CPU Type - Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
my monitor is a |1600 x 900| 60hz w2072a HP monitor
________________________________________________
OBS SETTINGS:
x264 encoder
no CBR (tried both on and off didn't make difference)
1000 Max Bitrate
Custom Buffer Size: 0 (tried no custom size but noticed no difference, should I leave default?)
Mode: File output only (saving video as .mp4)
Base Resolution: 1600 x 900 (downscaled 1280 x 720 didnt notice a difference while downscale off, what should I use?)
Filter: Bilinear
FPS: 30 (also tried 60 and would use 60 if possible)
__________________________________________________________________
OBS LOGS https://gist.github.com/1fad1ebd7020e6f823eaeb5ab6457931
X264 CPU preset: VeryFast
Encoding Profile: High
Use CFR (CHECKED)
Custom x264 Encoder Settings: cfr=5 (tried 5-20 noticed no difference)
EVERYTHING FROM THERE ON OUT IS DEFAULT :D
-Thank you, Don.
Memory Type - GDDR5
OBS SETTINGS:
x264 encoder
1000 Max Bitrate
Filter: Bilinear
Use CFR (CHECKED)
